Old 06-01-2023, 10:31 AM   #281
OnThree
OnThree's Avatar
Drives: 2017 Camaro SS 1LE
19x10.5 +35mm Offset square setup
305/30/19 RS4
OnThree is offline   Reply With Quote
Old 06-01-2023, 10:35 AM   #282
Camaro Fanatic
Drives: '23 1SS 1LE
Those look great, are you running any spacers on the 19x10.5 rims?
Also what camber?
Camaro Fanatic is offline   Reply With Quote
Old 06-01-2023, 11:08 AM   #283
OnThree
OnThree's Avatar
Also what camber?
Appreciate it! 15 mm spacer up front with extended studs, only running -2.2 camber up front. Did have to do the front strut grind mod as clearance was tight up front but no issues
According to the alignment guy, that's the max he could get so probably will get camber plates to get closer to -3.0 for track use // eliminate some poke up front. Poke isn't too bad up front with -2.2 but there is some.
Old 06-01-2023, 12:03 PM   #284
Camaro Fanatic
Drives: '23 1SS 1LE
Good to know! I've been looking for a way to run square 305s without extended studs as I'd like to swap with the OEM SS 1LE wheels between track and DD easily.
Old 06-01-2023, 12:47 PM   #285
OnThree
OnThree's Avatar
You can still run the OEM rims with the longer studs just need open lugs for the fronts. That's what I'm doing right now as my 1LE is my daily again at the moment.
Old 07-05-2023, 09:57 PM   #286
mcbat8
Drives: 2022 SS 1LE
Originally Posted by APEXRaceParts View Post
We haven't gotten any photos back from SS customers running this setup, nor have any volunteered to swing by our office for a photoshoot and a healthy discount on wheels when we ask :/
They will fit well, with minimal camber adjustments as noted in the fitment guides.
do you still need someone to do photoshoot? I could use a track set
current set:
20x10.5 ET15
20x11.5 ET42
mcbat8 is offline   Reply With Quote
Old 07-07-2023, 11:02 AM   #287
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
current set:
20x10.5 ET15
20x11.5 ET42
Yes! Please fill out this form: https://www.apexraceparts.com/suppor...hoot-volunteer
Apex Wheels is offline   Reply With Quote
Old 09-27-2023, 08:33 PM   #288
Greg83
Drives: 2023 ZL1 M6 Sharkskin
current set:
20x10.5 ET15
20x11.5 ET42
WOW, car looks great! This is probably my favorite looking SS 1LE. Are you running stock suspension or is it lowered? Are those the factory tires? Can you please post some more pics? Is there a little tire poke in the front? Thanks in Advance!
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD
2023 Red Hot ZLE M6 ordered 5/9/23, never built
2022 Shadow Grey 1SS-1LE M6-SOLD
2023 Sharkskin regular ZL1 M6-SOLD
Greg83 is offline   Reply With Quote
Old 10-18-2023, 06:51 PM   #289
Apex Wheels
Drives: Camaro Z28
A new look from Apex! We've recently undergone a lengthy rebranding process that sees our name change from APEX Race Parts to Apex Wheels, new logos, and many more exciting things along the way.
Our website address has also changed, apexwheels.com, with an all new user interface which allows for more info, easier ordering, and an extensive vehicle gallery to help you decide on that perfect setup.
Please note all wheels and merchandise will still be shipping with the original branding for the next few months.
**If you're looking to buy 1 or 2 spare wheels to complete a set, have for backups, etc, now is the time to do so to ensure they match. Waiting until the new year could mean we're out, and old logo products won't be returning!**
Old 11-02-2023, 03:23 PM   #290
Apex Wheels
Drives: Camaro Z28
This beautiful SS was out at Laguna Seca testing the new pavement recently. With plenty of aero and sticky tires wrapped around our 18" SM-10 wheels, he surely had a great time.
Apex SM-10 wheels in Satin Black
Front: 18x11" ET35 +26mm spacer with 315/30-18 Nankang AR-1 tires
Rear: 18x11" ET35 with 315/30-18 Nankang AR-1 tires
Old 11-12-2023, 06:39 PM   #291
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Final took some decent pics of the new SM-10's...
Man I love these wheels!!!
Old 01-12-2024, 11:22 AM   #292
Apex Wheels
Drives: Camaro Z28
Stunning!!!
Old 01-12-2024, 11:27 AM   #293
Apex Wheels
Drives: Camaro Z28
Bennet swung by with his SS 1LE to try out a few different flavors of our wheels. Which one is your favorite? His car is equipped with a track alignment, otherwise factory suspension.
SM-10RS in Satin Bronze
Front: 19x11" ET9 with 305/30-19
Rear: 19x12" ET41 with 325/30-19
VS-5RS in Anthracite
Front: 20x10.5" ET15 with 285/30-20
Rear: 20x11.5" ET42 with 305/30-20
ARC-8 in Anthracite
Front: 19x11" ET11 with 305/30-19
Old 01-12-2024, 11:30 AM   #294
FactoryMatt
FactoryMatt's Avatar
Drives: '22 2SS 1LE
19 sm10 bronze
FactoryMatt is offline   Reply With Quote
