12-07-2019, 08:42 AM | #29 | |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
what are your goals and future use? I absolutely LOVE my AAM 3.91's which is what GM uses and allowed me to practically drop them in...kept my stock posi but threw in a Ford S spring(self mod) for drag racin...my understanding trutrac better suited for track but heck what do I know. l8tr PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
12-07-2019, 02:24 PM | #30 |
Drives: 2014 1ss camaro Join Date: Jul 2017
thanks frank, going to do street/cross country driving. 6th is alittle low on the rpm for me. the old Harley days the mechanics used to say that the v-twin four stroke sweet spot was between 25k and 35k sustained rpm for running smoothly. drove the old ladies caddy at 85-90 mph for 100 miles the other day and it got better gas mileage than going 70-80 mph/ 23k rpm. so there seems to be truth to it.
12-08-2019, 01:46 PM | #31 |
FYI...found these on ebay today...
https://www.ebay.com/itm/For-Chevy-C...t/283559167089 and https://www.ebay.com/itm/For-Chevy-C...t/283573396348 and the nut https://www.ebay.com/itm/GM-OEM-Axle...8AAOSwTIhads7Q finally the washer https://www.ebay.com/itm/Chevrolet-G...MAAOSwvMFa11w8 hope this helps anybody still lookin...this is the exact setup on my ride for 3 years now and has stood up to over 100 drag launches.. l8tr PEACE
12-09-2019, 07:25 AM | #32 |
GPI Sales Consultant
I am pretty sure the TruTrac fits any ratio that fits on the OE SS Limited Slip carrier. If that's a ZL1 3.73 it's a no-go, but if it's an aftermarket for the 218mm SS rear it should fit a TruTrac fine.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
12-11-2019, 06:40 PM | #33 |
got my truetrac in today and my bearing kit yesterday. gears ship 12/23/19. eaton polished 3:73. I know iknow ! but, for my type of driving this is my best choice. I'm afraid with down shifting any numerically higher gears i'll plant my face in the windshield. still waiting on left axle also
12-18-2019, 03:34 PM | #34 | |
Space Coast Camaros
Drives: 2012 Camaro Vert Join Date: Sep 2011
i got everything for Diff. just need axles now |
12-20-2019, 08:05 PM | #35 |
kalcorp, yes me too I'm waiting on axles also specificlely the left one. the dealer says supply house can only say that they are in shipment
12-20-2019, 08:08 PM | #36 |
that's ok though, got screws put in my right foot cant do squat now anyway. just stare at parts , drink beer, and heal up.
01-02-2020, 10:32 AM | #37 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I am going to lower my car. Are these bushings used to raise the diff or lower it? I haven't looked at my axles and such yet, when under load is the wheel side actually going higher than the diff side? I am used to the wheel side usually being lower than the diff on other cars so I thought lowering the car would actually already help the angle. Does it have the opposite effect on our cars?
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
01-02-2020, 01:41 PM | #38 | |
01-07-2020, 09:14 PM | #39 |
got my 1le axles, now waiting on ring and pinion. foot starting to heal. probably start pulling stuff off this weekend. was just going for the axles. then low and behold here comes a trutrac, toe rods, arms, gears. you guys are a bad influence on an old man. heh heh !
01-18-2020, 04:24 AM | #40 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
For some reason my stock axles in my 2011 convertible look thicker than the ones in post #18
04-15-2020, 08:49 AM | #41 |
Space Coast Camaros
Put in order with GM parts direct and got email today that GM has Both Axles on backorder with no ETA.
09-18-2020, 02:45 PM | #42 |
Space Coast Camaros
Finally got to order the 1LE Axles today. lets hope this time the order does not get canceled again.
