Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 09-28-2022, 09:34 AM   #379
ctrlz
Originally Posted by BWoods View Post
I’m thinking about selling the Camaro…
The shuddering has come back after a triple flush and a TC replacement. The car has only 49k miles on it. Has anyone else experienced this?
This is something that has always interested me. If the problem is hygroscopic fluid causing corrosion and uneven wear of clutch plates, why should it be limited to just the clutches in the torque converter? There are multiple clutches within the transmission itself:
https://atracom.blob.core.windows.ne...troduction.pdf
Old 09-28-2022, 07:28 PM   #380
My conjecture is that the C1-C5 clutches in the transmission are never allowed to slip and sufficient(ly high) pressure is always applied to them, unlike the torque converter clutch that is programmed to allow some slip by default. The shudder, after all, is the TC clutch engaging and disengaging several times in quick succession once the friction coefficient of the fluid drops below a threshold due to the absorbed moisture.
Zeroing out the slip tables in the transmission tune helps with the shudder, and this is probably why.
Old 09-29-2022, 12:16 PM   #381
ctrlz
So, where does Bwoods look next? Differential?
Old 09-29-2022, 12:20 PM   #382
Well, I am neither a mechanic nor a gm employee, my only response would be to try a revised stock or even a different aftermarket torque converter on his own dime, which I'm not going to suggest to anyone. Sad situation indeed.
Old 03-31-2023, 11:37 AM   #383
BWoods
Drives: 2017 Camaro RS
A8 TC Shudder Fix!!!
I wanted to update everyone on the status of my shudder. I have a 2017 Camaro that had significant shuddering. I had the triple flush - that helped for a while, then came back. I had a new TC installed that helped for a little while and then it came back.
THE FIX
I installed a range tech AFM disabler and that fixed it almost completely. No one else could notice the shudder anymore but since I knew the feel of the car I could tell there was a hint of shuddering under certain conditions. One day I tried premium gas and to my surprise the combination of the range tech and premium completely got rid of the shudder. I have been driving it without shudder for almost a year now. The range tech and premium gas is what fixed it for me. Very happy I did not sell the Camaro.
BWoods is offline   Reply With Quote
