#2885 |
![]() ![]() Drives: 2017 2SS M6 Join Date: Apr 2017
Lol. It does not take .4 seconds to hit the brake.
#2886 |
![]() ![]() ![]() Drives: 2013 Camaro convertible 2SS/RS Join Date: Sep 2014
#2887 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Some additional information with the 10.6 number - within about 800ft
@8:45 https://youtu.be/Zol-OKJvyB8 |
#2888 | |
#2889 |
It could be. Depends on driver, especially if one is using the same foot going from throttle to brake. With left-foot braking or good right foot positioning and reaction time, that 0.4 could be something like 0.2.
It’s typically about 0.4/0.5 seconds to react to a typical drag tree. |
#2890 | |
#2891 |
Ford lost all credibility with me when they said the 15 GT was lighter than the 14. I take all their "numbers" with a truckload of salt.
#2892 |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
The ZLE is already 1 tenth behind at 60 mph because of the extra aero vs the ZL1. What's with the der emoticon? Did you want me to say 0.16 seconds slower to 100 mph? I was rounding a few hundredths of a second. Sheesh.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
#2893 | |
Either way, IF Ford did it the Motor Trend way and just added the two together, 10.6 seconds is nearly as fast as the ZR1 at 10.4. That's impressive. If the Ford test is a continuous 0-100-0 then it is even that much more impressive given the response time to brake (even if it is a 0.2 second time to apply the brakes).
2021 Camaro ZL1 A10
#2894 |
Show me the 1le 1/4 mile time in the 10 speed auto.
#2895 |
Your comparing a auto zl1 times to the 6 speed 1le. The 1le was 2 tenths faster to 60 then the manual zl1, so why wouldn’t the 10 speed be any different. Also, the 1le had a faster 1/4 mile then the 6 speed zl1! So there goes your aero theory.
#2896 |
Drives: F150 Join Date: Mar 2019
Motor Trend stipulates .2-.5 to transition from foot to the floor on the gas to the brakes... but I’m sure you’re the authority on reaction times.
#2897 |
You Mustang fanboys are really grasping at straws now. Lol. My bad. I'm sure it takes almost half a second for your brain to tell your left foot to push the brake 3 inches.
#2898 |
No you’re not sure , on the contrary you don’t have the slightest clue how long it takes. Now that’s a fact.
