Old 05-06-2019, 07:12 PM   #337
jwisjw
Drives: 2017 Camaro SS
Wow, it's been a long time since I've posted videos. Ran quite a few local/nationals events in ESP form on older/newer tires.
March 23rd and 24th event was the first time we put on relatively fresher 295/18 Hoosier A7's that were ran from nationals of 2018. However, we bagged them when we received them back in September. Cars balance on new A7's versus old A7's really felt a lot similar balance wise but just more overall grip.
ESP 2017 Camaro Hoosier A7 (295) AAS 3/23 Jeff
ESP 2017 Camaro Hoosier A7 (295) AAS 3/23 Nicole
ESP 2017 Camaro Hoosier A7 (295) AAS 3/24 Jeff
ESP 2017 Camaro Hoosier A7 (295) AAS 3/24 Nicole
The Crows Landing Pro Solo was the first time we ran stickered Hoosiers and also in the 315 size. On the practice course, just mounting the 315's on the front, it was close to .7-.8ish difference over the Nationals ran 295's. Age could have easily affected time deltas. Balance seemed to have shifted towards the front with the 315 setup, the initial response was much sharper and transition speed was increased.
ESP 2017 Camaro Hoosier A7 (315) Crows Landing Pro Solo Left Jeff
ESP 2017 Camaro Hoosier A7 (315) Crows Landing Pro Solo Right Jeff
ESP 2017 Camaro Hoosier A7 (315) Crows Landing Pro Solo Nicole
Fontana Pro Solo courses were painfully tight after the crossover to the finish with no line choice on the exits pretty much. Hoosiers on the lower grip surface definitely required fresher tires to feel the confidence in the car. Time wise, it could be worth about .3-.5 on the 30 second course. Not much changes to the car surprisingly, just a minor shock change to the front and it was handling as anticipated. Also thanks to Scargoes for making a class happen with his co driver so we didn't have to run in bump class.
ESP 2017 Camaro Hoosier A7 Fontana Pro Solo Jeff
ESP 2017 Camaro Hoosier A7 Fontana Pro Solo Nicole
Crows Landing Tour, we had no class unfortunately. Ended up splitting up to run in SM and SSM since it was a 90 degree weekend. We acquired 335's and decided to test them at this event, so we didn't have any surprises for Spring Nationals. 335's over 20ish run 315's on a modified test course showed to be .4-.5 sec faster on the 30 second course.
With all this potential speed possibly found and not having your own class to run in, it is really hard on me and making me bench race all the time. I just want to run against like cars! :(
ESP 2017 Camaro Hoosier A7 335 Crows Tour Saturday Jeff
ESP 2017 Camaro Hoosier A7 315 Crows Tour Sunday Jeff
Jeff Wong
ESP Camaro
jwisjw is offline   Reply With Quote
Old 05-21-2019, 10:47 PM   #338
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
Not exactly autocross but autocross related... The Lone Pine Time Trials.
This was my best clean run on Sunday and got me into 2nd place in the overall pax results.
https://youtu.be/YuzkqtYzllI
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 06-17-2019, 01:09 PM   #339
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
Here's a PDR video of a ZL1 1LE going around an autox course pretty quickly. Won Pro PAX using the CAM-C index. The car is also SS legal, and would have won with the SS index also-
Only mods are 18" wheels, Borla catback, and 315/335 BFG Rival-S 1.5.
rotis is offline   Reply With Quote
Old 06-17-2019, 11:25 PM   #340
Scargoes
Scargoes's Avatar
A little late but here is the video from my quickest run on June 2nd.
Old 06-28-2019, 08:13 PM   #341
1LE76G
Drives: 2017 SS 1LE
What an awesome location!
1LE76G is offline   Reply With Quote
Old 07-30-2019, 10:19 AM   #342
ABQautoxer
ABQautoxer's Avatar
Drives: 2019 ZL1
I'm new here but recognize some names as I'm not new to autox. I got my ZL1 A10 a month ago and finally got to autox it. Wheels/tires and an alignment is all I've done so far and the car is fun but needs some help on entry understeer. Fun car and the power is much more manageable than the C7Z's I've tried. More to come though this is just a fun, lite CAMC car.
Outside cam:
Inside cam:
ABQautoxer is offline   Reply With Quote
Old 07-30-2019, 11:38 AM   #343
kjchristopher
Drives: 911SC
Welcome to the fold, Tom.
kjchristopher is offline   Reply With Quote
Old 07-31-2019, 08:57 AM   #344
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
For those of you that auto-x your SS 1LE's I'm curious:
- If you're running a front bar, specifically the Hotchkiss FSB what setting do you have it on? I'm currently on the stiffest setting.
- For those on a 305/30/19 square RE71R what pressures are you running, currently I'm at 34F and 32R, tire pyro data shows the tires to be fairly happy and the sidewalls seem to hold up decently.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 08-01-2019, 07:46 PM   #345
ony1265
Drives: '17 Krypton 1LE
When you installed your FSB, did you end up with uneven ride height in the front? Mine is off slightly and I don't remember it being off before the install. However disconnecting the FSB didn't really make any difference.
ony1265 is offline   Reply With Quote
Old 08-02-2019, 09:41 AM   #346
ABQautoxer
ABQautoxer's Avatar
Drives: 2019 ZL1
Thanks KJ.
While not an SS1LE, the tire pressures would vary based on your tire, suspension and alignment settings. If as delivered (not maxed out front camber and rear toe settings conservative) RE71R, 34 definitely in the ballpark.
Old 08-02-2019, 10:24 AM   #347
94boosted
94boosted's Avatar
Definitely doesn't appear to be uneven. I made sure to install my bar on a perfectly level 4 post hoist and used adjustable endlinks to make sure there was no pre-load.
2017 - SS 1LE
Old 08-05-2019, 02:32 PM   #348
ony1265
I measured the ride height of a couple 1LE's that came out to our local this past weekend, they were all over the place. Thinking it is just in my head, though after installing adj endlinks the weekend before mine has gotten a lot better.
Old 09-16-2019, 06:38 PM   #349
jwisjw
Just a heads up for you So Cal guys, there was a new venue that the San Diego SCCA region test ran at Lake Elsinore Storm Stadium. Its a relatively small lot but the grip feels pretty amazing for smooth asphalt. Given how easy it is on tires relative to grip, the value is really high compared to other sites like Qualcomm Stadium or Fontana Speedway.
ESP 2017 Camaro Hoosier A7 Lake Elsinore SD Practice Jeff
ESP 2017 Camaro Hoosier A7 Lake Elsinore SD Practice Nicole
Hopefully he neighbors won't complain too much and enjoy the sweet motorsports noises... We shall see.
Jeff Wong
ESP Camaro
Old 10-16-2019, 09:31 PM   #350
ABQautoxer
ABQautoxer's Avatar
Drives: 2019 ZL1
Finally got a 32 runs now on the Vorshlag camber plates so I could bring my front camber up to -3.2. I set the rear toe to Performance handout levels versus the 1/8" total in I was trying and this woke up the car a bit. I think I need to add a bit more front wheel rate so I'm going to try a larger FSB. This particular course was quite a bit faster than a typical one for this lot so I did better than I had with the car thus far:
