Old 06-24-2021, 01:55 PM   #365
Lawrence1
Drives: BMW
Originally Posted by TCCamaro View Post
Hey GearheadSS how much is the option for the carbon free brakes that are required in California? I know they are six piston up front and thought about adding the option as an upgrade.
The only change made is with the brake pad compound, the braking system remains the same. I believe this only affected the 1LE cars anyway, and I don't believe there is any effect on pricing. They basically re-formulated the brake pad material.
Lawrence1 is offline   Reply With Quote
Old 06-24-2021, 02:00 PM   #366
TCCamaro
Drives: 2016 Camaro 1LT RS V6
I looked it up and found this article that states, "By 2025, the brakes had to have less than 0.5 percent copper by weight. It’s because of this rule that starting on January 1, Chevrolet won’t be able to sell the 2021 Camaro SS, 1LE, and ZL1 in those states due to the copper content of the Brembo brakes, which exceeds 5 percent." So the SS models are included which are the 4-piston brakes up front. I assume there has to be some additional cost upgrading from 4-piston to 6-piston which is why I was curious.
I found it in a Car and Driver article btw!
TCCamaro is offline   Reply With Quote
Old 06-24-2021, 02:38 PM   #367
D.O.M.D1
Drives: i want a camaro
That's because the official pricing schedule hasn't been published to dealers yet. We have partial 2022 pricing because when we go into the order system, it shows pricing when we build the car out. The only thing missing is the Gas Guzzler Tax for ZL1. Once Gas Guzzler is priced, the full pricing schedule will be released.
now i get it,gas guzzler tax is still pending,till then we can go to the dealers and we can build one/order one for now before the build and price feature is live on chevy.com
D.O.M.D1 is offline   Reply With Quote
Old 06-24-2021, 02:39 PM   #368
D.O.M.D1
Originally Posted by BrandanK View Post
Dude. Just stop. Please.
ok i will
Old 06-24-2021, 02:53 PM   #369
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Here you go.
ZL1 - $500
SS - $995
SS 1LE - $0
When you order it on SS, you also get the J6H 6 piston front, 4 piston rear brakes with 2 piece rotors from the ZL1. So it's a fantastic deal for non 1LE SS cars at $995. It will make brake jobs and rotor replacement more expensive but the option price is great.
On SS 1LE, you also get the J6H ZL1 brakes instead of the standard J6M SS 1LE brakes. If you don't order the copper free pads, you get the J6M brakes. I don't know if they're still red when you order them though. My guess is that they are.
In case the option codes are confusing:
J6G - Brembo 4-Piston Front and Rear - Standard on 1SS and 2SS
J6H - Brembo 6-Piston Front and 4-Piston Rear - Standard on ZL1 and on SS/SS1LE when ordering BCD Performance Copper Free Brake Pads
J6M - Brembo Red, 6-Piston Front and 4-Piston Rear - Standard on SS 1LE without BCD Performance Copper Free Brake Pads
These will be required for all SS and ZL1 cars shipped to CA and WA. They are not available on Redline Edition and not available with the following wheels: 56M, 56R, 56W, 57S. They are also not available with the optional Red or Orange Calipers on SS.
Old 06-24-2021, 02:58 PM   #370
GearheadSS
GearheadSS's Avatar
Correct. If you're ordering a ZL1, it will still show W/A in the price field but everything else should be good.
Old 06-24-2021, 03:01 PM   #371
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
Here you go.
ZL1 - $500
SS - $995
SS 1LE - $0
I have J6L on my newly purchased 2018 Hotwheels Edition. They are orange painted calipers. I’m guessing it’s the standard 4 piston setup, as it is a 2SS, just with orange painted calipers, unless you know something different. Thank you
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
Old 06-24-2021, 03:08 PM   #372
GearheadSS
GearheadSS's Avatar
J6L is and has been the code for orange calipers.
Old 06-24-2021, 05:13 PM   #373
JoeCamaro444
Thank you.
I’m assuming they are the standard for 2SS piston-wise. 4 front and rear.
Previous cars:
Old 06-24-2021, 07:29 PM   #374
D.O.M.D1
thank you for the clarification, it sounds like you work for a dealer, I'm sure you heard of what happened to me, right, crazy huh and very unethical on the dealer part
Old 06-24-2021, 08:24 PM   #375
TCCamaro
Here you go.
ZL1 - $500
SS - $995
SS 1LE - $0
Awesome thank you for the information GearheadSS! I also ordered my car with red colored brake calipers, would they still come red if I got the $995 J6H option or would they be the grey color?
Old 06-25-2021, 09:08 AM   #376
GearheadSS
GearheadSS's Avatar
Right now it's unclear. If you ordered a non-1LE then you would likely get gray calipers with the $995 copper free brake system. Red or orange calipers can't be ordered with that option on SS.
Old 06-25-2021, 11:21 AM   #377
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
I thought this was a good article about chips, the shortage, auto manufacturing, etc....Just FYI...
https://www.freep.com/story/money/ca...21/7688773002/
Old 06-25-2021, 02:02 PM   #378
SusieL
SusieL's Avatar
Drives: 2022 2SS
Thanks for all the updates! I've certainly learned more here then from my questions to the local Chevy dealership.
I ordered a 2021 2SS back in February and even though the dealer said they had Camaro allocations every time I asked the order was never picked up by GM and I've been told that it has been cancelled after not hearing back from the dealer and then a call to the General Manager.
I have two choices: 1. I put in a 2022 order with the same dealership and hope this time they will get an allocation. 2. I can go with another dealership that is an hour away, generally sells more Camaros then the first dealership and says they can get an allocation when they open up because they sell a lot of them. The only issue would be that I'll be their 4th order for a 2022 and at the first dealership I'd be the first order in line. I've been waiting so long I don't want to have to wait even longer if I don't have to. How do you know if the dealer actually gets allocation and isn't just stringing you along?
Can dealerships get at least 4 Camaro allocations at a time?
Would you stay with the 1st dealership and hope that this time your order will actually get accepted (and not have to wait forever for it to get accepted) or would you go to the dealership who moves more Camaros and probably gets more allocation but you are 4th in line?
The Future
2022 Camaro 2SS | RBM | A10 | NPP | MRC| Sunroof | Splash Guards - Waited 10 months total!
2/25/21 1100 (2021) - 6/25/21 order cancelled by GM. | 6/26/21 1100 (2022) Ordered from Joe this time
8/20/21 2000 | 9/8/21 3000 TPW 9/27 | 9/15/21 3000 TPW 10/18
10/1/21 3400 TPW 10/18 | 10/20/21 3800 Finally Built!
11/5/21 5000 | 12/6/21 6000
The Past
1989 Pontiac Trans Am GTA | 1976 Pontiac Formula | 1971 Pontiac Formula | 1971 Buick Gran Sport 455 | 1969 Chevrolet Camaro SS | 1969 Buick Gran Sport
SusieL is offline   Reply With Quote
