Old 12-04-2016, 05:10 PM   #281
Goertz
Goertz's Avatar
Drives: 2016 1SS Auto
everything is being prepped to go live
Looking to activating our sponsor account on 19 December on here.
Website should be 100% live on that date as well. Ironing out the final bugs on the site this week and getting the last bits of work done to the car this week as well.
Aiming for a dyno date this coming weekend.
Goertz is offline   Reply With Quote
Old 12-08-2016, 08:23 PM   #282
Goertz
Goertz's Avatar
new intercooler ready to rock, let me know if there was room to go any bigger lmao
should be on the dyno tomorrow
one of my tbolts got lost so just need to pick that up on the way to the dyno
Old 12-09-2016, 09:22 AM   #283
BigRedViking
BigRedViking's Avatar
Drives: 1987 IROC-Z 5.7L 2016 1SS M6 NGM
Send a message via Yahoo to BigRedViking
This project is badass! My only real concern is the intercooler. After working on countless body kits I always cringe when you have to modify, or remove structural pieces like the bumper reinforcement. I like the new design much better. I believe that your mounting profile should be boxed. I regard Goertz as a highly skilled fabricator with plenty of initiative. The way I see it we can meet, exceed, or fall short of OEM specifications. This is my favorite thread on camaro6
BigRedViking is offline   Reply With Quote
Old 12-09-2016, 12:14 PM   #284
Goertz
Goertz's Avatar
The intercooler is going to come off again in about a week to add mounting provisions for the radiator core support brackets, diff cooler right under the ic, and we will be adding a provision for a tow hook attachment.
I just tossed the brackets together last night to get it to the dyno today and be good enough for fixturing. The intercooler that will be going out in kits will essentialy be a new bumper support.
Old 12-09-2016, 01:09 PM   #285
Goertz
Goertz's Avatar
Tuner called and said no today. The appointment he is with is leaking fuel and is taking to long. He has to pickup family fromairport this evening. Aiming for mon now
Old 12-09-2016, 02:13 PM   #286
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I just have to say that your intercooler is totally bad@zz! I cannot imagine any problem with intake temps with that monster. I'm sure other big horsepower forced induction guys with air to air intercoolers would consider purchasing that thing all by itself if you would consider fabricating and selling those as a stand alone item.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 12-09-2016, 02:58 PM   #287
BadBowtieProductions
Check me out on YouTube!
BadBowtieProductions's Avatar
Drives: 2016 Camaro SS
Not sure how I missed this thread for this long.
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned
11.91 @ 117 - CAI intake only
11.99 @ 117 - STOCK 1/4 mile
410 RWHP / 424 RWTQ - STOCK Dyno
YouTube Channel: BadBowtieProductions
BadBowtieProductions is offline   Reply With Quote
Old 12-09-2016, 04:03 PM   #288
Goertz
Goertz's Avatar
@Jess
Yes sir that was part the idea.
I will offer options for alternate end tank and inlet outlet contributions so that it can accommodate any setup
Old 12-09-2016, 07:11 PM   #289
steelheadrob
Tactical Garage
steelheadrob's Avatar
Ditto. Feel like I am skipping to the last page in a book to see the ending. Not sure I have the energy to get through the first 21 pages. Looking for the cliff notes.
steelheadrob is offline   Reply With Quote
Old 12-09-2016, 07:20 PM   #290
Goertz
Goertz's Avatar
Thought yall might enjoy seeing some the fab pics from the intercooler and installed daylight pics
The laser/sheet metal shop that is my day job is hooking me up with the laser/bending for the intercooler endtanks.
Material is 5052 aluminum 3/16" thick. I've successfully run 1/8" wall intercoolers (fully welded, not bent from one piece so not quite as strong) as high as 30lbs of boost before so 3/16" should be good for a solid 40lbs or so. The sheet metal intake manifolds I built (although much less surface area) was 3/16 walls on the sides 1/8" on the top and it we pressure tested them to 50lbs of boost with zero issues. Needless to say I will gaurantee the 3/16 wall to 40lbs and if someone wants more boost I can make the tanks out of 1/4" for added security.
Old 12-09-2016, 07:22 PM   #291
Goertz
Goertz's Avatar
I had built a custom forming die for the bottom end tank for the 3" pipe
the end tank is 4.5" wide by 2.25" tall, I had to build a forming die to expand the 3" tube to that size and shape for ease of welding. Also had to machine a mandrel to go in the round side to maintain its roundness. The setup worked flawlessly.
I am ordering a bead roller so no more tacked on beads to prevent silicone slippage. That will make alot nicer product and take me alot less time, it can be a pita maneuvering around a huge intercooler without scratching it to get all those little tacks done...
Old 12-09-2016, 07:26 PM   #292
Goertz
Goertz's Avatar
i tossed together a makeshift jig out of the old bumper support. The intercooler piping locations on my last intercooler was perfect so I replicated those spots, then I had to cut out all the material in the middle to fit the core within it. I then bent a 1" sch40 aluminum pipe and stitch welded it down the length of the bumper support to maintain its shape and angles for the mounting brackets.
After this it was really easy centering my new intercooler and leveling it and getting the in and out pipes in the exact lengths to work as a simple bolt on.
Old 12-09-2016, 07:29 PM   #293
Goertz
Goertz's Avatar
The new intercooler was a major pita to install because I didn't think (it was 30F and nearly pitch black outside when I was putting the car back together at my house) to cut the black plastic radiator shrouding. I pretty much had to crush it down to get the intercooler on. The holes all lined up flawlessly with the mounting brackets though and the pipes went on easy.
I am going to pull the intercooler off and build my production jig of it within the next week. When I do this I will offset the core towards the front of the car enough so that the black plastic shrouding shouldn't need to be cut, I will also need to offset the top charge pipe towards the back of the end tank to keep proper alignment with the silicone that is snaked beside the headlight.
Minor adjustments for a easier install for the end user...
The bottom charge pipe has plenty of room for moving around so nothing needs to be done with it
Old 12-09-2016, 07:34 PM   #294
Goertz
Goertz's Avatar
And finally some pictures of it all installed
The pictures kind of dark but if you look closely through the top air vent opening in the hood by the Chevy emblem you can see the end tank is up that high and the clamp going onto the charge pipe back into the engine bay
The charge pipes are powder coated locally by a friend of mine that owns a coating business. The G1Pro was powder coated one white first then he put on a decal so that when he sprayed the black and pulled it off the white powder coat would be there just for the logo.
I am actually working with a company to get the top charge pipe from the tb all the way to the intercooler made out of 1 piece silicone. Just spray on some wd40 to lube it and shove it through the headlight opening. One simple piece for a very nice install and impossible to blow off. Only 1 clamp on tb and 1 on the ic.
