Old 04-17-2024, 01:58 PM   #337
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by Katech_Mike View Post
Our fuel pump module will support 1,000RWHP on a stock returnless set up.
So there isn't any need to modify the feed line.
I just installed my Katech module and love it. I think my THPSI system, with the current injectors, is good to the same power level your bucket supports, and since I'm running the OEM feed line, and I'm not close to 1000whp, that confirms I did okay.
'20 ZL1 Black "Fury"
Old 05-06-2024, 05:21 PM   #338
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
All set for the trip and drop off at Katech tomorrow !!!
Mike, see you tomorrow afternoon !
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•BGRF•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 05-07-2024, 06:41 AM   #339
clg82
Drives: 2020 Camaro ZL1
I'm still trying to wrap my head around fueling....what does the Katech drop in solve? High side? My tuner here in TX mentioned i'd have to upgrade my high side to run any sort of E content with my car....sorry to derail lol
Old 05-07-2024, 06:56 AM   #340
2023_ZL1-AUTO
I believe the Katech Dual fuel pump and controller system is for the low side. But, since I'm adding port injection, it's a different requirement for fuel vs high side with out port injection. This systems also uses a return line to the tank. But, I could be 100% wrong on this too and I'm sure Mike can jump in on this question! Also, I was running E60 with no issues and my ZL1 was crazy strong. All I added was the Flex Fuel sensor and a JMS Fuel Booster for the low side! Then, I Kong X-ported my blower and that's when I started running out of fuel. Thus, new fuel system and port injection to solve the problem.
Old 05-07-2024, 07:44 AM   #341
clg82
Yeah I think with my 2650 and the boost i'm at i'm right at the top of fueling unfortunately
Old 05-07-2024, 10:51 AM   #342
ZL1...SON
Drives: 2021 Camaro ZL1
You were able to run E60 on your current setup with the stock high pressure fuel pump and stock injectors? or before the X-port and 2.3" upper?
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR
ZL1...SON is offline   Reply With Quote
Old 05-07-2024, 07:39 PM   #343
2023_ZL1-AUTO
No... It was E60 with stock high pressure system but JMS Fuel Booster for low site with stock pully. This was prior to Kong X-port and 2.3 upper, and now it dropped me to E25, thus taking it Katech for THPSI and new fuel system etc.
Old 05-07-2024, 07:47 PM   #344
2023_ZL1-AUTO
Made the drop off at Katech today. Mike was out but Keenan helped me get the car "checked in". He gave us a full tour of the shop, all 4 building! Just seeing the machining and fabrication work they were doing alone. Was confirmation I made a great decision to have them finish the reset of the work on my ZL1. All the people we met were great and it couldn't have been a better experience! They'll get a baseline Dyno done first part of next week. Then I hope to pick the car up about two weeks after that!
Old 05-08-2024, 09:22 AM   #345
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Congrats SCOTT... Your sig just keeps getting longer and longer... HAHA
Is their a such thing as signature envy?
When will we see dyno numbers?
What was Mike's prediction?
Old 05-08-2024, 10:20 AM   #346
2023_ZL1-AUTO
Baseline Dyno will be first part of next week. That's a procedural thing to make sure the car is right before they start working on it. But, with my fuel lowered to E20 since having my blower X-ported and running out on high side fuel at 5600rpm. I'm not sure I even want to see those numbers! Mike hopes around 775rwhp+ on straight E85. They will be removing the JMS Fuel Max Booster, the current Katech valve covers with coil relocation kit and the FI Chillers Blower Space Plates. So, a few less things that will be part of the overall mods in the mix! One thing, they've not done a build exactly like mine yet. Meaning, these mods on an engine 100% stock, no CAM and no heads etc. Mike will give progress updates once work starts he hopes no more than 2 weeks to complete. Then final tune and final dyno. Mike said he'd take some photos during the build!
Old 05-08-2024, 02:17 PM   #347
Katech_Mike
Drives: 2015 Camaro ZL1
Sorry I missed you Scott. I'm just now somewhat getting back on my feet after this damn flu or whatever it is.
I'm hoping we can make 775RWHP. Like Scott said we haven't done one with this exact combo without a cam so it will be interesting.
Our dyno isn't a record setter either. Stock LT4 cars typically make about 520RWHP for reference.
Katech_Mike is offline   Reply With Quote
Old 05-08-2024, 03:06 PM   #348
clg82
Every dyno shop is saying that these days to impress the customer when they pick it up..........kidding.....sort of.............can't wait to see the final numbers.
Old 05-09-2024, 07:45 AM   #349
Smokin19
Drives: 19' ZL1 A10, w/pdr
Following this thread and still learning, not trying to steal the thread. I went with the BTR cam (stg II) and a 38% fuel lobe tuned on 93 gas. We went with a conservative tune using Mustang tuning.
My question is this, would adding a cam to his build get him over 800 RWHP?
Smokin19 is offline   Reply With Quote
Old 05-09-2024, 08:13 AM   #350
2023_ZL1-AUTO
Mike can chime if he wants! But, Mike and I literally had this discussion yesterday and I have a quote in my hands and I'm still debating what to do. But, the most Mike feels adding a complete cam package including lifters, springs, push rods and all the other needed parts would get the car to 850rwhp. Thus, it would only add an additional 75rwhp more horsepower. So, I could be at 850rwhp, trap 140mph+ and be in the low 9 seconds in the 1/4 mile. But, at that point the stock LT4 blower is holding the power back. The CAM package install would only add an additional week to the build time, so that's not a big deal. But, the price is a bit steep and only getting an additional 75rwhp. At that point, I'm not sure I shouldn't just wait until this fall and do the rest of what's needed for a full Katech Stage 4 package that includes a Magnuson 2650. Then the LT4 blower is no longer the limiting factor. My ZL1 isn't my daily, it will also be turned for straight E85. I do make a point to drive it every day the weather is good! But, I'm hoping the actual rwhp is more than they are guesstimating!
