#3235 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
The 2SS curb weight is 3860 with m6. Comes with Brembos stock, comes with 20's stock. Comes with leather and power everything.
From what I have read the GT's weight of 3603 is base model. The weight of the GT premium in motor trend was 3620 with no glass roof. I think the glass roof adds another 25 lbs from what ive read. 3645 to 3860 both optioned. 1SS might be 3849 but thats only an educated guess because that is another weight I have seen quoted for the 2010 camaro. This would add up...a couple less motors (manual passenger seat and no heated mirrors) and no leather. base to base it is 3849 to 3603 Base to base = 246 lb difference (both m6) Both optioned out= 215 lb difference (both m6) You would be more correct to just site a 200 lb difference if you are into rounding numbers ![]() Also...the SS has a larger gas tank and curb weights are cited with a full tank. If it had the same amount of gas as the GT it would be a little closer lol |
#3236 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2000 Mustang GT Join Date: Jul 2009
Whipple states they have a kit that will make 600hp @ 7 psi for the 5.0 on pump gas. I really want to see what Kenne Bell is going to offer. And getting more wild than that will require changing some internals and at that point you can bring the CR down. The LS3 still has a 10:7:1 ratio itself. |
#3237 | |
I used to be Dragoneye...
#3238 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
I've heard that the LS7's cylinder walls are too thin to reliably withstand boost. That's why the LS9 was based on the LS3, and not the LS7. I guess that's the downside of boring a small block out to 428 cubic inches.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." |
#3239 | |
BOOOOOM MF'R!!
Drives: to Chipotle daily Join Date: May 2009
#3240 |
Ok. You never specified. I was just including all information. Its not my fault loaded on the GT comes with a glass roof. I listed weights for both anyway...so im not sure what your getting at champ.
GT Premium 3620. 2SS 3860 240lbs. Or how about base gt at 3603 and 1SS at 3849 246lbs. (Still wont work for your rounding up game) I know it feels good to dog the camaro and lay down your "300lb weight advantage". But just know you are incorrect when you say so
#3241 | |
BOOOOOM MF'R!!
#3242 | |
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
I am not convinced the 5.0 will make up for it's limited N/A capability on the FI side. (In comparison to the 6.2) There are folks with the LS3 FI laying down 600WHP on pump gas. That = around 690HP at the crank. I feel that will only be achievable with race gas or meth on the 5.0. Time will tell. |
#3243 | |
But I think we will need to wait and see when the GTs hit the street. The heads are supposed to be flat out amazing. Better than the GT500 heads. Depending on their efficiency they might can help the 5.0 handle a little bit more psi from a supercharger. Remember the compression ratio is not necessarily the enemy, it is detonation. And another thing to remember is that while that Camaro hits that 600rwhp mark the stang would be able to dyno 575-580rwhp to keep the power to weight very close. |
#3244 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
#3245 | |
Id like to know how all those complex internal moving parts would work and hold up under 5000+ horsepower What is the fastest time any ohc design has ever went in the 1/4? No car under any class has ever gone faster than pushrod (except for the rocket propelled cars of the 70's) Surely someone has pushed OHC to the limit. educate me. And Im not sure what you mean about driveability. 530rwhp (600hp) N/A LS3 cars built from nothing more than average joes with aftermarket parts (h/c/exhaust/full bolts ons/dyno tune) are perfectly driveable and reliable all day long and on pump gas at that. They do pretty good for a dinosaur. Id like to see you do that with a 4.6 or 5.0 OHC motor. Last edited by ULTRAZLS1; 04-10-2010 at 09:11 PM. |
#3246 |
Here's why I like DOHC:
It's more flexible in adjustments (see VVT) and in general...is a more efficient design, allowing engineers to do more with less displacement. Here's why I like OHV: It sounds ridiculous with an exhaust (all the chains and valves externally-placed cams make DOHC sound "whiney") And it's simple. Simple to build, simple to maintain, simple to modify. Simple also means inexpensive. Here's why I like BOTH: They can both be adapted to a V8...and stuffed into a sporty coupe like the Camaro or Mustang. Which...I have to assume...is why we're all here.
#3247 | |
![]() Drives: ex-500hp v6 mustang Join Date: Oct 2008
fixed for you |
#3248 | |
As for your question about how these complex moving parts would hold up under 5,000hp...top fuel runs at over 7,000hp and DOHC would hold up just as well as OHV; For about one race before having to be rebuilt... There is no real reason to use DOHC in top fuel because you are better off just increasing displacement when you aren't concerned about efficiency or reliability, like I said. Again, this really doesn't have anything to do with what we're talking about because no form of racing be it F1, NASCAR, top fuel, or GT Cup focuses on what the production car market does. What should be of interest to you is the fact that the forms of racing that allow the most tech and limit displacement instead of specific types of designs, use mostly OHC designs, almost all using DOHC (bike, f1, f3, etc.). Last edited by 8cd03gro; 04-11-2010 at 04:01 PM. |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Official 2011 Mustang GT info released | nester7929 | General Automotive + Other Cars Discussion | 81 | 12-28-2009 03:13 PM |
