Old 09-23-2023, 11:04 AM   #379
driftking123
driftking123's Avatar
Drives: 2022 SS 1LE
Originally Posted by DemonZL1 View Post
there is an idle procedure that you can do as well, just takes time. The tool is a shortcut, essentially, and not a requirement.
Thanks Demon, I'll look that up.
driftking123 is offline   Reply With Quote
Old 09-25-2023, 04:09 PM   #380
driftking123
Drives: 2022 SS 1LE
Demon, why did you put the rear port on the corner instead of between the first section? Phastek and GPI both use the first section of the rows of lines. But in your video you are using the corner. Any preference or reason for it or does it matter? Oh I just thought of-does it make it easier to use the stock tubing?
