Old 10-06-2020, 11:14 AM   #337
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
With that combo you should be in the 6.60s at 108 or so 1/8 mile. My NA C7 runs almost that quick with just E85, headers and drag radials (7.23@99 w/1.63 60ft) Are you running drag radials, if not get a set. Who is tuning your car and how much power are you making? Something seems wrong. What happened to your 60' on that pass as a previous slip you were cutting 1.54 60' times.
He is in Texas so it could still be pretty hot down there. Aside from that comparing different tracks is like comparing different dynos without all the data...such as DA, humidity, water grains...etc.
Old 10-06-2020, 09:09 PM   #338
Flexhorn
Drives: A10 ZL1
Yes I’m running Toyo888’s. I’m at 824 RWHP right now. One thing I think that keeps messing me up is that I can’t seem to roll out of my line lock so I might still have some water on my tires. I feel it spinning a little at take off and through some of the gears.
Flexhorn is offline   Reply With Quote
Old 10-08-2020, 02:40 PM   #339
laynlo15
Drives: 2022 Lt1 A10
King is right but if your spinning your not putting down all the HP you are making. Even in the heat and da you should be running 1/2 second faster then that if it hooks. I'm not gigging you at all as I used to work for Magnuson s I still want you to run as fast as possible. Get some drag radials and that 1.79 60ft will get you back to that 1.54 60ft you had before. Go get um
Old 10-08-2020, 09:11 PM   #340
Flexhorn
Drives: A10 ZL1
The Toyo888R’s are DR’s
Old 10-29-2020, 10:43 AM   #341
WhitesnakeSS
WhitesnakeSS's Avatar
Drives: 2018 Camaro SS
Holly Springs Motorsports
Holly Springs, MS.
10/18/2020
Car/Engine: 2018 2SS A8
Top Thirty Class: Bolt-Ons *without* Internal Engine Modifications
Tires used on the pass: Nitto 555G2 Summer Tires
Performance Mods (if any): CAI, LT'S, Vellosa ram air, LT2 ported intake, Mamo ported 87mm TB, MBRP axle back with cats. E85 sensor, GPI tune.
R/T: .750
60': 1.9555
330': 5.162
660': 7.744
660' 96.07
Temp was cooler than normal that day. Low 80's
Couldn't get any traction. Track was fair but the Nitto G2 did nothing no matter how I tried. I rolled into the throttle multiple ways. When ever I full throttled her she would lose it. Low end is a MONSTER.
Ended up just leaving all the nannies on and rolled into the throttle that way with the TC light flashing the whole time and the CPU pulling power. Felt like a slug but got the best time I could muster on the day.
Will get some drag radials for next year and get some better numbers. Should be 7.30 or better.
GPI ported LT2 intake
Kooks 1 7/8 long tubes high flow cats
Mamo ported 87mm TB
CAI cold air box
Vellosa ram air
MBRP axle back
E85 Flex fuel sensor
Tuned by GPI
WhitesnakeSS is offline   Reply With Quote
Old 11-10-2020, 03:35 AM   #342
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Originally Posted by WhitesnakeSS View Post
Attachment 1048669
Holly Springs, MS.
10/18/2020
R/T: .750
60': 1.9555
330': 5.162
660': 7.744
660' 96.07
Not bad considering the 60’ my car went 7.75 @90 bone stock on the run flats
Now I have a very similar set up to you just instead of longtubes I have cat deletes, looks like if you were to cut a 1.70 60’ that would get you into the 7.3s. Do you have a trans tune?
Murder6.2 is offline   Reply With Quote
Old 11-11-2020, 12:41 AM   #343
WhitesnakeSS
Yes sir I had GPI tune it as well.
I ran 8.07 on run flats and a CAI box.
I could always hook fairly well before but now the low end is unreal. Heck a 40mph roll is a adventure. When you throtte that boy it gets all over the road.
I can't tell much about the trans tune (don't think you can) but I have heard it's worth a few tenths in the 1/4 with it.
Yes I'm shooting for 7:30-40 with a drag radial.
It will be next year before I can get that time but that is my goal.
Mamo ported 87mm TB
CAI cold air box
Vellosa ram air
MBRP axle back
Tuned by GPI
Old 11-11-2020, 10:31 AM   #344
Flexhorn
Drives: A10 ZL1
I just can’t seem to get better than a 1.7 60’. I know I had one slip showing a 1.5 but I think that was a fluke bc I staged beyond the line but they went ahead and let me make my pass. I’m running 22 in my rear DR Toyo’s. Should I drop it lower to 18 maybe?
Old 11-11-2020, 10:46 AM   #345
KingLT1
KingLT1's Avatar
The problem with going lower on a hard sidewall R compound tire is that it might hook better right off the line and then break loose as you get out a bit. I forget the term off the top of my head for it...Anyway, MT Street R like lower pressure. That is what you need for best 60ft's at the track on a "streetable" tire.
Old 12-15-2020, 12:37 AM   #346
WhitesnakeSS
Is the fast list not updated anymore?
Mamo ported 87mm TB
CAI cold air box
Vellosa ram air
MBRP axle back
Tuned by GPI
Old 12-17-2020, 10:41 AM   #347
laynlo15
Hasn't been updated since about March.
Old 02-07-2021, 07:09 AM   #348
Yosh6
Yosh6's Avatar
Drives: 2024 Toyota Camry XSE
Tires used on the pass: Micky 305/45R-17 DR's & M&H 4.5 radial skinnies
Performance Mods (if any):CAI, PTB, PIM, LT, E85 Tune, Gears, WR, Converter
Category submitted for:#3 Camaro SS 2016+ LT-1 Bolt On's NO Internal Mod's (Stock Displacement)
R/T.......... 0.554
60'............. 1.492
330'........... 4.398
660'........... 6.819
660’ mph... 101.14
Name of the track: Houston Raceway Park
Date of pass: 1-31-2021
Weather conditions: 63 degrees 15 MPH Headwind
2016 1SS - Bought: 8/2017 Sold: 12/2023
Yosh6 is offline   Reply With Quote
Old 02-07-2021, 09:07 AM   #349
laynlo15
Good pass Yosh.
Old 02-24-2021, 10:32 AM   #350
Merc
In The Circle
Merc's Avatar
1/8 mile screenshots have been updated. Big THX! to Danhar for the updates to the lists.
