#337 | |
I daily ST-43 and they squeak as expected. Need a good stop before they're at temperature. ST-47 would suck on the street. 2c
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
#338 | |
![]() Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
Used titanium shims coated with ceramic brake lube, for extra protection, worked great, even though the temperature was in the low 90s |
#339 |
![]() Drives: 2017 Chevy Camaro 1LE & 2023 1LE Join Date: Apr 2021
Pad experience needed
Well I do have questions for the experienced, I’m needing a new set of pads on my ‘17 1LE, I saw Matt mention the Raybestos. I once used a set on my racecar and they were phenomenal! However, due to the dust issue on OEM pads, I’m looking for a set that I can use on the street also without worrying about fade on track. (I know it’s a tall order). I’m happy with the track manners of OE pads actually and aren’t an issue on the street, just dust I’m tired of constantly cleaning up. I know hawk HPS+ Probably isn’t up to track work. (I smoked a new set once in short order) any feedback on a good all rounder w/o immense dust. Trade off is question, confidence for track, ability on street w/o squealing to put heat in.
BTW, using OE Goodyears |
#340 |
Oh yea, saw some talk about titanium shims? Where can those be purchased?
#341 |
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
Ken at KBS
#342 |
Thanks guys, went to KNS and bought a bunch of stuff! Nice to see a vendor that’s a candy store!
#343 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have a set of hawk dtc60s gonna put on for next event wish me luck!
#344 |
Well, I did what I thought I’d have to do and just get a separate street & track pads... Just can’t go cheap like I was hoping to... I got a set of Hawk ceramics for the street, hopefully will take care of the nasty dusting issue with adequate street performance. Haven’t decided on the Hawk DTC60’s or the Raybestos. Any thoughts from the group on mixing manufacturers pads on same rotors? I’m used to one type on the racecar not switching around for a mixed street and occasional track time...
Input would be appreciated. |
#345 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Haw states specifically you can use any of their compounds on the same rotor without bedding EXCEPT ceramic. I was running the HPS5 and DTC60 combo for a while. But honestly, now I stay with the OEM pad. With fresh fluid, I haven't faded a pad yet.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#346 |
Of course, my luck!
#347 |
![]() Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
how may days do you get from the stock pads and where have you found the best deal? thanks!
#348 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
I get most stuff from Cargurus and the more i buy the better discounts they offer
#349 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
Thanks for the pad wear estimates TrackClub!! Very helpful for planning how to get the most out of your pads while still remaining safe.
#350 | |
Regardless, i always check tires, rotors, pads and under the car for leaks after EACH run. Plus oil level and lug nuts torque at lunch after cool down. It is a good habit to develop and stick to. Cheers! |
