Old 02-28-2020, 07:41 PM   #295
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Originally Posted by glamcem View Post
Cool photos those deflectors look like vampire teeth which I'm totally fine with it
My wife asked me why my car had fangs, and why am I showing them. She thought they look cool too. 😎
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 02-28-2020, 09:38 PM   #296
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
glamcem is offline   Reply With Quote
Old 02-28-2020, 09:49 PM   #297
glamcem
glamcem's Avatar
Weight Reduction update
I removed the passenger and back seats before my appointment for alignment (and other stuff) so that the alignment will be based on track weight (with me sitting in it).
I had a chance to weigh them so for now I will be saving 87lbs from seats and 38lbs from the wheels and tires which make up to a total of 125lbs weight reduction. So I am thinking the car should weigh about 3620lbs (since factory curb weight is 3745lbs)
Once I get the R7 (2lbs on each corner), Girodisc front rotors (4lbs on each side) and lightweight battery (possibly 25-30lbs savings) it will be an additional 40lbs of savings which makes it below 3600lbs. ChaseRace have a scale so I will have him weigh the car .
Old 02-28-2020, 10:37 PM   #298
glamcem
glamcem's Avatar
Tested the Schroth quick fit pro 4 pt harness with my HANS device (NecksGen Rev2) and helmet.
More info can be found here:
https://www.camaro6.com/forums/showt...7#post10735107
Old 03-01-2020, 04:36 PM   #299
glamcem
glamcem's Avatar
Since some members warned me about the annoying buffeting issue at the track days that caused by removing the back seat (possibly due to opening to the trunk ...causes a turbulence maybe?), I decided to cover the trunk opening area.
After thinking about it, I think I might have found an quick and easy solution (or a dumb one)
I used the existing trunk mat, upside down, put a small hole with a center punch and zip tied it to the hook where the backseats connects, added a couple velcro pieces to connect and hold the trunk mat in place ( velcro pieces can be reused also, haha)
I will report back if it does the job
Old 03-02-2020, 01:40 PM   #300
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I like the idea, but I think the buffeting is there even with the seats in. At least for me it is...
Old 03-02-2020, 06:53 PM   #301
glamcem
glamcem's Avatar
Hmm I don't recall it was that bas (when I had the backseats) but maybe because I was driving two windows down
Old 03-03-2020, 01:19 PM   #302
TheRealJA105
Drives: 2013 C6Z06
I always track with both windows down and I think it gets bad anywhere over about 110.
Old 03-03-2020, 01:22 PM   #303
glamcem
glamcem's Avatar
Oh ok that makes sense at our local tracks here in PNW, there are maybe 1-2 straightaways that I can pass those speeds and it's not constantly over those triple digits so maybe I didn't pay attention b/c of that.
Old 03-04-2020, 01:24 PM   #304
glamcem
glamcem's Avatar
I picked up the car from ChaseRace yesterday so the following has been done:
  1. Engine oil changed (Mobil 1 0w-40)
  2. Front and rear swaybars installed (both in center hole for 30% more stiffnes)
  3. Knuckle grinding and bolt hole extension mods have been done for more camber
  4. Alignment done
  5. GM OEM longer wheel studs installed for 5mm spacer
It looks like after some additional trimming and welding to the strut ears, I was able to get about 6mm clearance with -2.7 camber.
BEFORE (this is after initial grinding not the OEM look)
and after (unfortunately the photo I received is not from the same angle but some additional clearance gained after trimming spot welding area)
ChaseRace also weighed the car while it's on the alignment rack, full tank of gas, passenger and rear seats have been removed. With Apex 18" Toyo RR set
final numbers after alignment :
Old 03-04-2020, 01:40 PM   #305
glamcem
glamcem's Avatar
I received the my spare Toyo RR set in same sizes (295/315/30/18) that I ordered after seeing the special discount so no wait times for the second set or if I cord the fronts earlier than expected.
Lately, I was thinking about a pair of custom front wheels in 18x10.5" (with about +10 offset to push the whole thing outwards as I have tons of clearance outside with -2.7 camber now) and test it against to my 18x10" Apex wheels, so instead of running 295 -315/30-18 Front and rear, I would see how effective the 315/30/18 SQ setup would be.
Since we have a front heavy car, adding more front grip would be great to fight with understeer, especially since I now have the adjustable front sway bar and I could even make it stiffer to combine with the 315s up front for even better traction and stability (as well as sharper turn in).
However, after some careful consideration I figured for about the same money for a pair of custom 18" wheels, I can get a whole new set of Apex ARC-8 wheels in 19" sizes so that I can try the Goodyear Supercar 3R tires that most people had great experience with. Unfortunately there's no good available sizes for 18" wheels. I decided go with 19x10.5 +22 and 19x11" +43mm Apex ARC-8 wheels as they surprisingly weight about the same as my 18" Apex SM 10 wheels. That way I will be able to try 305-30-19 Supercar 3R tires Square setup and compare against the 295/315 staggered Toyo RRs. I ordered both 19" wheels and Supercar3R tires last night .
I really want to see if the SC3R tires live up to the hype and how they will compare against to RRs. Hopefully they will be ready before my scheduled event on March 20-21st
Old 03-04-2020, 07:33 PM   #306
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Great progress! The Provoste strut mod works great. I did mine in my garage with less than ideal tools. I will be running the SC3R 305 square setup March 14-15 for the first time. I may have to get those swaybars depending how it goes.
Old 03-04-2020, 09:09 PM   #307
glamcem
glamcem's Avatar
Originally Posted by carguy55 View Post
Great progress! The Provoste strut mod works great. I did mine in my garage with less than ideal tools. I will be running the SC3 305 square setup March 14-15 for the first time. I may have to get those swaybars depending how it goes.
I agree, it's a great mod. I was able to achieve a bit more camber with the previous car (~ -2.9 ) but it's maxed out at -2.7 this time. If I feel like I need a bit more I will think about it and so maybe we can modify the knuckle a little.
Hopefully we both like these tires
Old 03-04-2020, 09:32 PM   #308
red6.2
Drives: 2010 camaro
when do you typically do oil changes on the car? after 3-4 days on track?
red6.2 is offline   Reply With Quote
