#379 |
I used to be Dragoneye...
#380 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
At some point there has to be diminishing returns I would think. This thing is going to have plenty of power to pull a little lower RPM's out of a corner with a wider spread. My guess is that GM tested both and found little if no reason to run the 10AT at the limits and maybe it was actually less suited (less reliable) for heavy track use which I think a good amount of these purchased will be used for.
#381 | ||
BeckyD Rocks :-)
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
#382 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
I think they're only offering the manual to keep the price down and possibly to deter less track oriented owners from buying a car that really isn't a daily driver considering the tires and extra stiffness of the suspension. On the other hand; those in the know will be salivating over this option once the reviews start coming in.
#383 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE Join Date: Mar 2016
IG: @NC_M1SS1LE
#384 |
It's also worth remembering...the ZL1 1LE weighs 124 lbs lighter than an automatic ZL1.
That is significant, and will surely result (coupled with the crazy-wide, grippy tires and aero) in increased performance beyond what is worth the added weight of the automatic. I think there were several factors in the choice:
#385 |
^^^ All very good points especially on the weight difference. The fact they got the curb weight (which btw includes a full tank of gas) even lower is impressive. If my math is right; 60-3,886 (M6 car weight) = 3,826-lbs for the ZL1/1LE model. Subtract 57-lbs for a 1/2 tank of gas and you get 3,769-lbs. Wow, that's impressive for a factory super charged car. I know it's a road course car, but I would love to see someone throw some drag radials on this thing to see how it runs at the drag strip.
#386 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
#387 | |
![]() The best part of the weight reduction is it's all in rotating and unsprung mass...wheels, tires, dampers...it will make for lightning-quick responsiveness to directional inputs, braking, and acceleration. And they specifically list ZL1 1LE as 3820 (those 6 pounds help! )
#388 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 Status "Thank You!" Join Date: Feb 2009
#389 |
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Wake me up when they offer the A10 with the 1LE package in either the SS or ZL1 trim.
#390 | |
BeckyD Rocks :-)
#391 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
![]() I was going to post the same thing with an apple, but didn't want to be a jerk![]()
#392 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
My lease is up in 11 months.....
