Old 07-30-2022, 04:30 PM   #281
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Changed Diff fluid today. Definitely looked necessary. Reminded me of the oil at 900+ miles. Definitely had a metallic presence.
george is offline   Reply With Quote
Old 01-09-2023, 02:22 PM   #282
HemiDave
HemiDave's Avatar
Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R
For my 2016 Z06, GM recommended a 500 and 1500 oil change.
I would stick with that for the break in oil changes for the ZL1's.
I would wait until 1500 for the rear diff.
You cant track the car before the 1500 break in anyway, so why do a 500 mile rear diff change?
2018 Dodge Demon #1399
2020 Jeep Gladiator Rubicon 6 speed manual
2023 ZL1 1LE 6 speed manual
2018 Suzuki GSXR 1000R
2021 Kawasaki ZX10R
HemiDave is offline   Reply With Quote
Old 01-09-2023, 03:30 PM   #283
Vigilante375
Drives: 2018 Camaro ZL1
Because you still get a bunch of metal shavings from the gears breaking in as you see from the above post.
I changed my oil and diff fluid at 500 and 1500 miles. Both times the diff had metallic shavings but a lot less on the 2nd time. Its quick to do and cheap.
I mean, technically all this break in stuff for the ZL1 is recommended. Doesn't mean you have to. It's not like the C8 or CT5 Blackwing that actually limits your RPMs until you hit 500 miles.
Old 01-10-2023, 04:19 PM   #284
HemiDave
HemiDave's Avatar
Plenty of different options here on when to change the diff fluid.
I don't think anyone is going to run into a diff failure if they wait to do it at 1500 miles after following proper break in.
2021 Kawasaki ZX10R
Old 04-05-2023, 08:45 PM   #285
Transformerrk
Transformerrk's Avatar
Drives: 2023 ZL1 1LE, 2010 SS Transformer
Advice needed
I got my new 2023 ZL1 1LE 10A 3 months ago and have 500 miles on it. I've had a pretty spirited break in so far using all the gears, rpm's (to 4 or 5k), brakes, tires (warmed properly), etc. and want to do the right thing next.
Should I change the oil, differential and transmission fluid? all three or some combination? anything else?
Whatever I do now I want to do again at 1,500, or should I? Please advise and I thank you all for your knowledge!
I have already signed up for Limerock and Poconos in May so need to put a 1,000 more on in a month.
Been using my 2010 SS so huge jump for me in performance is an understatement.
Thanks, Rob
Transformerrk is offline   Reply With Quote
Old 04-22-2023, 06:14 PM   #286
CashBasis
Drives: ZLE
How hard can you push the car during this period? Are you supposed to stay under a certain RPM? I think I read somewhere in this forum that it’s recommended to stay under 3,500.
CashBasis is offline   Reply With Quote
Old 04-22-2023, 10:27 PM   #287
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Isn't 4k rpm the limit for first 1500mi? For my car, I would accelerate and leave it in 2nd or 3rd to let it coast down in gear to give the opposite piston walls some break in.
wakespeak is offline   Reply With Quote
Old 04-22-2023, 10:37 PM   #288
wakespeak
wakespeak's Avatar
Thanks, Rob
Its all in the track supplement but you can't change the engine oil or diff often enough. Yes change it at 500 miles to get the fine break in metals out. After break in its more about how hard you use the car, but annual on the manual trans and before every event for engine oil and diff is what I do (about 4 events/year).
Old 04-30-2023, 01:11 PM   #289
Transformerrk
Thank you, I am reading as much as I can before first track event.
What about the automatic transmission fluid change? It's hard to get good info on that.
Thanks
Old 04-30-2023, 02:30 PM   #290
vj123
Drives: 2023 ZL1
Here is a link to the documentation.
https://www.chevrolet.com/content/da...ackPREP-R3.pdf
vj123 is offline   Reply With Quote
Old 05-01-2023, 03:43 AM   #291
Bigjammer
Drives: Chevy, ZL1 1LE
can you run the 15/50 oil for longer than 4 hrs.?? because I drive car there for Saturday and Sunday for 6 25 minute sessions each day then home!! so I will have about 9 hrs on that oil! can you run the 15-50 oil for a couple thousand miles on the street??
Bigjammer is offline   Reply With Quote
Old 06-28-2023, 09:43 AM   #292
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
with all this oil talk
my manual say 0w-40 dextos R oil which only comes in a mobile 1 supercar
not Dextos 2
IMCWORTH is offline   Reply With Quote
Old 11-03-2023, 06:51 PM   #293
htron435
Drives: NASA SPEC IRON MUSTANG, 2023 ZL1
Mobil1 Supercar is the Dexos2/Dexos R variant. Fwiw, anyone tracking a ZL1 with track tires should consider using 15/50 instead of the 0w40 since lateral grip will approach that of a ZLE.
htron435 is offline   Reply With Quote
Old 11-05-2023, 08:02 AM   #294
TTown918
TTown918's Avatar
Drives: 24 ZL1 (4Runner, CRV, Civic, Expl)
Preliminary:
Regarding the 500/1500 interval, right out of the gate..
So remind us, what is the recommendatation? Oil and differential fluid change at both 500 and 1500 miles?
TTown918 is offline   Reply With Quote
