03-02-2016, 09:58 PM | #309 | |
Drives: 2016 F150 Join Date: May 2014
Edit: Just looked at the Hennessey video and the above may not be true, but they are very close to each other in MPH in the first 4 gears. |
03-02-2016, 10:20 PM | #310 |
Drives: Want a gen 6 Join Date: Jan 2013
That's what I'm thinking too. You can probably keep an 1LE in 3rd on a slower corner where the gt350 may have to downshift to second then upshift to 3rd on the straight. Say there is one corner like that and one straight where you need to go over 110mph and shift the camaro (assuming the gt350 can keep 3rd for that entire straight). Then I would call that a wash on loss of time due shifting. With the 1LE getting the edge due to low end torque coming out of most corners where both cars are staying in 3rd.
03-03-2016, 08:09 AM | #311 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
You’re shifting a lot, too, just cresting into third as you enter the corner before shifting back down to second. We like rowing our own gears as much as the next guy or gal, but rushing through the gears in the Ford is frustratingAlso, The Voodoo revs higher but its usable power is also 1500 rpm higher. Its a turd below 4000 rpm
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
03-03-2016, 08:09 AM | #312 | |
I used to be Dragoneye...
Comparison of the GT350 v Camaro SS transmission ratios. |
03-03-2016, 08:28 AM | #313 | |
03-03-2016, 09:00 AM | #314 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
03-03-2016, 10:59 AM | #315 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
You think with that extra net torque, the GT would be able to keep up with the SS.
03-03-2016, 11:12 AM | #316 | ||||
Drives: 21 Bronco Join Date: Jun 2012
I think what GM has done with the Camaro is incredible. The SS is damn fast, it is almost scary to think what the high performance variants will be capable off. Also you say HP is one way to value an engine but you were the one who kept mentioning the Voodoos low HP. You were the one who brought it up. You dogged the voodoo for low HP, I asked you to name an engine that makes more HP you ignored. You said the LT1 nor any of its derivatives get the gas guzzler tax. The LT4 in the CTS-V does. You also ignored that. Quote:
Paris is the one who kept saying the Voodoo is a low HP engine not me. |
03-03-2016, 12:30 PM | #317 | |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
I don't care what their graph shows in manipulating gear ratios, the fact remains that the SS is on average .6 seconds faster in the 1/4 mile. That's a lot. |
03-03-2016, 12:38 PM | #318 |
03-03-2016, 12:39 PM | #319 |
Drives: 2012 Ford Focus Join Date: Jan 2014
The GT only has more net torque through 50 MPH, after that its pretty even until about 70 and then the SS takes it. It's one of the reasons the GT is so hard to launch with the 3:73 gears.
03-03-2016, 01:23 PM | #320 | |
03-03-2016, 01:34 PM | #321 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I've never seen a GT have more torque than an SS at that point on a dyno sheet...not to mention the ratings are 400 to 455.
03-03-2016, 01:36 PM | #322 |
