Old 01-18-2019, 12:30 PM   #379
ZL1Boomer
ZL1Boomer's Avatar
Drives: 2014 ZL1
ACS installed. After questioning the stability, ACS told me the key was to push on the back of wheel well felt as you pump rivet gun. So I took out bottom plug on wheel well and after aligning and drilling the holes, pulled the felt out to get my hand behind as I did the rivets. Couldn’t get the bottom plug back in as it’s covered by rock guard now but don’t think it will be a problem. They feel solid. And yes my tire is wacked. Car was a repo and they never had correct pressure for 8K miles. But got a great deal. Hope I do pictures correctly.
ZL1Boomer is offline   Reply With Quote
Old 01-18-2019, 03:17 PM   #380
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
Looks good !
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 01-18-2019, 03:23 PM   #381
meSSohappy
meSSohappy's Avatar
Originally Posted by 2018ZL1 View Post
Count me in for the rears as well! Just bought the fronts and they look waaaaaaaay better than the ZL1 addon ones!!!
Added you to the list.
List updated.
Old 01-19-2019, 07:45 AM   #382
2017-ZL1
2017-ZL1's Avatar
Drives: 2017 Red Hot ZL1
I installed the ZL1 Addons. Mine did come with black hardware which is easily addressed either way. The small gap in the rear doesn't bother me. Nothing a short piece of 1/4" foam insulation tape want fill. Easy to install. I never removed any tire at all. Rear was installed using a 1/4' gear wrench with a T15. About 45 minutes for all 4 corners.
2017-ZL1 is offline   Reply With Quote
Old 01-19-2019, 10:20 AM   #383
meSSohappy
meSSohappy's Avatar
This exactly what I did. The foam tape attracts debris and doesn’t last long. Also looks like shit on a beauty car. Looking forward to this ACS upgrade.
Old 01-22-2019, 06:08 PM   #384
meSSohappy
meSSohappy's Avatar
Check out this link. Its for the gen6 Camaro rock guard install front and rear. Keep in mind this is not for the ZL1, but informative all the same. The fronts install the same. Wont know about the rears until they are made.
https://acscomposite.us7.list-manage...6&e=baf54be425
Old 01-23-2019, 06:35 PM   #385
JSAVILLE
JSAVILLE's Avatar
Drives: 2018 ZL1 Vert. A10
Are the rears available yet???? I haven't been on the site for a while. I have order the fronts and received them.
Thanks a lot
JSAVILLE is offline   Reply With Quote
Old 01-27-2019, 01:39 PM   #386
FunChevy
Drives: 19 ZL1
List updated.
Ordered the fronts. Please add me for rear set.
No change in fit for 19 ZL in back?
c
FunChevy is offline   Reply With Quote
Old 01-28-2019, 10:24 AM   #387
meSSohappy
meSSohappy's Avatar
c
Added you to List ! Thanks !
Old 01-28-2019, 10:25 AM   #388
meSSohappy
meSSohappy's Avatar
Design phase is complete and tooling is underway. Hopefully production will start soon
Old 01-28-2019, 04:54 PM   #389
Mcardenal
Mcardenal's Avatar
Drives: 2018 Nightfall Gray Metalic ZL1 A10
woohoo!
Mcardenal is offline   Reply With Quote
Old 01-28-2019, 07:50 PM   #390
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
Nice. Thanks for the update.
7LitreC5 is offline   Reply With Quote
Old 01-28-2019, 07:58 PM   #391
RandRZL1
RandRZL1's Avatar
Drives: 2018 ZL1
Can’t wait!!!!
RandRZL1 is offline   Reply With Quote
Old 01-29-2019, 07:22 AM   #392
Ten4Lou
Ten4Lou's Avatar
Drives: 2018 ZL1 NGM
Question... do these front flares (ACS) prevent how the front tires spray water all over the side doors and rear fenders when the roads are wet? I’ve been on the fence with buying these but may pull the trigger if that problem is eliminated.
For those who have them, what’s your experience?
Kind Regards,
Lou
Ten4Lou is offline   Reply With Quote
