#3137 | |
Drives: some to distraction Join Date: Sep 2011
it's 24+ freakin' %! In the real world of racing, these two are separated by at least 10 zip codes! |
#3138 | |
Anthrax Popcorn User
Drives: 2013 GT500 Join Date: Nov 2011
And it's still diminishing returns.
If there was a 24% power/weight ratio difference on a pair of 8 and 9 second cars, they'd be even CLOSER. The answer is staring you in the face, you can look away if you wish.
2013 GT500
1999 GT- sold 1972 Mach 1- sold Quote:
#3139 |
![]() Drives: Mustang GT Join Date: May 2012
More excuses, damn just give it up guys. The fact is the ZL1 has other things that the GT500 does not have that should negate the extra HP. Two things that come to mind that your own people say are IRS, and magic magnets in the suspension. So stop making excuses, if the ZL1 wins I won't be claiming the des parity in suspension. Or maybe I should.
#3140 |
![]() Drives: 2013 Porsche 981S Join Date: Feb 2012
The power required to overcome aerodynamic drag scales with the velocity cubed.
#3141 |
eolson
Drives: 2006 premium Package Mustang GT cou Join Date: Dec 2011
I think it's pretty clear that at this level, the ZL1 has been brought to a sophisticated level of performance with IRS, Magnetic ride control, great traction control, and over all balance.....on paper, the ZL1 should clearly win at the road courses.
.....but it looks like now that the info is in, other than how people "feel" about driving the cars, the GT500 is equal in actual performance. Hopefully someone will jimmy rig some brake ducting on the GT500 and run a published Nurburgring time to shut everyone up. Until then, as said before, this 57%/43% weight distribution, Fixed axel, basic traction control(not used) crude, over powered shit box can put the power down and stick it out of corners just fine. The issues to be improved would be slightly better corner G's (less weight in front) and brake ducting or cooling (no brainer). Great Job after all SVT!!! Erik
2006 Prem Pkg Mustang GT coupe. Saleen SC,10psi, 454rwhp,442rwtq, Complete Steeda/H&R, suspension change out, with weight loss, Techco Watts link, Stoptech big brakes, Race clutch, Alum. flywheel, Alum 1 pc driveshaft, 9x18,10x18 chrome bullit wheels, 285/40/18,255/45/18 nitto 555 tires. 3545 lbs currently. New car scent air freshener.
#3142 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Luminadead/01 Dakota/97 F150 4x4 Join Date: Jul 2009
Well, this thread seems to have gotten pretty quiet.......
#3143 |
![]() Drives: 2011 C63 Join Date: Feb 2012
#3144 |
#3145 | |
![]() Drives: 2010 Camaro SS, 2014 Z28 Join Date: Jan 2012
#3146 |
![]() Drives: 2013 WRX Sedan Join Date: Aug 2009
#3147 |
eolson
The issue with a hero lap is break ducting or cooling and better materials which should be addressed by SVT, that doesn't mean you can write off the entire design of the GT500 as a one lapper. The breaks work well, but the cooling isn't.
That's like saying GM can't put more power down with the ZL1 with a shorter pulley and some internal reinforcement. Of course they can, and will I think. So clearly the ZL1 is more sophisticated, but the GT500 is plenty able to over come the break fade element, and individuals are addressing it already making consistent laps with little break fade. Erik
#3148 |
![]() Drives: 2010 Vette Join Date: Jun 2010
Sorry...but I have just have to, as I've seen it too many times today...
It is "brake"....not "break". No offense intended.
#3149 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2000 Mustang GT Join Date: Jul 2009
#3150 |
Drives: 2010 Camaro 2SS/RS Join Date: Jul 2009
