10-30-2023, 02:43 AM | #337 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Glad your ok! Tbh, I really only get on camaro5 anymore to see updates on members cars here in the journals page, with yours being one of my favorites!
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
10-30-2023, 07:57 AM | #338 |
Drives: 2023 2SS 1LE Join Date: May 2014
Glad to hear you are OK. Scary story indeed.
If you follow your doctor's orders the same way you document your builds, you will be in excellent shape soon. |
10-31-2023, 04:37 AM | #339 |
Awesome & thank you!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-31-2023, 04:45 AM | #340 |
Thank you Sir! Looking forward to seeing your new ride this next year!
10-31-2023, 08:27 AM | #341 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
its them damn chips striking again...
Jokes aside, glad to hear that you're ok. Gotta be a scary feeling.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
11-02-2023, 06:21 AM | #342 |
No doubt right!! lol
Thank you sir! And yes it was for sure!
12-23-2023, 05:30 AM | #343 |
Not much been going on with the car here lately. It's been at GPI for a bit getting the kinks worked out with changing over to Holley Dominator ECU. While they were getting it dialed in the alternator decided it would only work intermittently then just quit working all together. That was causing some fueling issues to pop up. The alternator was sent out for repair and thats all fixed now.
There were signs that something was going on with the charging system prior to taking it to GPI. When I switched over to the lightweight battery it started out working just fine. Several road drives no issues. Then on the way to work one day it just quit charging. I swapped it back over to the OEM battery and all was well. Timing of that made me think it was related to the lithium battery . Anyways, now the Gateway that allows the Dominator to communicate with the GM can bus system is having issues. So the Gateway is on the way back to the mfg for inspection/repair. Hoping thats a quick turnaround so I can get the car back home soon. I've been eyeing the Holley Pro Dash display and thinking of swapping over to that before long. I do have a slot reserved in March to get a 10pt 8.50 cert cage put in, so I might wait till after thats all done since the dash has to come out for the cage install.
12-28-2023, 12:44 AM | #344 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Hey buddy how's your health doing?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
12-28-2023, 05:29 AM | #345 |
I've been doing good & thanks for asking! I have been walking a lot and with it getting cold I actually bought a treadmill so I don't stop that trend. I tried walking loops in Walmart & Lowes but with the holidays they were just too crowded for that. Now anytime I get bored I can hop on it and walk for a bit.
Hope all is well with you & your family as well!
12-30-2023, 04:02 AM | #346 | |
01-03-2024, 06:25 AM | #347 | |
Thank you sir!
01-13-2024, 06:27 AM | #348 |
GPI called and said the car is ready so went and picked it up Thursday morning.
Everything is working like it should and boy it sure felt good driving it around before putting on the trailer. Now to start working on the winter mods.
01-14-2024, 07:52 PM | #349 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Nice, I wish I was in driving distance I would have them do some work. I like your tow rig as well, I really need to find a nice car trailer, i do want an aluminum one.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
01-15-2024, 06:58 AM | #350 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Glad to see you back in business!
What are the winter mods?
