03-22-2018, 11:03 PM | #2787 |
Drives: 2013 2SS 6sp manual Join Date: Feb 2018
Did it this afternoon and noticed and immediate difference upon starting and driving the car tonight. I didn't even know I had a problem, just wanted to make sure since I bought the car used. Highly recommend doing this if you bought a used SS.
03-23-2018, 01:00 PM | #2788 | |
Only thing is, you may notice some weird shifting and strange behavior from the transmission until it relearns/adapts. If I do this in my car, I will get some shift flaring on the 2/3 shift until relearn is done.
03-28-2018, 11:46 AM | #2789 |
Drives: 2015 Supercharged Camaro 1LE Join Date: Mar 2018
If this is an issue do you get any kind of service engine light ? I have that service engine soon indicator now and the dealer filled the car
03-28-2018, 10:25 PM | #2790 |
Drives: 2013 Dusk Special Edition 2SS/RS Join Date: May 2017
No CELs from the fuse pulls. Need to run to the auto parts store and use their scanner and pull the codes.
05-04-2018, 08:55 AM | #2791 |
Drives: 2010 Camaro 2SS LS3 Join Date: May 2012
If anybody has a scanner or one of those dash mount displays like DiabloSport or similar, you can monitor KNOCK LEARN. If it's near 0.00 then your good, 100% reading from High Octane table since this is what the fuse pull does.. resets KNOCK LEARN back to 0.00. If it increments towards 1.00 then your getting reduced power. 1.00 is 100% Low Octane table. 0.5 would be 50% High, 50% Low Octane table. If your tuner simply copied HIGH OCTANE to LOW OCTANE then you could be near 1.0 KNOCK LEARN and have no loss of power. But then again, your tuner could have simply made the KNOCK LEARN value stop incrementing, there are a few ways to do the same thing here.
This tends to be much more useful than just monitoring Knock Retard since a small blip of retard is normal here and there, but if you see 0.5 Knock learn then you know your down on power and you need to try better gas. |
05-07-2018, 09:43 PM | #2792 |
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
If you have a tune, do you need to do this fuse pull? I thought with a tune it would only run from the high table or they rewrite the tables both the same?
05-09-2018, 10:12 AM | #2793 |
Drives: 2011 2SS/RS Join Date: Aug 2015
I read one reply related to DiabloSport and possibly missed the answer elsewhere. I know 87 octane was in it when I bought the car used. Do I need to fuse pull going to 93 octane OR can I just use my DiabloSport Intune i3 and push the 93 Octane Tune to my PCM, so no need to pull fuses?
05-09-2018, 11:17 PM | #2794 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
Just pull them wait an hour or overnight then reinstall, it can't hurt. I just did the fuse thing last week and my auto runs harder for sure. 100% worth it
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
05-10-2018, 03:55 AM | #2795 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
05-17-2018, 12:37 AM | #2796 |
Space Shuttle Aficionado
Bought my SS used. Pulled the fuses before leaving for work... Can't wait to see the results.
05-30-2018, 11:47 AM | #2797 |
I'm quite surprised you haven't done this already
07-14-2018, 05:13 PM | #2798 |
Drives: 2010 Camaro 2SS 6M Join Date: Aug 2012
The fuse pull works and makes a big difference. I have had my 2010 LS3 M6 for 8 years now. Stared doing the fuse pull back in 2011. Have to do the pull every so often as the ECM seems to slowly revert back to the low side. I never put less than 91 in the tank. On high fuel map I can hit 100 mph in 3rd gear very quickly. Takes quite a bit longer when it reverts back to low map.
Any of you guys using Torco to boost fuel tank to 95-98+ octane ? Have not tried that yet. |
07-14-2018, 11:55 PM | #2799 |
Not tried that yet, but thanks for the reminder as I need to go pull the fuse right now. It has been a little sluggish last couple trips and I always use 92 octane.
07-15-2018, 05:05 PM | #2800 |
Drives: 2013 SS Camaro Join Date: May 2016
Best camaro tip ...just did it..last week...I run 93 only..felt like new again...bump
Sent from my SM-G960U using Tapatalk |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) | raptor | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 14 | 06-02-2020 12:51 PM |
What kind of gas are you filling up with in your '10 Camaro? | JewelZ | 5th Gen Camaro SS LS LT General Discussions | 42 | 08-02-2009 09:31 AM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
