02-20-2016, 12:52 PM | #29 |
Drives: 2013 Camaro SS LS3 Join Date: Mar 2014
2013 1SS LS3 M6 - ZL1 (3.73) differential kit - Street Slayer Twin Disc - Cam Motion cam 228/236 spec'd by Patrick Guerra - C5r timing chain - manton pushrods - BTR dual .660 valve springs - TSP 1"&7/8 LT's(no cats) - 3" Hooker Black Heart axle back with 4" quad tips - MGW flat stick shifter - tuned by Patrick Guerra @LSX performance dyno tuning - 305/45-18 MT ET Street
02-20-2016, 12:54 PM | #30 |
02-20-2016, 01:00 PM | #31 |
These two pictures are two axles I broke at 463 rwhp on the passenger side. the first one broke at the joint and made a mess, it was the factory axles launched it at about 4800-5000 rpms and it just went. So I figured the 1le axles were better since they had bigger joints, but I guess I was wrong I found the new weak point which the second one as you can see broke at the shaft before the joint at about the same rpms as the first one. So now I'm looking for something that won't break I didn't want to go the 1000 hp axles because I didn't want to shuck the rear differential.
Here are the axle measurements I got: The new axle joint measurement Part# 22806796 right Wheel side 4-1/8 Differential side 3-3/4 Axle length boot to boot 13-5/8 Axle O.D. 1-1/2 The old axle joint measurements Part# 22813178 right Wheel side 3-3/4 Differential side3-3/4 Axle length boot to boot 13-7/8 Axle O.D. 1-1/2 The new axle joint measurements Part# 22806795 left Wheel side 4-1/16 Differential side 3-7/8 Axle length boot to boot 15" Axle O.D. 1-1/4 The old axle joint measurements Part# 22813177 left Wheel side 3-5/8 Differential side 3-13/16 Axle length boot to boot 15-1/4 Axle O.D. 1-1/4
02-20-2016, 05:41 PM | #32 |
Drives: 2010 Camaro SS Join Date: Oct 2013
ZL1 diff FTW
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
07-20-2016, 03:36 PM | #33 |
Drives: 2011 Camaro SS Join Date: Sep 2013
Old thread, but adding my $.02
I'm running stock L99 for power outside of CAI and cat-back. I've broken the stock axels twice on track (corvette museum). Once the passenger side split, and the second time both broke at joint. Word is around track the stock Camaro axels are prone to breaking. But I know of one guy who runs Z28 stock with no problem. I'm looking to upgrade, and IMO any track activity would warrant upgrade.
07-20-2016, 06:33 PM | #34 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Running 430 then 470rwhp last season and no issues here. M6 guys have had issues but everyone with automatic has been good on stock axels
07-20-2016, 10:32 PM | #35 |
What's the difference between the z/28 axle shafts vs the 1LE axle shafts???
Also will the z/28 shafts fit the SS???
Orange Krush II
09-09-2016, 02:01 PM | #36 |
Drives: 2011 Camaro 2SS Join Date: May 2016
06-26-2018, 07:26 PM | #37 |
Drives: 2010 Camaro SS RS 6 speed Join Date: Jun 2018
So I grenaded my rear end...
So a few weeks ago I was out having some fun in my 2010 Camaro SS (6 speed) and long story short I blew up my rear end. 💥 Car is mostly stock, intake, headers, just the basic bolt on upgrades. That being said I got a quote for $1900 for an upgraded set of gears and all the rest for having a grenaded rear end. I was hoping for some insight on maybe a better direction to go, or if upgraded gears and a rebuild is the right way to go. Also gear ratio and aftermarket manufacture recommendations would be greatly appreciated. It seems the only thing I really know about rear ends is how to destroy them lol.
Any insight would be great. Cheers 🍻 |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
New Product! 2010 Camaro Rear Trunk Panel Blackout Kit! | RPI Designs | Exterior Parts & Accessories | 25 | 06-18-2020 08:03 AM |
OFFICIAL 2010 Camaro Specifications (full tech specs PDF inside) | Tran | Guides, Manuals, Bulletins, Documentation Archive | 394 | 06-11-2010 06:16 PM |
2010 Mustang GT vs 2010 Camaro SS | Fireball | Chevy Camaro vs... | 257 | 05-18-2009 11:04 AM |
Hennessey 2010 Chevrolet Camaro 705-HP!! (HPE700) | Caliman93230 | 5th Gen Camaro SS LS LT General Discussions | 172 | 04-01-2009 06:12 PM |
Consumer Guide's Impressions of the 2010 Chevrolet Camaro | camaro5 | 5th Gen Camaro SS LS LT General Discussions | 30 | 04-29-2008 10:20 PM |
