Old 11-28-2021, 05:59 PM   #323
laynlo15
Drives: 2022 Lt1 A10
I broke one of the Gforce aluminum shafts on my Magnuson 2650 Camaro on the first pass at the LS Fest 2019. Pretty disappointing so ditched that and went to a DSS Chromoly and never had an issue after that.
Old 11-28-2021, 06:16 PM   #324
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I thought that was M6 version? Not sure the auto one fits since the ZL1 A10 is probably a different length than the SS A8?
I was under the impression that the A10 and A8 are the same length and the driveshaft interchanges. You just have to make sure you buy a shaft from a A10 if you have a A8...and M6 Zl1 for M6 SS.
https://gmauthority.com/blog/2018/08...#ixzz5P1ApwACZ
Old 01-10-2022, 12:19 PM   #325
cjperformance
cjperformance's Avatar
This thing is too gorgeous to mount underneath the car.
Wondering how it might look installed sticking out of the hood instead?
Maybe a see-through driveshaft tunnel?
Hold it out the window, joust-style?
Old 01-10-2022, 07:27 PM   #326
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Old 01-12-2022, 02:41 PM   #327
Trochoidal
Drives: 2017 Camaro 2SS A8
That’s a nice upgrade. I need to get one of these too. How long did it take for them to get this to you after you placed the order?
Old 01-12-2022, 03:32 PM   #328
cjperformance
About 5 weeks or so.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 03-10-2022, 05:30 PM   #329
cjperformance
Ok... converter and carbon fiber driveshaft are installed.
Fun drive home. But didn't floor it until I can do some real logging and adjusting. But wow. It's going to be a different beast now I can tell.
Will post more info as I collect and adjust. Going to be snow this weekend, so probably won't get anything meaningful for several days.
Old 03-11-2022, 09:15 AM   #330
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
That converter should make a big difference in the way it drives, bet it spools up quicker now and hits harder.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Forged internals
BTR stage 3 cam - Circle Stage 3 trans
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 03-11-2022, 11:59 AM   #331
cjperformance
Yeah, it sure does so far. I was pretty timid with it on the way home. I think a WOT hit with DRs is going to be a fun ride.
I'm going to dial back the shift points in the tcm tune close to what they were originally and work my way back up incrementally so I dont overrev on the WOT shifts. I'm not sure what the difference in tc slip at WOT will be yet.
With stock converter theres about a 200-300 rpm difference between trans input and engine rpm. Just not sure what to expect with this converter, and it already goes to 6800 rpm for a shift with the current tune. That's already pretty close to fuel cutoff rpm.
Old 03-11-2022, 12:58 PM   #332
cjperformance
Oh, and after I get WOT shift tuned, then I'll probably start having the TC Clutch lock at lower mph too. I had applied a tune that keeps it from locking until 60mph in 8th, but I'd like to drop that to lock @ 30mph+ in 5?, 6, 7, 8.
Keep the rpms down during casual cruising, and keep the trans temp down too.
Pretty sure I've got a good bead on all the tables to modify for all of this. I can be more detailed if anyone is interested in exactly what I'm changing.
Old 03-12-2022, 06:08 AM   #333
wnta1ss
Drives: 2017 Camaro 1SS
Agree, should be WAY into the 10s with your setup on DRs.
Old 03-12-2022, 07:12 AM   #334
cjperformance
I dont have the DRs yet, but as soon as i am comfortable with the trans tune, ill make a pass in the 1/4. Im expecting a **** show on the nt05s unless they glue the heck out of the track.
Thinking of getting a 17" wheel setup on back for the track, and keeping the 20s for street.
Old 03-12-2022, 07:58 AM   #335
Joshinator99
Moderator
Joshinator99's Avatar
I found the 20” DRs would grip at a fully prepped track until somewhere in the 650 WHP range or so. Once I did my next round of upgrades it just wasn’t happening. I should have tried a second gear launch IMO, that probably would have helped a ton.
Old 03-12-2022, 09:19 AM   #336
cjperformance
Good info. Thank you. I would like to think I'm somewhere over 600 WHP after the trans tune... Not that the trans tune makes a big difference on launch though for me You PD guys have more oomph down low. I'm just assuming somewhere between 580 and 620 based on online 1/4 mile calculators and correlating that with cyl airmass and airflow lb/min. Big variable is timing, but I should be in the right neighborhood.
With the trans tune and increased rpm and addl boost from that rpm increase, peak airflow lbs/min went from high 60s to high 70s... so if you believe the 9-10hp per 1lb airflow, then I should have 90 to 100 more crank hp at least at the top end for my next run.
I'll just have to try with NT05s first mainly because DRs wouldn't even arrive in time before first opportunity to run.
