Old 09-25-2018, 12:03 PM   #309
Bains
Bains's Avatar
Drives: '18 Camaro 2SS 1LE M6T
These are great, now we need a ZL1 1LE style smoked 3rd Brake Light that's cheaper than the one from GM!
Bains is offline   Reply With Quote
Old 09-25-2018, 12:35 PM   #310
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Need C7 Vette markers.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 09-25-2018, 01:46 PM   #311
crosive
Drives: 18 zl1
I'm on the 3rd set, the new manufactured ones, and they are still running strong. been on almost a month I'd say.
I'd post pictures, but *somebody*, I'm not naming names, put them on backwards without paying attention to the colors.
So yes, you can put the reds on front and the oranges on back.
crosive is offline   Reply With Quote
Old 09-26-2018, 09:25 AM   #312
JWMotoring
JWMotoring's Avatar
Drives: 2018 SS Hyper Blue
I'll look into it.
They're in the works. We're finishing up our R&D on them now
Great to hear!
Swap those fronts to the rears and you should be good
JWMotoring is offline   Reply With Quote
Old 09-26-2018, 03:14 PM   #313
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
https://***************/collections/...-clear-red-led
These are even cheaper and better. I went with DD while ago but If this came out then I would’ve bought it.
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 09-26-2018, 03:53 PM   #314
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
I think this whole thread is a valuable lesson in why cheaper isn't always better, though.
S2K+1LE is offline   Reply With Quote
Old 10-28-2018, 03:28 PM   #315
ExCrystal
Drives: 2017 2SS NGM
Still working beautifully!
ExCrystal is offline   Reply With Quote
Old 10-29-2018, 06:57 AM   #316
JWMotoring
JWMotoring's Avatar
we've had no issues on the new sets.
Old 10-29-2018, 08:34 AM   #317
crosive
Drives: 18 zl1
mine are still working beautifully. my flir even shows them at a decent temperature as well, whereas the other ones did run warm. very warm.
Old 10-31-2018, 05:04 PM   #318
JWMotoring
JWMotoring's Avatar
Thanks buddy
Old 10-31-2018, 08:46 PM   #319
mondelo
Drives: 2017 2SS
For 100$ savings over DD... I wouldn't recommend.
Not after looking at OP's pictures with light bleed. Not after looking at through 3 out of the 24 pages of this thread.
You get what you pay for in life. And this is a great budget option no doubt. But unless you got the LS/RS (im not even sure what it's called) and you paid under 28k and you struggle with affording 200$.... there is not a reason you shouldn't double your money and buy a set of higher quality LED lights that will last your use of your vehicle (4-8 yrs). Now if you happen to be a 2yr lessee of a 28k 2T/V6 (whatever the name) then I fully understand why you waiting out for these.
But come on... price does not equal value... but price usually correlates to value. And if you disagree with me, you either are young or inexperienced (or incredibly savvy in your life, but that's few and far between)
mondelo is offline   Reply With Quote
Old 10-31-2018, 08:49 PM   #320
mondelo
Drives: 2017 2SS
@JWMotoring
Please correct me if I'm wrong, but all i see in your profile is posts of others with the Title: "XXXXXXXXXXXXXXXXXXXXX $89.99 as good as oracle and DD"
Old 10-31-2018, 08:52 PM   #321
mondelo
Drives: 2017 2SS
Maybe if I would have waiting between my posts and accepted the Venmo payment. I would have had a similar post with AlphaCamaro7.
Your post sounds as authentic as an Infomercial
Old 10-31-2018, 08:59 PM   #322
mondelo
Drives: 2017 2SS
My front passenger one went out again. Front driver is still working.
I had Chevy install the LED footwell lights (GM accessory) after the second set stopped working, so I don't think those are causing a problem.
I may hold off on replacing the side marker for a third time, though, and put the factory back on.
Facts. Go for factory or a more reputable brand. Hope for the best for you but I doubt those Chevy installed footweel lights had anything to do with a legally sanctioned exterior light wiring....
There just defective at a higher rate because they are made cheaper... Go back to factory or dispute the charge with your CC and buy a better quality set (DD or Oracle)
