#3501 |
![]() Drives: SEARCHING Join Date: Apr 2010
These same old arguments were around when power steering came into prominence over manual steering. Luckily there weren't online forums then....
I'm glad we've moved mostly away from manual steering.
#3502 | |
![]() ![]() Drives: 80 Cutlass 403, 2010 FF RT Join Date: Jun 2014
There were no 20k drag cars that were running 9.25 and the Drag Cars were all 50K plus and any car build North of the border would cost much more than it would in the US. TrackHawks were running 11.2 stock and one was well into the 10's Last edited by rocket403; 09-16-2019 at 09:36 AM. |
#3503 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
The Base GT500 is fully loaded (save for premium audio and Nav) so theres weight from that stuff. Supercharger obviously adds weight, massive brakes, and supposedly and hopefully more than enough sufficient cooling. I'll try to find the article, but one of the main goals was to make sure the GT500 can go all out all the time. That to me, is probably why it's so heavy and so expensive. Things Ford cut out of it's other cars had to be thrown in learning from all the mistakes they have made so far with the S550. Those things add cost and weight. Quote:
But yeah the GT500 is for sure more expensive, better bring the performance to back up that price tag. |
#3504 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
#3505 |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Ha; you missed the part where I said an additional 110 hp (and the DCT).
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
#3506 | |
I am still baffled as to why they couldn't keep the weight closer to 4,000 lbs, or at least under 4,100 lbs in the base GT500. That said, similar to the ZR1 being around 100 lbs heavier than the Z06, an LT5 powered ZL1 would be about 100 lbs heavier than the LT4 ZL1. Which would put the auto LT5 ZL1 at around 4,050 lbs. It would also be more expensive than the LT4 powered ZL1, most likely in-line with the base GT500. If you think GM would put the LT5 in the ZL1 and not increase the price significantly, and if you think an LT5 powered ZL1 wouldn't also be heavier than the LT4 ZL1, I have some ocean front property in AZ I could sell you.
2021 Camaro ZL1 A10
#3507 | |
Basically to me is it looks like the result of bandaids, and having to put stuff in that maybe they never anticipated having to do due to how good the Alpha Camaro is. Basically, ford short sightedness catching up with them again |
#3508 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
WOW, is that all that comes with the handling pack? No stiffer springs or anything?
J-Rod Built and Matt@FSP Tuned |
#3509 | ||
#3510 | ||
The car has been delayed enough and is expensive enough that I think they actually went all in trying to make the best car they can. Not undertired, massive brakes, proper cooling. All things in the past ford has cut short on, not on this one which is why I think it's so expensive |
#3511 | |
![]() ![]() ![]() ![]() Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
#3512 | |||
![]() ![]() ![]() Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT 1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
#3513 |
That is really my only regret in my car choices over the years, not sure wtf I was thinking not buying a manual HAHAHAHA
#3514 |
Lol, that's why no matter that the N54 is notoriously issue prone - I am keeping ours as it is manual and I love daily driving it. I will just do the major issue fixes ahead of time.
