Old 07-03-2009, 08:55 AM   #29303
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
it finally did
ljustin293 is offline
Old 07-03-2009, 09:05 AM   #29304
cam2fst4u
Drives: 08 SS trailblazer,08 Silverado
Send a message via Yahoo to cam2fst4u
I wish someone would call me from one of the jobs I applied for... :(
cam2fst4u is offline
Old 07-03-2009, 09:53 AM   #29305
ljustin293
ljustin293's Avatar
what are you going to do about the store??
Old 07-03-2009, 10:12 AM   #29306
Vash
Drives: 00 Blazer
Mornin' all.
Vash is offline
Old 07-03-2009, 10:14 AM   #29307
ljustin293
ljustin293's Avatar
Originally Posted by Vash View Post
Mornin' all.
good morning
Old 07-03-2009, 10:34 AM   #29308
cam2fst4u
Let my wife look after it.... and work it when im not working at the other place i guess..
Old 07-03-2009, 10:36 AM   #29309
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Morning guys, just dropping in
I see we have punished the stanger in sales for june!
MOAR! I WANT MOAR!
Camaro_Corvette is offline
Old 07-03-2009, 10:42 AM   #29310
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
morning whores
later whores
Gentry78 is offline
Old 07-03-2009, 10:53 AM   #29311
cam2fst4u
hey gent
bye gent
Old 07-03-2009, 10:53 AM   #29312
cam2fst4u
how bout a link C_C
Old 07-03-2009, 11:08 AM   #29313
68 Z/28
Father Time
68 Z/28's Avatar
Drives: 1967 Malibu / 2002 Caddy DTS
Send a message via Yahoo to 68 Z/28
Yo Ho's
She's been sold ( Goodies List Updated )http://www.camaro5.com/forums/showthread.php?t=86262
68 Z/28 is offline
Old 07-03-2009, 11:12 AM   #29314
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
how bout a link C_C
It was featured on our homepage!
http://www.camaro5.com/forums/showthread.php?t=30317
Gotto go. Later
Old 07-03-2009, 11:14 AM   #29315
68 Z/28
Father Time
68 Z/28's Avatar
Gotto go. Later
Bye CC
68 Z/28 is offline
Old 07-03-2009, 11:39 AM   #29316
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Gent/Spike -
The asvab is score based, but its a bit confusing because they list percentiles on the score sheet.
At least for Army, your total score (for example, Gents 67) is just a guideline for the level of jobs you should be looking at. Any particular job will actually require a certain score in certain subsections.
What Gent was referring to with his 130 was a line score - one of those compilations of certain subsections - for Army use only. For example, a computer tech doesn't need to know much about engine repair.
Each branch uses the ASVAB differently:
Marine Corps.
The Marine Corps determines job qualifications from four separate composite scores made up from various sub-tests of the ASVAB. The Marine Corps Composite Scores are:
* Clerical (CL)- No Marine Corps enlisted job uses this composite anymore. In 2002, all enlisted MOS's which had a requirement for a CL composite score were converted to GT scores.
* Electronics Repair, Missile Repair, Electronics & Communications (EL) - Determined from General Science (GS), Arithmetic Reasoning (AR), Mathematics Knowledge (MK) and Electronic Information (EI).
* General Maintenance, Construction, Utility and Chemical Maintenance (MM) - Determined from General Science (GS), Auto & Shop (AS), Mathematics Knowledge (MK) and Electronics Information (EI).
* General Technical, Special and Officer Programs (GT) - Determined from Verbal Expression (VE) and Arithmetic Reasoning (AR).
Air Force.
The Air Force has four composite score areas made up from the individual ASVAB sub-tests, known as MAGE. The four composite score areas that make up MAGE are:
* Mechanical Aptitude Score - Determined from General Science (GS), Mechanical Comprehension (MC), and Auto/Shop (AS).
* Administrative Aptitude Score - Numerical Operations (NO), Coding Speed (CS), and Verbal Expression (VE). (Note: With the elimination of NO and CS from the ASVAB, a "dummy score" is now inserted there, so the Administrative Score is actually determined directly from the VE Score).
* General Aptitude Score - Determined from Arithmetic Reasoning (AR) and and Verbal Expression (VE).
* Electronics Aptitude Score - Determined from General Science (GS), Arithmetic Reasoning (AR), Mathematics Knowledge (MK), and Electronics Information (EI).
Army.
The Army determines job qualification from ten separate composite scores made up from various sub-tests of the ASVAB. The Army Composite Scores are:
* Clerical (CL) - Determined from Verbal Expression (VE), Arithmetic Reasoning (AR), and Mathematics Knowledge (MK).
* Combat (CO) - Determined from Verbal Expression (VE), Coding Speed (CS), Auto & Shop (AS) and Mechanical Comprehension (MC). Note: Because CS has been removed from the ASVAB, a "dummy score" is inserted for this area.
* Electronics (EL) - Determined from General Science (GS), Arithmetic Reasoning (AR), Mathematics Knowledge (MK) and Electronic Information (EI).
* Field Artillery (FA) - Determined from Arithmetic Reasoning (AR), Coding Speed (CS), Mathematics Knowledge (MK) and Mechanical Comprehension (MC). Note: Because CS has been removed from the ASVAB, a "dummy score" is inserted for this area.
* General Maintenance (GM) - Determined from General Science (GS), Auto & Shop (AS), Mathematics Knowledge (MK) and Electronics Information (EI).
* General Technical (GT) - Determined from Verbal Expression (VE) and Arithmetic Reasoning (AR).
* Mechanical Maintenance (MM) - Determined from Numerical Operations (NO), Auto & Shop (AS), Mechanical Comprehension (MC) and Electronic Information (EI). Note: Because NO has been removed from the ASVAB, a "dummy score" is inserted for this area.
* Operators and Food (OF) - Determined from Verbal Expression (VE), Numerical Operations (NO), Auto & Shop (AS) and Mechanical Comprehension (MC). Note: Because NO has been removed from the ASVAB, a "dummy score" is inserted for this area.
* Surveillance and Communications (SC) - Determined from Verbal Expression (VE), Arithmetic Reasoning (AR), Auto & Shop (AS) and Mechanical Comprehension (MC).
* Skilled Technical (ST) - Determined from General Science (GS), Verbal Expression (VE), Mechanical Comprehension (MC) and Mathematics Knowledge (MK).
Navy & Coast Guard.
The Navy and the Coast Guard use direct ASVAB line scores for job qualification determination.
Hope this clarifies things instead of just making it more complicated.
-X
P.S. - Looking at my ASVAB scores, I realize that I misremembered my score. I made a 93, not a 94 . However, as said earlier, a 93 is good enough for any job - 80 is about the highest required.
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline
10 tags for dg, 3.4l of ram-air fury ftw!, all tags for fake palm tree, always remember to not forget, call tactical z peanut, dg's tag empire restored, hail to da hose, lol@xsoptifail, nick is a delicate flower, post if you notice this tag, potd extended to weekends, pq is still shorter than frodo, pq is the coolest.........., sugar shack, votw every friday
LOUNGE Forum camaro5 Site Related Announcements / Suggestions / Feedback / Questions 37 01-04-2009 08:29 PM
