#323 | |
![]() Drives: 2018 Camaro RS 3.6 A8 Join Date: Jun 2018
I have a 2018 RS with 11K miles and no shudder. Is it worth getting the TSB flush as preventative maintenance? I know I'll have to pay for it but why wait until the TC is damaged? |
#324 |
![]() Drives: 2023 SGM 1SS Join Date: Dec 2017
It's the latest version, 8.7 I believe. No CELs and it doesn't seem to drain the battery as the car sits for days without being driven. My wife got it direct from Range and put it under the Christmas tree this past year.
#325 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
I have my Range on a switch. They say longer than a few days and it start draining the battery.
#326 |
![]() Drives: 2016 Camaro RS, 2LT Join Date: Aug 2010
I just brought my 2016 RS A8 in for the shudder problem at 30K miles, had it bad. I'll post results in about a week or so. The service guy said no camaros serviced with the flush have returned, so I'm hopeful. He did say it is covered by the 5-yr powertrain warranty. He also noted that it will be serviced for a transmission turbine shaft service bulletin (not recall), news to me, no postcard notification?
Update: Had 3-way flush done on 4-2-19. It was interesting to watch as my dash cam activates at startup, so I could watch activity in shop and the test drive after service. Invoice ticket advised to drive at least 500 miles. It felt much better on the short ride home, but I'll do another update after I've driven it for 100 miles or so, and again after the recommended 500 miles. 2nd Update: I am now 500+ miles (4-18-19) after the triple flush "fix" and the A8 is shifting fine with virtually no shudder issues, so I am hopeful it will continue to operate smoothly. Last edited by wjmeyer; 04-18-2019 at 01:41 PM. Reason: Update |
#327 |
![]() ![]() ![]() Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
Follow up to my request for picoscope results in post #316 of this thread, scheduled my shudder service yesterday, the service person said that they do require a road test to verify the issue, but only break out the scope if it isn't clearly there. They did say I could be the driver thankfully.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
#328 | |
![]() Drives: 2017 Camaro SS Join Date: Nov 2018
Kevin
Luceo Non Uro |
#329 |
![]() Drives: 2019 Camaro 2SS Join Date: Mar 2019
In the market for a 6th Gen Camaro...Now I'm bummed out. This thread is unbelievably depressing.
Get a Mustang? Manual transmission? |
#330 | |
STD free
Drives: 2018 Bright Yellow LGX M6 RS NPP Join Date: Nov 2017
Thanks to this forum,this major issue is the reason I never considered an A8. I looked for and found an V-6 M6 to my liking. I feel for everyone affected. |
#331 | |
![]() You could go with a manual but the early reports from people that have had the NEW flush done is that it fixed the shudder issue.
Kevin
Luceo Non Uro |
#332 |
Thank you Al Oppenheiser!
#333 |
STD free
Yes,"early reports" being less than a thousand miles. In most cases,a few hundred. Means little. Give it say,5k miles and if it's gone away,halleluah for them!
#334 | |
![]() Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
I will preface this by saying my shudder is very very light compared to some. But it doesn't really bother me that much. It only happens for a split second every 10 miles or so, and only ever on the highway. That being said the dealer diagnosed it using a picoscope, and as soon as their new trans flush machine is in, i'll be getting the new mobil fluid. Go figure their machine breaks the day before I get it diagnosed. Just my luck ![]() If you are worried about it, just buy a stick. The Camaro is so much better than the stang in just about every single way. As the test driver of Motor Trend said after driving the GT and SS around the streets of willow.... "There's about 4000 years of evolution separating the two" |
#335 |
![]() Drives: 2017 2SS A8 Hyper Blue Join Date: Nov 2011
My 17 SS A8 has been flawless for first 5200 miles. Started shuddering like crazy right after the 5,200 miles Hope to get it to the dealer next week... interesting that my 15 Corvette started shuddering right at 5,000 miles though no where as bad as the Camaro. They replaced the converter in the Vette 2 years ago, all has been well.
#336 | |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
It's a bummer that there is this issue, however, I love this car so much regardless, if it comes down to it and I get this issue again after the powertrain warranty is up, I'll just go with an aftermarket TC and have a tune done. Possibly have the transmission looked at, at the same time if need be. Like people have said before, I'd much rather deal with TC issues, possibly transmission issue, than an engine issue.
