#337 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
![]() From what you describe, I suspect you engage brakes way too much on corner entry, which is not really producing trail braking per se, but massive amount of understeer, with the fronts sliding, especially with steering lock being added on. Then, when the car slows down closer to the apex and the fronts finally REGAIN GRIP, the rears get violently loose. This is a classic case of snap oversteer. Often times, the initial understeer puts a driver to sleep, until the fronts regain traction. This is also a classic situation in the wet. So...watch for understeer, as it is not always a benign thing and is capable of causing some truly spectacular wrecks... Cheers! |
#338 | |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
I'm pretty certain it's not understeer (massive or otherwise). At my last track day two weeks ago at VIR I finally entered T1 with a few mph too many under trail braking, asked too much from the front tires, and had the car understeer. I simply opened the wheel a little (still under braking) so the ratio of lateral grip request was lower. Blew the racing line but easily, but had room to keep the car on the asphalt and kept the rear end planted. Normally under trail braking with the extra weight on the front and the car and the speed in check, the front tires have extra grip and the car pivots amazingly well (on a dime in the best examples), and smoothly (not violently). But I also notice that I seem to sometimes get a little bit of extra pivot (yaw) when I release the last bit of brake pedal, near the apex. Normally it's fine and the back end stays under control behind me without ECS intervening. Every once in a while, though, this extra pivot winds up being too much for the rear traction and back end will start to step out. The PDR data on PI Toolbox seems to suggest the extra yaw on brake release is more pronounced when the brake pedal is released (too) quickly. In the example where I had the back end step out while trail braking into turn 4, I released the last 18% of pedal considerably faster than what I had done up to that point and the yaw rate during that time climbed from 34% to 38% without any additional steering input, and this immediately preceded the rear losing traction. I would have thought that at that moment the weight transfer rearward would tend to stop any rotation immediately and perhaps initiate understeer, but clearly that's not what is happening. |
#339 | |
And ESC let's you exceed limits until you exceed the ESC. Solution? Move up to PTM Race and assume direct control of yaw, based on what the car is ACTUALLY doing vs what ESC is preventing the car from doing due to your overdriving (meaning: you don't feel what the car is doing balance wise, as ESC is masking the exceeded limits, until its own corrective limits are exceeded).I can tell you without a shadow of a doubt, that the car feels VERY different balance wise between Sport1 and Race. It is capable of very fast laps under BOTH settings, but it requires an adjustment from a driver. In my strictly personal opinion, the car is clearly safer in Sport1, but not necessarily easier to drive fast, as its feedback is muted by ESC (as one would fully expect). Hope this makes sense. Cheers and have fun! |
#340 | |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Lately I have started switching to Sport 2 (from all off or Race) on hot days during the session whenever the tires start to get hot/greasy and slide more. I can hear the exhaust note change when Sport 2 is intervening most of the time but I usually can't tell when Race is intervening without reviewing the PDR video afterwards so I prefer Sport 2 in that situation plus it was designed for use on hot tires. I have also been experimenting with purposely inducing oversteer with abrupt throttle in slow low risk corners while in Sport 2 to rotate the car for a moment before PTM stops the slide but I need to compare data to see if there is actually any advantage from this. |
#341 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Fully agree with your comments here. I love the feel of the car in Race. Breakaway at the limits is progressive and communicative. Gives you plenty of heads up in most cases so you can counter steer or use the pedals to manage the weight transfer.
I usually stay in Race even with hot tires. It becomes more of a handful and I know Sport2 would be faster. I just like to slide and enjoy the Alpha chassis balance and rigidity. |
#342 |
![]() Drives: 2022 ZL1 1LE Join Date: Feb 2022
Thank you to all that answered. Unfortunately, your suggestions did not seem to work on my car so I'll be headed to dealer to try to resolve. Probably user error!
#343 |
Just to make sure: have you gone to the very first page of this thread? It has all the info in one single post and I have kept it pretty current. You may wish to read it and re read it again in necesssary and then practice on your car when stationary. Why? Because the chance is, that a dealer will be clueless - unfortunately. Not a dig towards hard working folks (some friends work that profession), but these cars are pretty rare and dealers do not get a chance to drive them at all, never mind setting them up. Also, maybe find some Youtube vids on how to set up PTM etc for visuals if you really have trouble. Fingers crossed for y either way. Cheers!
#344 | |
#345 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Wow until I read this thread I didn't realize how much traction control is part of the RACE setting in PTM. I had thought the eLSD was helping but no throttle management with some Stabilitrak.
I have been fighting the PTM. You can indeed mash the throttle when you don't think you can in RACE as it turns out. I have been modulating the throttle more then I have needed to, like at turn 19 at COTA which is easy to otherwise dangerously oversteer on throttle. I have just floored it on some occasions at the apex of turn 19 and thought the car was down on power because the tail didn't get loose.. Focusing on slip angles, opening up your hands is the right way to leverage the PTM in RACE. Aim for smooth, consistent racing line and let the car handle the throttle for the most part. The only exception is when the tires are close to "done" or they are cold. In those conditions sport 1/2 could be better if you are working with the PTM. While that is safer I like ability to rotate the car with the throttle a bit more. Now that I understand better the PTM's intentions, it will be interesting next time.
#346 | |
But, it all depends on how much speed one carries into a corner and especially in a mid corner phase. Cheers! |
#347 | |
#348 |
Got ya! Just in case you have not read the very first post (since updated with all subsequent comments etc), check out the GM engineer's discussion about PTM, which I have included there. Very good stuff. Cheers and happy motoring!
#349 |
![]() Drives: 2022 Camaro 1SS 1LE Join Date: Sep 2022
Kudos to the author, this is such a great guidance, collected in one place.
I'm doing autocross, ~1 minute for a single lap, and PTM Sport 1 is my choice. |
#350 | |
If the car starts to feel a bit too tight during rotations, don't hesitate to try Race (after you get comfy with the balance overall). Cheers and have fun in your competitions! |
