#295 | |
I knew my battery was going out as the voltmeter would stay at 14V the whole time I was driving for about 4 months before it failed. I don't drive the car much on long trips. Most trips are 30 minutes or less. With this car's charging system and an AGM battery those short trips are a recipe for a short battery life (3-4 years tops). I now use a battery tender between drives to keep the battery topped off. Reading what I've posted today one could reason that a good battery is all that is needed. That is true for cold starts. But the heat-soaked hot starts need a good battery and the extra ground cable to keep that circuit resistance low or the starter will drag.
#296 | |
![]() Drives: 2017 Camaro 2SS Convertible Join Date: Oct 2021
Coincidentally for me.....my daughter was in an accident last year (November-ish), pretty soon after I had replaced the cable. The battery died pretty quickly with just the 4-ways going. But when I got it back from the shop it fired up better than ever. I thought maybe they had replaced something that was affecting it but they would have had to charge the battery to get it started again. The last time my wife got stuck when it wouldn't start. She called me so I drove over (took about 20 mins + she in was in a store for about 10 mins). Once I got there she tried to start it and it fired right up. Just that 30 mins was enough for it to cool down enough to overcome the heat-soak I guess. I also notice that my battery very rarely goes up to the 13.8-14V on the dash. Most of the time it's sitting down around 12.5. I'm wondering if it's just not getting the charge it needs from the car (maybe due to poor cables?) The battery must be original. I've had this car since 2019 and was bought with only 1000 miles on it. And I've never replaced it....I'll take a look at it this weekend. |
#297 |
![]() Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
I have not done the ground wire thing yet on my 2016 SS.
I am in central FL, gets pretty hot here and I have experienced the slow cranks when I drive only short distances before shutting off the engine. Recently I have started using a battery tender that has a "desulfator" feature. I leave it hooked up to the battery tender for a week at a time, each month. I have not experienced any slow cranks since I started using the battery tender (in my garage) for 1 week, every month. Rest of the month, I just leave my car outside the garage. My driving is predominantly 5 mile commutes, 5 miles to work, 5 miles back home. Kids. ![]() EDIT: oh yes, I am on the original battery. |
#298 | |
#299 |
Sounds similar to the Big 3 Upgrade that the car stereo guys do. I did that on my 94 Z28 with 2 amplifiers and a stock-type battery. Never had issues with starting the car, or with headlights dimming or anything like that. Had it for several years, up until I traded up last November.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#300 | |
Did a long drive yesterday, where it started at 14+ and ended up around 12-13 after almost 45 min of driving. I don't know much about the desulfation process, or if it's even effective, but some folks that work in the industry recommended that I leave my car hooked up to a battery tender with a "desulfator" for multiple days at a time. Let's see what happens this summer, my battery is 7-8 years old. It probably needs to be replaced anyway. Have not really had any slow cranks in the last several months, but at the first hint of trouble, I'll replace the battery. |
#301 |
![]() Drives: 2016 Camaro 2SS Join Date: Aug 2022
Slow crank , no crank hot
Hi I had the same issue with my 2016 Camaro 2 SS. Been through 2 batteries and an 800 bill at the dealer to replace a cable(non-warranty). I did the ground update as mentioned STILL had an issue. I switched the battery from an AGM battery to a standard lead acid battery Same size same CCA and the problem has not come back. Hearing many bad things about AGM batteries....
#302 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
After about a month of slow starts, my battery wouldn't start my 2016 RS today. Had it jumped & voltmeter was at 14 after 10 minutes of sitting & running. While driving, it went up to 15, then started dropping to just below 14 after a long traffic light. After stopping at a restaurant for dinner, it started & is staying right at about 14. I've got an interstate 48 month battery that's 2.5 years old - it shouldn't be going bad already. Yesterday my side warning systems started giving me "temporarily unavailable" messages too. Not sure if it's the battery or not.
#303 | |||||
![]() Drives: 2016 Chevrolet Camaro 2SS Vert Join Date: Apr 2023
When you put the extra ground for your battery, did you bolt the body end of the ground down to the unused body post, or did you just place it on there? |
#304 |
The photo doesn’t show it very well but it has a nut holding the cable on the stud.
#305 | |
Thanks again in advance |
#306 |
That cable has a thick lug. If I remember right I put it in a vise and used a hacksaw with a metal cutting blade. You might want to skim through this thread and look for other engine connections that can be used. The other locations will not require cutting the lug. But if you go my way it has worked perfectly fine for over 2.5 years. Remember that if you make a lot of short trips (under 30 minutes) that the battery is probably not gettin fully charged. It takes a strong battery and a solid ground connection to overcome the slow crank every time. I now keep my battery on a trickle charger between drives since I only drive the car once or twice a week. Good luck.
#307 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#308 |
Mine has got so bad over the last month that I never know if it's going to start when I get in it after going somewhere.....
Last time there was a strong electrical burning smell coming from the engine compartment. But it still jump starts and runs just fine.... Thinking of replacing the battery (still original in 2017 Camaro) as a (new) starting point. EDIT: new fun fact....trying to start just now (tried about 3x) something right under the engine caught on fire. Couldn't see exactly what but could see the smoke and glow. Luckily had lawn hose nearby to put it out. Guess it's dealer time (again) Last edited by chovaz; 07-26-2023 at 03:59 PM. |
