Old 08-16-2017, 09:14 AM   #295
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Originally Posted by thescreensavers View Post
Its relativity cheap ill tally it all when Im done. If you have basic wiring knowledge its easy but the hardest part is soldering that small chip lol
Thank you x2!! This would be so amazing to have some air blowing on my back during track days. So effing hot.
2017 SS 1LE (sold)
Nightfall Gray
Th3Beast is offline   Reply With Quote
Old 08-23-2017, 12:11 AM   #296
N54NOMORE
Drives: 2016 2SS
Update. They are almost plug and play in a 2SS. I bought a set out of a 1LE for my 2SS. All power options work. And yes, the hot and cold works just as it did in my factory seats. All power riser switches work.
Here is what doesn't work. The memory function and now my power mirrors don't work either. Which makes sense as they are tied into the memory function. I assume the fix is to completely swap the wiring harness from my factory 2SS drivers seat along with the memory box located under the drivers seat over to my recaro seat and then swap that harness back to my 2SS seat for the next user.
All parts in the seats are identical part numbers as far as the components go. All seat motors, cooling fans, airbags and everything are identical.
I was willing to do without the memory function until I noticed today that my power mirrors no longer work. I will update of the harness swap and box work.
N54NOMORE is offline   Reply With Quote
Old 08-26-2017, 03:49 PM   #297
N54NOMORE
Drives: 2016 2SS
I was correct. After swapping over the harness from my original seats along with the memory box located below the seat I now have 100% plug and play functional seats. 😁
Old 08-26-2017, 05:42 PM   #298
AZ_SS_1LE
Drives: F150
So if I'm understanding this correctly, if I buy the 2ss control module and the memory box it's plug and play on my 1LE? If that's the case anyone know the list price?
Thanks for all the good work on this.. it's HOT in AZ.
AZ_SS_1LE is offline   Reply With Quote
Old 08-26-2017, 07:52 PM   #299
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I would be very interested in this since I have the ZL1 door panels in my 1LE which already have the memory buttons so all I should need is the memory box!
IG: @NC_M1SS1LE
Old 08-26-2017, 08:17 PM   #300
The_Coleman
Drives: 2017 NGM 1SS 1LE
He has a 2SS car that already was wired for and had the switches. He wanted the recaro seats and bought some from a 1LE and installed them in his 2SS. All that was proven was that if the BCM was configured to control them and the switches and wiring are present, the ventilation and heating will work.
1LE owners still lack the wiring, switches, and BCM programming.
The_Coleman is offline   Reply With Quote
Old 08-27-2017, 12:39 AM   #301
AZ_SS_1LE
Drives: F150
Thanks for the clarification.
Old 08-27-2017, 04:06 PM   #302
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
all right. here is a newbie question.
I want to install my 1LE seats into my SS.
Can I just unbolt and unhook the harness underneath. Swap seats and re-hook the wire harness.
Or do we have to disconnect the battery? In the trunk? negative cable?
Old 08-27-2017, 06:40 PM   #303
The_Coleman
I would take the time to unhook the negative battery cable in the trunk from the battery. You are going to be disconnecting modules and airbags from the car when you do it, and you really don't want to chance one of those things firing.
Old 08-30-2017, 12:22 AM   #304
N54NOMORE
Drives: 2016 2SS
Correct! The body harness would still be different. I just wanted to clarify what is needed for peeps trying to make them fully functional in their 2SS cars.
It does confirm that they are different because if they were the same the mirrors would have still worked without switching over the memory box and different seat harness.
I would assume you could make the memory work just as you can make the fans work with the factory ac controls from a 2SS in a 1LE but you would have to run wires. Also you would need to change the wiring for the mirrors. Could get messy.
Old 08-30-2017, 06:23 PM   #305
The_Coleman
I would guess the memory functions were added from another supplier. Recaro probably only provideded what they did because it was easier to make one variant and the components were integral to the seat.
Old 08-31-2017, 10:09 AM   #306
zryan
zryan's Avatar
Drives: 1973 z28 Rs, 2018 SS 1LE
This Sucks. They could have at least saved the weight if they were gonna screw us like this.
2018 HBM SS 1LE Built 7/26: Black emblems, Smoked reflectors/lights, Dimple magnetic drain plugs, Carbon rock guards, Carbon fuel door, Elite Engineering Catch-can, BMR strut-brace,
zryan is offline   Reply With Quote
Old 08-31-2017, 10:19 AM   #307
rootus
Drives: 2018 HBM SS 1LE
It is kind of taunting us to put the equipment in but provide no way to use it. I will probably do the DIY switches at some point so I'm glad the stuff is there, but I have to laugh about them saving a few bucks on the switch. But probably Recaro, as the supplier, is the one really making the choice on what is most cost effective for them.
rootus is offline   Reply With Quote
Old 08-31-2017, 12:12 PM   #308
The_Coleman
It simplifies a lot of things for everyone just from the fact that there is only one part number for a recaro seat. The supply chain is much easier to manage if you don't have to account for consumption/availability rate of two items for instance.
Recaro probably made the decision and GM got the price they wanted for the seat. The cost of the equipment is minimal, but it adds up in high volume situations. I am willing to bet that Recaro figured out the uptick in cost was recouped downstream in the assembly and supply chain phase. Also, no supplier wants to be the one to halt an assembly line, the penalties are enormous and your odds of getting a renewed contract are drastically reduced. I work for a Ford supplier.
