08-28-2019, 10:38 AM | #3305 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
C8
The rumors change pretty often though, maybe the NA version of the dohc TT going on the zr1 will be an option for the base car along side the lt2 and the z06 will be a lesser version of the zr1 TT dohc. Or maybe it'll be something totally different lol.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
08-28-2019, 10:50 AM | #3306 | |
Drives: E92 BMW M3 Join Date: Oct 2012
Who knows, GM has options with these different engines and variants. They can do some interesting stuff, and mid-engine is brand new so screw tradition at this point haha.
J-Rod Built and Matt@FSP Tuned |
08-28-2019, 11:01 AM | #3307 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Also, it is near impossible to not have turbo-lag at all. In order for a turbo to work, you have to have exhaust pressure. Simply closing the throttle (like when you are in a turn) will put exhaust pressure to such low levels, you are not going to be able to produce boost. But that is a good thing because why would you want boost with the throttle closed? But, once you open the throttle, there is a lag to spin up the turbo, and hence, turbo-lag. Currently, they are using turbos that spin up quickly, and then using a waste-gate to ensure there isn't too much boost at higher RPMs and open throttle. This makes turbo-lag hardly noticable under most normal driving conditions, but it's still there, and you WILL feel it when driving spirited or on a road course exiting the turns. AND, you saccrifice power in the upper RPM range due to the way you have to tune the intake runners, cam shaft profile, and other things (like how much undersquare you design the engine with). The only way I see it so far, is to use an electric boost assist before the turbo spins up. You can do that if you have a 48volt system, so this technology is coming. The electric turbo can run from the 48volt system and keep boost up while in the turn, then the mechanical boost kicks in as you exit the turn and begin to apply throttle. The handoff can be controlled by computer to keep things linear. That way the engine can be tuned for higher RPM power, and then just force the issue with the electric boost when needed. But, my original question remains. Can someone point out an engine with a super-flat and early torque curve that still produces peak HP higher in the RPM range? I can only find one or the other right now, but I am not too familiar with the exotics. |
08-28-2019, 11:29 AM | #3308 | ||
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
Zora will get the hybrid - Electric front wheel assisted to the Z06 TT DOHC V8 for ~900HP. This is be the way GM brings electric into the Corvette world. I'm happy to be wrong about either predictions, lol! Quote:
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
08-28-2019, 01:28 PM | #3309 | ||||||
Drives: 21 Bronco Join Date: Jun 2012
What He said ^ Quote:
And whatever powers them, I would bet the farm that they are both missiles lol. Those high po C8 variants are going to flat out fly |
08-28-2019, 01:40 PM | #3310 |
Yup - same engine family as Blackwing, but obviously different turbo layout as per the CAD drawing already posted. Block and head architecture will be identical, bore, stroke, cam profiles, valve sizing etc will all be optimized for the C8.
08-28-2019, 02:06 PM | #3311 |
The heads will have to be completely different since the Blackwing is reverse flow and the rumored C8 TT engine will be normal flow.
08-28-2019, 03:16 PM | #3312 |
Will wait and see - I don't see GM building two completely different sets of heads for the same engine family (AKA Blackwing Block)...they may have different flow rates, chamber sizes, valve, etc, but the overall architecture will most likely be the same.
08-28-2019, 07:42 PM | #3313 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
So what can a DOHC engine do that a pushrod engine can't do...besides rev higher? I have not seen any evidence of DOHC engines being superior. To me, some dude raved about "oh man this thing revs soo high" even as he was getting passed by other cars and everyone drank the Koolaid. Look at it like this, ZL1 top speed 202 (198 "officially"), Hellcat top speed 204 (some have hit 205), GT500 limited at 180. Look at the oil drinking problem the Voodoo engines have. BMW DOHC engines are terrible. All these supercars with DOHC engines constantly have enough issues and high maintenance costs that they would suck as a DD. The Mustang GT is faster than the Camaro SS but only after a mile and on a dried up river bed. So where has there been any evidence that DOHC engines are good? Even with the front engine design the Z06, ZR1, Viper, ZL1, etc have been beating much more expensive supercars with DOHC engines. So where is their advantage? They cost more, have more parts that can possible break, have no torque down low, higher maintenance, run hotter, are more prone to heat soak, are physically bigger and therefore are limited on displacement, the list goes on.
I'm not dishing on DOHC engines BTW. I just don't see how anyone can think they offer some advantage. Ok they rev high...so what advantage does that give when they still can't beat well built cars around a track? |
08-28-2019, 09:29 PM | #3314 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
DOHC engines have less moving parts than a pushrod although they are physically larger. DOHC engines give the ability for variable valve timing. This is one of the more important factors. DOHC engines can rev higher allowing for more hp (since hp is a factor of torque and rpms) This short article highlights some of the pros of each type: https://www.cjponyparts.com/resources/ohv-vs-ohc
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
08-28-2019, 10:30 PM | #3315 | |
I know the differences between the two engines and the benefits of both. I have multiple times on here outlined those benefits. But I'll bite anyway. While a DOHC setup can make more HP vs a pushrod engine at the same displacement, the drawback of the DOHC engine is it's physical size. Back in the early 2000s there were 2V engines that dwarfed big block pushrod engines by a lot. Therefore what a pushrod engine lacks when it is at the same displacement can more than be made up for due to the fact that you can shove more cubic inches in a smaller space. Even these days. Plus GM was able to build a 454 small block engine only a few years ago. Therefore the HP to displacement ratio is neutralized by the fact that there is only soo much space available in an engine compartment. Plus the fact that you have to rev the hell out of a DOHC engine the more HP it has means that it is not ideal for performance. As far as moving parts...well 32 valves vs 16 valves. 5 sprockets vs 2 sprockets. 4 cams vs 1 cam. Ok the pushrod has, well, pushrods. But the DOHC has more cam followers. The list goes on. So which engine has less moving parts? Restriction plates. Valve springs. So that wasn't a true statement at all. Again, you have to rev the hell out of a DOHC engine. Funny thing tho is that the Demon at 840/808 has more HP than anything Ford has made. The Redeye at 797 has more HP than the GT500. And I'd wager that the basic Hellcat makes more HP to the wheels than the GT500 will. So where is this HP advantage? VVT...nothing but a gimmick. End of the day the pushrod engines have been outperforming the DOHC engines by a long shot and pretty easily I might add. EVen if you argue that a DOHC engine makes more power up top, which engine makes more power thru most of it's power band? Ok so a Voodoo can rev to 8250. But it's power doesn't come on until sometime after 4K. A pushrod engine makes power from 2K to over 6K. What's the difference? Both engines have the same amount of power available for the same amount of RPMs. Coming out of a turn and nailing it, which is going to accelerate faster? The only way a DOHC engine would be able to keep up is if you kept the engine screaming at the top of it's lungs the entire time. Guess what that does. Drive train strain, engine strain, fuel consumption, oil consumption, excess heat, increased IATs, etc. And it offers no extra acceleration from what I've seen. Basically there is nothing to prove the superiority of a DOHC engine vs a pushrod engine. Fuel efficiency? Bullshit. Unless you keep it under 2K RPMs and gutless you ain't saving any gas. In fact I bet my 15 GT got worse MPGs than my ZL1 gets. Both engines has it's pros and cons. What the DOHC excels at (HP per cyl) is also where it sucks (limited space = limited displacement). It's pros are the pushrod's cons and the pushrod's pros are the DOHC's cons. And the fact that we are seeing the pushrod engines pushing way more HP safely and more efficiently than DOHC engines is a testament in itself. The 7.0 LS7 in the Z28 made 505 HP vs the 5.2 Voodoo's 526 HP. But which engine vibrated itself apart and drank oil like an alcoholic at an all inclusive? The 3rd Gen Coyote makes slightly more than the current LT1 but which one has been having issues? There is no evidence to prove that a DOHC engine outperforms pushrod engines when the pros of each engine are exploited. |
08-28-2019, 11:43 PM | #3316 | |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
It should also be noted that many OHV engines, including GM small block engines, have Variable Valve Timing. Actually, I’m hard pressed to think of any modern engine OHV or OHC that does not have VVT.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
08-29-2019, 07:11 AM | #3317 |
They have to be different. The path the intake and exhaust gasses take is switched. And you can't just make the intake the exhaust and the exhaust the intake because the intake valves are bigger. Plus the bore size will be bigger, location of the direct injection will be different, etc. The only thing that will be the same is the size and bolt pattern. And those might be different as well...
08-29-2019, 07:41 AM | #3318 | |
There are advantages and disadvantages to both the OHV and DOHC. The simplified equation for this is HP = RPM x Tq(at that RPM). The advantage of DOHC is the ability to rev higher, and therby create more torque by increasing RPMs. The disadvantage is it will be physically larger and heavier allowing for less displacement. The advantage of an OHV engine is it will be smaller and lighter, so you can have more displacment, which makes more HP through more torque. The disadvantage is that it can't rev as high. Is it a fair comparison to use HP/L at this point? That metric is pretending that each engine is the same displacement, which ARBITRARILLY takes away the OHV advantage, namely, more displacement. Why? OHV getgs more displacment in the real world. To limit the advantage of one engine over the other will give a biased result every time. That would be like me saying, hey, lets compare HP/RPM. How much HP per RPM does a DOHC engine make as compared to an OHV engine? It will always be less due to the less displacement. That is taking away the advantage of going to DOHC in the first place. It would be a biased result. In the real world, a DOHC engine can rev higher, so we shouldn't try to compare while limiting the RPMs. Nor should we compare the two by limiting the displacment advantage of the OHV engine. It doen't make sense (unless you are trying to make a bogus argument on purpose). Let's take it a step further. Say you are a Ford guy and HP/L is your favorite metric. Well, the 2.3L Ecoboost makes 310HP at 2.3L which = 134.8 HP/L. The Coyote makes 460HP at 5.0L which = 92HP/L. According the favorite Ford fanboi metric, you HAVE to buy the Ecoboost engine. AND you want to tell Ford to make an even smaller engine, like 1L and jack the boost to the moon. That would give you close to 300 HP/L. Would you want to drive that engine? HP/L will always tell you that you should lower displacement, add boost if you don't have it, and jack the boost as high as you can when you do have it. That leads to a shitty engine in terms of driving dynamics. It is a completely stupid metric that will lead you to a worse design every time. Let's look at it another way. How about if we use the metric the way it was intended: compare two engines of the same design. Chevy (and GM) makes mostly DOHC engines. The Mustang used to come with a 3.7L V6 as an option that made 300 HP. At the same time, Chevy made a 3.6L V6 that put out 315 HP (IIRC) at that time (and now makes 335HP with the same 3.6L). Now this is a valid comparison because the two engines are of the same design, so volumetric efficiency is now an applicalbe metric. Turns out Chevy builds a more efficient engine. HP/L is a crappy metric that teaches us to all drive 2.0L turbo engines rather than N/A V8. AND, the Ford faithfull MISSUSE this metric in a situation that it's not applicable, and then they can give themselves a pat on the back, even though that metric is clearly telling them that Ford should dump the N/A V8, and go with a TT V6 instead. Or better yet, a 4 cylinder turbo. Hey, want to go exotic? Get a one cylinder and add both turbo and supercharging... |
