08-29-2019, 07:53 AM | #3319 | |
Drives: SEARCHING Join Date: Apr 2010
08-29-2019, 08:03 AM | #3320 | |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
08-29-2019, 08:04 AM | #3321 |
Friend has an AMG Merc with a 2.0l turbo - just a tune and it's a monster once spooled.
08-29-2019, 08:08 AM | #3322 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Turbo engines are great for folks who want to modify their engines for more power. You can tune the blow off valve or waste gate to increase boost. So with just a tune, and sometimes a few boltons, you can add a ton of additional power with minimal effort and cost. I love that aspect of a 2.0L (or any displacement) turbo. Great for shadetree mechanics to modifiy thier toy. Definately fun stuff. The only issue is you tend to add more turbo-lag with the additional boost, and that makes the throttle more non-linear. You have to get used to when/where the boost kicks in. Many a folk jacked the curb leaving a cars and coffee when the boost kicks in. I also like boost when trying to make huge HP numbers. How can you get 1,000 HP with displacement alone? The engine would be too big and heavy. At some point in the HP wars, boost makes sense. But, you give up that great throttle response that you get with a properly designed N/A engine. Again, everything has it's advantages and disadvantages... |
08-29-2019, 08:14 AM | #3323 | |
Now, perhaps they could 180 the head, and put it on backwards, and that would put the valves and ports in the right place, but I belive that the exhaust ports in the valley of the V may need to be redesigned, for the turbo placement. There isn't much room in the vally for two turbos, and I have heard that the exhaust routing is tricky because of the lack of room, and how the turbos get laid into the valley. Of course, if you turn the head around, you have to have a differnt camshaft (as the lobes will have to be switched around), but that's no big deal. And I don't think the intake side would need too much reworking. But, even the bigger displacement alone means the heads will have to accomodate a larger bore size, which means a different head. |
08-29-2019, 08:19 AM | #3324 |
The rumors are swirling the last few days. Here is an article from yesterday saying that the Z06 will be an 5.5L FPC N/A for around 600HP.
https://news.yahoo.com/know-flat-pla...171800233.html 5.5L and FPC will be a challenge for sure. But, the design would allow for the Z06 to return to it's N/A roots. ALSO, since they extended the life of the 6th gen by two years, that leaves plenty of time for this new Z06 engine to show up in a Z/28 camaro. If it will fit, that is. But since the new C8 has an LT2 and will have a 5.5 DOHC later, then perhaps they are of comperable size... |
08-29-2019, 08:20 AM | #3325 | |
08-29-2019, 08:30 AM | #3326 | |
I think the real solution to turbo-lag is an electric boost device powered by a 48 volt semi-hybrid system. Or even just using the 48-volt system to add more torque to the crankshaft directly until the turbo spools up. They have a device that goes in between the engine and transmission to add torque to the crankshaft directly using the 48-volt power. The computer can run this so the handoff is seamless. This will give N/A like throttle response in theory. And it won't drain the batteries because it will only add power for a short burst under certain circumstances. |
08-29-2019, 08:45 AM | #3327 | ||
Drives: 21 Bronco Join Date: Jun 2012
displacement doesn't seem to matter as much when your throwing a pair of turbos on it. I mean the Ferrari 488 engine makes 661 at 8K RPM and 561 lb/ft of torque at 3K. Thats a twin turbo 3.9L V8. That engine seems to have plenty of low down torque while screaming in the upper RPMs. I don't know if any of that makes any sense but thats my guess lol. What it probably is though is because that is what the competition has. All the other ME cars have a DOHC TT set up. Quote:
08-29-2019, 08:57 AM | #3328 | |
08-29-2019, 08:57 AM | #3329 | |
Also, an undersquare design is also better for boost, and an oversquare design is better for high RPMs. But, displacement still matters, as the more displacement with less boost gives better throttle response in comparsion to low displacment with high boost. It's why folks like AMG use pretty large displacment with a touch of boost. But now, HP numbers are so high, you are going to need both large displacment AND big boost. No way around it for high HP, and you probably will see high RPMs too. Again, this will introduce more turbo-lag, but if you want insane HP numbers, compromises have to be made. So, the 488 engine has pretty big displacement at 3.9L V8, and high RPM's at 8k RPMs, and I'm guessing that the boost is pretty big too. It's the everything and the kitchen sink approach. |
08-29-2019, 08:59 AM | #3330 | |
08-29-2019, 09:13 AM | #3331 | |
Even though the Voodoo has a redline of 8,250, peak power is at 7,500 for 526 HP. If you kept the same displacment and increased peak power to 8,500 RPM's (assming you can keep the same torque number), it would put out a theoretical 596 HP. Pretty close to the rumored 600 HP. And it's theoretically possible in accordance with the article I linked becasue it says that the redline was limited to 8,600 due to the transmission. Here's another theoretical example. Suppose they went with peak power at 7,500 like the Voodoo, but used 5.5L. That would put out a theoretical 556 HP. Not enough to make it to 600 HP without reving higher. So, who knows... What I do know, is that if this is going to be N/A and 600 or so HP, it will have to rev pretty high, and produce peak power above 8,000 or more RPMs. This will make the engine lack the low end in comparison to the LT2, but for a track car (road course), high RPM N/A makes sense. But these examples show that they can't really go with a significantly lower displacement than the Voodoo, or it would have to rev higher than the transmisssion can take. It will have to be at least 5.0L, but more than likely a bit more. I guess 5.5L is still on the table... |
08-29-2019, 09:14 AM | #3332 | |
yeah just looking at the list of ME cars if they are V-8s they seem to be around 4.0L of displacement |
