Old 11-18-2018, 09:41 AM   #281
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
Originally Posted by 94boosted View Post
Are people getting "ice mode" in the 1LE's? I thought those car's didn't really get ice mode just the SS non-1LE's.
the 1LE still does get ice mode(hard pedal) but it its harder to hit ice mode. if that makes sense.
Basically from talking with the engineers is since the 1LE was tested with sticky tires they were able to work around the problem where as a regular SS was never tested with actual track tires so when you put something like an RE71R on it tends to freak out!
Oddly enough since I drive mine year round up here.. I never ever get "ice mode" in the winter... lol
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 11-18-2018, 01:13 PM   #282
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
Yah I had a 2015 1LE on square 305 RE71R's and some custom Koni's and the car got ice mode so much I sold it after 5 events, absolutely awful feeling getting hard pedal as it takes away your confidence.
Here's to hoping the soon to be released 2019+ brake controler addresses some of these problems and supercedes the 2017-18 unit.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 11-18-2018, 03:02 PM   #283
apexit53
apexit53's Avatar
honestly thats exactly why im looking at a 2019 mustang or a new 2019 Camaro. I don't think the car will be any faster but having that confidence and knowing the car will brake when you ask it to is huge to me.
Also don't expect that to happen. If gm wanted to do that they could but they would have to do a whole lot of tests make sure it works on the older cars(it will but they won't pay). Plus they would have to admit the brakes are an issue, and outside of the relatively small motorsports community it just isn't an issue.
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 11-19-2018, 09:02 AM   #284
94boosted
94boosted's Avatar
I'm still cautiously optimistic, I don't see there being any real changes to the brake controller other than the conditions that cause hard pedal being reduced, no reason it wouldn't be backwards compatible. I'm still keeping my fingers crossed it supersedes the 17-18 brake controller part #.
2017 - SS 1LE
Old 11-19-2018, 11:14 AM   #285
apexit53
apexit53's Avatar
its not legal for stock classes ot ST classes but if they dont make a bulletin for it, and you wana do that CAMC it is allowed in!
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 11-19-2018, 12:07 PM   #286
jwisjw
Drives: 2017 Camaro SS
Also what options are there for 19x10/19x11 wheels for these cars? MRR & Forgestar anything else that's not crazy expensive?
I believe the Mag ride does a lot to keep the car flat so it will be less prone to ice mode. However, I think any Camaro that spins the tires going into a braking zone will experience the ice mode.
MRR is probably the cheapest right now, if you need a quote, I can PM you.
Interesting. Did you do back to back testing? I would of for sure thought a 305 square setup would be faster.
My Testing was 265/275/285 on a 8.5" wheel. I haven't done a back to back with the 305 vs 285 on a 10" wheel. Just went straight to a 285, however, driving a friends SS 1LE with 305's on the 10" is some what "okay" on higher grip surfaces, which 285's vs 265's on a 8.5" wheel were close. However, lower grip asphalt porous surfaces really show the differences in the speed between the two.
Which bar is it? Adjustable? How does it compare to the SS 1LE stock front bar in terms of stiffness?
The hotchkis bar on full soft is about 40% stiffer over the SS 1LE bar and full stiff is 90% stiffer.
If you need a quote on that as well, you can PM me.
Jeff Wong
ESP Camaro
jwisjw is offline   Reply With Quote
Old 11-19-2018, 05:12 PM   #287
94boosted
94boosted's Avatar
Thanks Jeff^
I'm first going to see where they class the 1LE, if it stays in AS I may just do a mild CAM build
According to the Hotchkiss website the 40% and 90% stiffer is in relation to a stock SS bar not a 1LE bar?
Curious as to why it wouldn't be legal in street class? If the part is functionally the same and the part number supersedes the existing one it should be legal, otherwise if said part failed on a car the owner would be unable to have his car fixed at the dealership in a way that is legal?
2017 - SS 1LE
Old 11-19-2018, 05:22 PM   #288
jwisjw
Thanks Jeff^
The #'s on the website are wrong unfortunately, the actual #'s against the SS bars are ranging from 70%-125% over the stock SS bar.
Jeff Wong
ESP Camaro
Old 11-19-2018, 06:12 PM   #289
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
Hey Jeff, Did you get my PM?
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 11-19-2018, 11:05 PM   #290
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
[QUOTE=94boosted;10362783]Are people getting "ice mode" in the 1LE's? I thought those car's didn't really get ice mode just the SS non-1LE's.
UOTE]
I don't get ice mode, I heard GM has the ABS calibrated for the stickier 1LE tires.
JRL1LE is offline   Reply With Quote
Old 11-20-2018, 08:59 AM   #291
94boosted
94boosted's Avatar
Good to know, thanks Jeff
2017 - SS 1LE
Old 11-20-2018, 10:38 AM   #292
apexit53
apexit53's Avatar
because its not a factory replacement part.
If they make it as such, yes but as of right now its not.
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 11-20-2018, 06:09 PM   #293
jwisjw
Yeah, I PM'ed you back, not sure if it got lost when the camaro6 server went haywire.
Jeff Wong
ESP Camaro
Old 11-21-2018, 01:11 PM   #294
sholzer
sholzer's Avatar
Drives: Cayman S or Borrowed 17 1SS 1LE
to add another data point, I have experienced ICE mode in a 1LE a few times. One day in particular comes to mind, In the video below, @ the :43 second mark I was having issues with ice mode on all 3 of my first runs and on my last run I broke way early to avoid it. Then again at the 1:00 mark I experienced it and nearly went through a cone wall.
Stephen
Autocrossing Videos
Instagram: sholzer17
sholzer is offline   Reply With Quote
