10-11-2019, 09:07 AM | #3865 |
Drives: E92 BMW M3 Join Date: Oct 2012
Will be interesting to see if GM executes the FPC better than Ford did(history says they will). It is bigger than Ford's version too, which correct if I am wrong, up to this point the Voodoo was the biggest production FPC ever right?
I am glad I have waited to pull the trigger. A high revving Chevy engine is exactly what I have been waiting for. I hope they put it in a platform with a manual though.
J-Rod Built and Matt@FSP Tuned |
10-11-2019, 10:12 AM | #3866 | ||||
Drives: 21 Bronco Join Date: Jun 2012
Agreed lol Quote:
Now I an article I read from MT said they expect the Z06 version to be smaller and turbo charged. Quote:
But if the MT report is wrong and it's 5.5 and NA man oh man that thing is going to scream to make 600HP. It's going to be amazing lol. I can't wait to see more details I will be curious to see how people here view it, it's going to lack low end torque so it will be interesting to me to see how people who have been pro OHV and low end torque like it.
10-11-2019, 01:46 PM | #3867 | ||
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
http://gmauthority.com/blog/2019/10/...-based-engine/ Quote:
Now, if you gave me a choice of a C8 with a LT2 (almost 500HP), or a 500HP 5.5L N/A FPC that revs to the moon, it's a no brainer, I will take the LT2 everytime. If the choice was an LT2 (almost 500HP) or a 600HP 5.5L N/A FPC that revs to the moon, I would take the LT2 if it was more of a street car or a daily driver, but I would take the 600HP engine, if it was mostly a track car. That's because, on a track, you will be keeping the engine in the meat of the power band, so the lack of low end won't be that noticeable. On the street it will be noticed quite often, and it's not my cup of tea for street application. Others may feel differently, and that's fine with me. I respect other's personal preferences. |
10-11-2019, 03:21 PM | #3868 | |
Man a 9k rpm screamer. The thought of that sounds so amazing |
10-11-2019, 03:38 PM | #3869 |
Gives me goosebumps!
10-11-2019, 06:28 PM | #3870 | |
But when you listen, listen how fast this engine gets from idle to max RPM. It's like a light switch. That's the advantage of an FPC. It has a big reduction in rotating mass in the engine because you don't need huge balance weights on the crankshaft. BUT, BIG NOTE: The GT350 couldn't fit a dual intake system that the FPC V8 requires, so they had to use a different firing order, and most of the mass had to be added back in to the crankshaft in the Voodoo. Regardless of the power output or oil issues or whatever, the main advantage of an FPC V8 engine was NOT present in the Voodoo engine. It has a somewhat reduced mass over a cross plane crank, so while it can rev high, it can't rev high fast. Listen to what a true FPC V8 can do in terms of going from idle to the max RPMs. It's like a lightswitch: https://www.youtube.com/watch?time_c...&v=BlGLoWnHyMw |
10-11-2019, 07:54 PM | #3871 |
Drives: 2016 F150 Join Date: May 2014
Pretty sure GM was putting out more powerful ohc v8 in the 90s than Ford was. Besides, is there really that much of a development difference between a v6 and v8 one? I won't bring up reliability because the Voodo sure isn't known for it.
10-11-2019, 09:24 PM | #3872 | |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Trying to rev my 350 made me feel like i had ED. |
10-11-2019, 09:40 PM | #3873 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Lotus built the C4 ZR1 engine, not GM.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
10-11-2019, 09:41 PM | #3874 | |
2021 Camaro ZL1 A10
10-11-2019, 09:43 PM | #3875 | |
2021 Camaro ZL1 A10
10-11-2019, 09:48 PM | #3876 | |
2021 Camaro ZL1 A10
10-11-2019, 09:58 PM | #3877 |
I prefer NA engines over FI for a given similar hp output. An NA FPC 600-620 hp C8 Z06 would be killer. Would be nice if they could squeeze 625 hp out of it to keep it closer to the C7 Z06 output; but at 5.5 liters, 600 hp is 8% more hp/ liter (109 vs 101 hp/liter) than the Voodoo. Would emissions and reliability requirements be met at that output? Only exotic NA engines have higher specific output than the Voodoo.
That said, I hope they do it: 600+ hp FPC 5.5 liter C8 Z06.
2021 Camaro ZL1 A10
10-11-2019, 10:30 PM | #3878 |
