Old 05-27-2025, 06:17 PM   #337
SlamForce
SlamForce's Avatar
Drives: 2018 Chevrolet Camaro SS 1LE
Originally Posted by Apex Wheels View Post
The 285/35-19 and 305/30-19 recommendation comes from tire availability. There's a severe lack of 305/35-19 tires on the market, and those that do come in that size aren't desirable for track use. NT555G2 is a nice street tire for many people though.
There are no problems with TC/PTM to run the recommended tire combo. I would not do 285/30-19 up front, its very short and reduces ground clearance and will look a bit silly.
275/35-19 and 295/35-19 is also an option. Or even 315/30-19 rear with a bit of negative camber can work.
I would really prefer to maintain the size stagger with smaller diameter in front and larger in back. Since I got the Apex 19x10 and 19x11 for a track wheel setup to reduce weight without any modifications to suspension, tire compound and fit are top priority. Would you suggest 275/35/19 and 295/35/19 in either Falken Azeris RT660+ or Yokohama Advan A052? Car gets driven infrequently, with almost all driving on mountain roads and track.
The other option would be to go 285/35/19 and 305/35/19 with Michelin PS4S/PSS for what seems like ideal fit. This would get a little more rubber on the road and perfect fit on rim, a good street tire, and a tire that is fine but not great on the track.
2018 Camaro SS 1LE M6 Red Hot
Rotofab CAI, Soler 95mm TB, MSD intake manifold, Soler throttle controller, MBRP axle back, EMP rear seat delete, Titanium tow hook, Katech 160 thermostat, SPL rear toe links, BW front brake air deflectors, Apex ARC-8 wheels in 19x10/11 and Falken Azenis RT660
SlamForce is offline   Reply With Quote
Old 06-02-2025, 08:25 PM   #338
zapp
zapp's Avatar
Drives: 2022 ZLE 6M
@ApexWheels:
Are the ZLE spec EC-7RS in 19inch coming back?
zapp is offline   Reply With Quote
Old 06-12-2025, 01:40 PM   #339
SlamForce
SlamForce's Avatar
Quick Pic
Just installed:
Apex Arc8 in 19x10 front, 19x11 rear
Falken Azenis RT660 in 275/35/19 front, 295/35/19 rear
Old 07-21-2025, 11:33 AM   #340
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
Originally Posted by zapp View Post
@ApexWheels:
No, those have been discontinued sorry. I like the design a lot, even run a set on my own car, but demand was too low to keep producing them at this time.
Apex Wheels is offline   Reply With Quote
Old 08-13-2025, 12:16 PM   #341
Apex Wheels
Drives: Camaro Z28
Customer Showcase!
Check out this 6th Gen Camaro SS rocking 19x11 ET44 ML-10RT Machined Lip Gloss Motorsports Gold, wrapped with Goodyear Eagle F1 305/30/19's all around! This requires 30mm spacers but works as a square setup for track customers trying to get longevity out of their tires!
Click here to buy the same fitment!
Old 08-13-2025, 03:10 PM   #342
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
I love my set of Apex wheels. i'd like to get another at some point. However, you no longer make 19x11 ET35 which worked perfectly as a square setup when combined with 26mm spacers up front. You now only make ET44 which creates a tuck in the rear. Plus, to clear the front struts, you need at least a what, 1.5" spacer?
The reason the ET44 works above is because he's on ZLE DSSV shocks. I think it was a mistake to move away from the 35 offset.
Dabjbr is offline   Reply With Quote
Old 08-14-2025, 12:20 PM   #343
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I think you can still get the 19x11 et35 is certain wheel versions but they don't offer it on the ML-10s unfortunately, that's why I went with the above setup which is a rear BMW M3/4 spec. And I should add that I only use a 25mm spacer so if you grind down the strut and also run a Magride compatible camber plate you can probably also make this setup work on a "stock" SS 1LE with a 30mm spacer.
IG: @NC_M1SS1LE
Old 08-14-2025, 09:45 PM   #344
redfish86
Drives: GMC Sierra
VS-5RS 19x11 wearing 305/30/19 Nankangs
I really need a set of SM-10RS in satin bronze. (Or maybe even a set in 18”!?). When will y’all be back in stock?
redfish86 is offline   Reply With Quote
Old 11-24-2025, 09:29 PM   #345
zapp
zapp's Avatar
Drives: 2022 ZLE 6M
Are you doing custom orders for them? I would take 2 sets in ZLE spec and won't mind a long wait.
Old 01-19-2026, 10:19 AM   #346
redfish86
Drives: GMC Sierra
SM10RS. 19x11F, 19x12R. 305/30/19,325/30/19
One pic with some brake dust, just for fun!
Old 02-16-2026, 11:32 AM   #347
cdb95z28
cdb95z28's Avatar
Looks great! I'm debating the SM-10RS in bronze on my Wild Cherry SS 1LE. Do you have any other entire car pics of with those wheels? Thanks!
"KEEP THE FAITH"-Fbodfather
Old 03-09-2026, 07:01 AM   #348
-Rooster-
Drives: 23 2SS 1LE
ARC-8, Cont ECS02, ZLE sizes.
Camber: -3.5 front, -2 rear
2023 Sharkskin 2SS 1LE 6-speed slicktop
-Rooster- is offline   Reply With Quote
Old 03-27-2026, 05:23 AM   #349
redfish86
Drives: GMC Sierra
Attachment 1172506
This is all I have at the moment. I’m prepping her for my next weekend, I’ll try to remember to get a better one when I put those wheels back on.
They get dirty in a quick hurry at the track!!
Old 03-30-2026, 07:32 PM   #350
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
18x12.5" VS-5RS with 335/30-18 Bridgestone RE-71RZ Square.
MCS in front and spacers for fitment.
rotis is offline   Reply With Quote
