#365 |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
Update: Mike and the Katech team seem to be making really good progress! 1) Port plates are on, 2) fuel lines are ran, 3) fuel filter kit is mounted, and 4) the blower is back on. Reflex wiring is next. They had to order a fitting for the catch can. The MM wild kit includes a fitting for the stock valve cover that replaces the oil cap which doesn’t fit in the billet valve covers.
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•BGRF•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#366 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Mouse = rodent?
#367 |
#368 |
Update: Katech had to order (expecting delivery tomorrow) a few connecting pins for the AEM AFR Wideband gauge/controller. This is where the THPSI Reflex controller need to connect. Then, configure THPSI controller and then Dyno and tuning! I am schedule to pick her up on Monday! But, wow, she's back together nicely!
#369 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Umm….they forgot the Magnuson :P
#370 |
Thank you Al Oppenheiser!
I gotta say that's a really nice lookin' engine bay.
Thanks for sharing your journey!!
#371 |
The fall mods are coming!!! Mike at Katech knows I'm almost talked into the Stage 5 package! I actually considered adding this while they were doing the current build since the car was already in their shop. But, good weather is here and I actually wanted to give the forum/users here info/data on what a build like this can do: Stock blower w/Kong X-port, pulleys and THPSI and all the other goodies! But Stage 5, Magnuson, CAM, upgraded DI and THPSI... whoa!!! Might even throw in a trans tune !
Thanks ! and yes this has been a journey! All started out with me wanting a Camaro ZL1 since they talked about ending production (I bought mine new Dec 2022) and that was all I wanted! Then, I got the need more power fever! I can't wait to get it back !!! First-things-first, the garage "car spa" to make her more presentable... well after the first trip to "Mexico" and a few WOT runs!!!
#372 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Congrats on your build and enjoy, just one thing. Katech could do a little better in hose routings to clean up the clutter around the engine, see my pic.
#373 |
Dang that's a clean job you've done! I'm already planning a "wire/hose" re-route!
#374 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Man get them to clean up those intake coupler clamps to something that doesn't look awful
Or at least trim the length and turn them 90 degrees.
GM Gen V Calibrator
#375 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Hey Scott, Sorry to hijack the thread.... but a quick question for SMOKIN... can you please explain the routing / changes you made to the PCV system? I see you deleted all connection to the OEM oil separator?
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#376 | |
Dave
#377 | |
Katech didn't do any of the cold air intake stuff it was already done. So, to be fair, that was all my doing. But, I have all new black hose clamps at the house waiting to swap them once I get it back. I also have a new BigGulp induction elbow to swap out the one I have now. I had to use a rubber plug and plug an un-need hole I made when I originally had my Elite E2-X Catch Can.
#378 |
Update: I don't think I could be more thrilled than I am, with the final Dyno/Tune results! 784rwhp, 687 toque @ 19psi Boost. Mike and the team really hit this out of the park !!! Thanks Katech !!!
