Old 01-11-2017, 04:16 PM   #281
Ricardo@Phastek
Ricardo@Phastek's Avatar
Drives: the boss nuts....
Send a message via AIM to Ricardo@Phastek Send a message via Yahoo to Ricardo@Phastek
Originally Posted by Adampau123 View Post
Will these Springs work with the 2.0 turbo?
We have not been able to confirm that yet. We do plan on it once we find a vehicle we can test on.
Ricardo@Phastek is offline   Reply With Quote
Old 01-11-2017, 04:55 PM   #282
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
Originally Posted by Ricardo@Phastek View Post
20x11 +43mm is what we have on our car.
Thanks. They look like they are poking out further than that offset.
Sent from my VS500 using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-14-2017, 09:39 PM   #283
metwaru
Newbie
metwaru's Avatar
Drives: 2016 I-4 2.0
I am interested in this as well. Too bad i'm not local i would volunteer my car for testing
2016 I-4 2.0 Velvet Blue
metwaru is offline   Reply With Quote
Old 01-20-2017, 02:56 PM   #284
Ricardo@Phastek
Guess what's BACK!!
Old 01-20-2017, 04:06 PM   #285
diirk
diirk's Avatar
Drives: 2016 Camaro SS
Awesome. You have my address....
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 01-20-2017, 04:06 PM   #286
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Me too!
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 01-20-2017, 04:08 PM   #287
BowtieRocket
Guess what's BACK!!
Looks like you need to run and overstock sale!
Old 01-23-2017, 04:04 PM   #288
Ricardo@Phastek
PM Sent
Old 01-26-2017, 07:05 AM   #289
2alfa
Lou
Drives: Camaro 2017 :-)
pls Clarify
Just to be sure / need confirmation:
(I've read all of this thread but it isn't clear)
If you go for Phastek Springs on a 2016/2017 Camaro WITH MRC can you expect a drop of 1.5 Inch all around?
There has been a lot of discussion of this but NO ONE has clarified this yet.
Is there any difference in drop for MRC and Non-MRC cars? And if so, is it due to that MRC cars sits lower from the beginning but both cars end up with the same ride-height at the end if you use the same springs?
Also, should you or shouldn't adjust rods or pivoting links on the MRC measuring device?
The Eibach;s supposedly lowers 1.1 Inch on a MRC equipped car (Lethal partly confirmed this)
I do believe the Camaro really needs the 1.5 drop though as those fender gaps are horrendous so preferably Phastek if drop is confirmed.
Just took delivery of my 2017 2SS, Summit White, NPP, MRC.
SS Ground effects, Graphics and Slamming next :-)
2alfa is offline   Reply With Quote
Old 01-26-2017, 11:27 AM   #290
BowtieRocket
Not sure but I am about to find out, these springs are about to hit my doorstep. BMR suggests "clocking" the suspension. Just got an email back from them stating to loosen all the rear suspension links on both ends to let the rear settle, then re-torque. Local alignment shop says they will take care of that for me during the $89 four wheel alignment.
Old 01-27-2017, 09:26 AM   #291
Ricardo@Phastek
I have gotten to measure the springs on an MRC car and our shop car is a Non-MRC car. They measure the same when it comes to the strut mounts, the difference is in the spring rate.
I have tested our springs and know they fit with MRC struts but we have not put them on a car to see what kind of drop we would get.
So, I guess to answer the question, "Will they fit?"....... YES, they will fit, just not sure what kind of drop you will get. I would say that you will be very close to the 1.5" drop like on the Non-MRC cars.
As for adjusting the rods, not sure since we have not put the springs on a car yet. We have put BMR and Eibach on MRC cars with out any issues, but their springs are only 1".
I hope this helps ya!
Old 01-27-2017, 03:21 PM   #292
diirk
diirk's Avatar
Mine just arrived. Will hopefully get them installed this weekend.
1morproject
Old 01-30-2017, 09:14 AM   #293
diirk
diirk's Avatar
New version springs installed this weekend.
Fitment is much better. Very happy with the updated design.
Thanks Ricardo
1morproject
Old 01-30-2017, 03:38 PM   #294
Ricardo@Phastek
Thanks Ricardo
Thank you for the update!!
Here is some new information.... Got our hands on a V6 car for testing... STAY TUNED!!
camaro springs, lower, lowering springs, phastek springs, springs
