Old 09-10-2016, 11:48 AM   #281
EXSSIVE
EXSSIVE's Avatar
Drives: 2016 Camaro 1SS M6
4k off of the launch control limiter with a "slow" release of the clutch. Stock rear tires at 28psi, fronts at 35.
The heat and humidity has been killing us here in Ohio lately. Once it started to cool off is when I layed down that 12.38 but the track started to go away after that. It was a "no prep" night.
Almost forgot to mention, a healthy 2nd gear burnout to get the heat into the tires.
EXSSIVE is offline   Reply With Quote
Old 09-10-2016, 12:09 PM   #282
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
Yesterdays DA 3900. Current DA 1700.
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 09-10-2016, 12:47 PM   #283
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
You used launch control? Surprised that got you your best result as most do better without it as it cuts timing.
You try with out using it?
Old 09-10-2016, 01:17 PM   #284
EXSSIVE
EXSSIVE's Avatar
Unless you side step the clutch or quickly release the clutch it wont engage the launch control so I'm basically just using the rev limiter function without using anything else.
I actually work for GM on the dealer level and being one of the top sales people in our area I was invited to the Camaro training event at Indianapolis Motor Speedway when the 16's came out. They really pulled out the stops and we road raced, drag raced and went around the oval at 175mph. I was also able to talk to a lot of the pro drovers and pick up some tips like the one above.
Old 09-14-2016, 04:37 PM   #285
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
2016 Camaro SS A8. All stock. I'm in the left lane.
Post the details of your quarter-mile pass using this template: (cut and paste)
Tires used on the pass: Stock Run flats
Performance Mods (if any): (2) BONE STOCK 2016+ CAMARO SS LT-1 A8:
Category submitted for: Please List the Category or Category #
R/T............-0.4339
60'.............1.966
330'...........5.409
660'...........8.221
660’ mph....88.04
1000'..........
1320'..........12.648
1320’ mph…111.11
Name of the track: Marion County International Raceway
Date of pass: 09/09/2016
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 09-14-2016, 06:27 PM   #286
GreaseMonkey83
GreaseMonkey83's Avatar
Drives: 2016 Camaro
Just used launch control like exssive suggested. First pass I went 12.28@114.5 with a 1.93 60'. Good advice exssive!! Ill post the slip and details up tomorrow while im at work.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it
GreaseMonkey83 is offline   Reply With Quote
Old 09-14-2016, 07:05 PM   #287
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Nice, makes you #1 so far on the stock manual fast list. Make sure you get that slip up!
His tip about using "some" of the launch control feature seems to be a good one.
...you should go quicker when it cools down too, what was your DA?
Old 09-15-2016, 08:06 AM   #288
GreaseMonkey83
Drives: 2016 Camaro
Here's my first and best pass from last night. Went 12.28 @ 114.5. My 60fts are a lot more consistent now using Exssive's technique. For the 4 passes that I made I had a 1.931, 1.945, 1.937, and a 2.031 (let the clutch out too fast and spun) 60ft. This was all with 3/5th tank of 93 octane.
Tires used on the pass: Stock 35psi front, 27psi rear
Performance Mods (if any): None
Category submitted for: #1 - Stock M6
R/T............. .309
60'...............1.931
330'.............5.264
660'.............7.983
660’ mph......90.90
1000'..........10.305
1320'..........12.280
1320’ mph….114.46
Name of the track: Summit Motorsports Park, Norwalk OH
Date of pass: 14 Sept 2016
Weather conditions: No wind, 69*, 68% Humidity, 1520ft DA
Old 09-15-2016, 08:12 AM   #289
bballr4567
Drives: 2016 Camaro 1LT M6
That is damn fast!!! Nice run!
bballr4567 is offline   Reply With Quote
Old 09-15-2016, 08:55 AM   #290
HyperblueSS
HyperblueSS's Avatar
Drives: 2016 Camaro SS M6
Nice Run...Ill definitely give this a try next time I hit the track!
2016 Hyperblue 1SS M6
"If you're not first you're last!"
HyperblueSS is offline   Reply With Quote
Old 09-15-2016, 09:24 AM   #291
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
660’ mph......90.90
1320’ mph….114.46
Nice run, in better DA that is an easy 12.1x...
Old 09-15-2016, 09:32 AM   #292
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
660’ mph......90.90
1320’ mph….114.46
Good job man! So you used launch control to what rpm?
I tried launching at 4k once but I must have let out the clutch too fast and it really spun. I want to get it down and just need more practice.. poor clutch!
Richard0nee is offline   Reply With Quote
Old 09-15-2016, 09:35 AM   #293
Richard0nee
That's awesome!
I'll give this another try but I'm not going to lower the rear psi since it won't be on a track.
Seems like launching to 4k rpm and slowly letting out the clutch is key!
Old 09-15-2016, 11:39 AM   #294
GreaseMonkey83
Drives: 2016 Camaro
Originally Posted by Richard0nee View Post
That's awesome!
It helps with consistency more than anything. I can get just as good 60fts with out the launch control, but they are few and far in between. Leaving from the same RPM helped out a ton and I was able to string together 3 decent 60's in a row before i purposely tried to push it a little harder and spun on the 4th pass. Regardless of whether you use launch control or not, you still need to ease out the clutch if you're on the stock tires.
