#267 |
![]() Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Looking forward to the results.
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake |
#268 |
![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
A FEW PICS from ECR TT with SCCA on 4-15-23
OK here a few pics of me and car at ECR!! LOL
I only ran ONE session of the four sessions because I cooked my starter. THAT run is in the YOUTUBE video in my signature below.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#269 |
My next track time is MAY 6th at Motorsports Ranch 1.7 CCW so I will post up results. Weather permitting I am hoping for a personal best but I will post up either way.
#270 | |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#271 | |
#272 | |
#273 |
UPDATE AP Racing Brake Set Up
Ok well THIS saturday I will be out at Motorsports Ranch Cresson TX on the 1.7 CCW to see if I can do a personal best with these FRONT AP Racing Brake set up.
A few notes at to WHY I chose this specific set up. First off I chose to get the CP9668 Caliper set up. This SPECIFIC caliper allows you to run the THICKER brake pads. To be exact 25MM brake pads (1 inch thick). This brake pad is almost TWICE as thick as the pads used with a ZL 1LE caliper as a comparison. There are TWO versions of the CP9668 caliper set up and the HEAVY DUTY version which I opted for uses a D62 PAD (pad radial width is 62MM). The NON-Heavy Duty version uses a D54 PAD (pad radial width is 54MM) WEIGHT Savings. This BIG BRAKE kit is 20 POUNDS Lighter than a stock ZL1 1LE set up. The CALIPERS DO NOT use piston boots (they are bootless). The pads can be changed out in a few minutes by loosening TWO 6MM Torx bolts. They also provided a spring clip that you can use INSTEAD of the two 6MM TORX bolts but THEN you cant use the anti-rattle clips. I chose the 390MM rotor setup although technically you could choose to go with the 372MM Rotor (they use these on Corvette C8 set up). I opted to get the anti-rattle clips for the calipers. These clips will keep the pads from making alot of racket as they shift as pressure is being applied to them. For a track car its NOT Necessary but for a street car, they are a MUST. So the bottom line is I chose the largest rotor available, biggest caliper and widest PAD. I verified that THEY WILL fit inside my 18 x 11 APEX EC7 ET25 wheels. Essex offers a template which you can print out and then I transferred to a piece of poster board and then I checked it on a loose wheel. Just to be on the safe side, I sent the template to APEX Wheels and their engineers CONFIRMED that the 18 inch wheels I currently have had enough clearance. I purchased TWO sets of brake pads with the big brake kit. I got a set of FERODO 3.12 track pads which I will run saturday. The second set which is installed currently is a set of FERODO 2500 PADS. This is their high performance street pad and I have been pleased with them so far. In case you were not aware, BREMBO owns AP racing which is a distributor for www.essexparts.com. There is a WEALTH of information on their website regarding their offerings complete with videos. Anyway, more to come later!!!!
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 05-04-2023 at 12:44 AM. |
#274 |
I had no idea Brembo owns AP racing.
That quick change brake pad option sounds great!
#275 |
UPDATE 2 AP Racing Brake Set up
OK guys, one of the major selling points of the AP Racing Brake set up according to them is that the serviceability and maintainence is MUCH easier vs the stock setup. Another significant factor is that the AP Racing is 20 pounds LIGHTER than the stock ZL1 1LE set up in total by comparison.
I had chance to test that theory after I did some track testing the other day. The FIRST thing that happened towards the end of the day is that I broke a wheel stud and as you know that is pretty much a pain in the ass on the ZL1 1LE brake setup because it requires the removal of the brake caliper which is held on by TWO 18MM bolts. The problem with those bolts is that it is hard to get the proper torque on them when you reinstall them and they can easily strip out if you arent careful. So below you will see that the AP racing caliper is actually attached to a SEPARATE BLACK Billett caliper bracket that you never have to remove and THAT bracket has TWO Studs that are actually parallel to the ground that the caliper slides over and TWO 14MM nuts attach the caliper to the bracket. So to take the caliper OFF the car, you just unbolt the two nuts and the caliper will slide off to the left (assuming passenger side). Another issue that the AP Racing setup solves is pad changes are MUCH Easier and Much LESS FREQUENT because the pads are 25MM (1 inch thick - see pic). This assumes you are using the CP9668 caliper. In my PARTICULAR case I chose the HEAVY DUTY version of the CP9668 caliper which uses 62MM width pads as compared to the standard 54MM width pads. To change the pads you simply unbolt the TWO allen headed bolts you see in the pic of the caliper. Another PIC of the inside of the caliper shows the brake pistons ; which of course AP Racing will tout as a selling point; is that these calipers DO NOT have piston boots. So the days of cooking the silicone boots SHOULD be over. My NEXT track day I will be running DS 3.12 front pads on the AP Racing Caliper setup and I will run DTC60 pads on the stock ZL1 1LE rear rotors. The AP Racing system is designed to allow for the use of the stock rear brake system. Of course the million dollar question is, '"Are these calipers worth the money?" In the next few weeks I will try to determine that. Ultimately for me personally, if I can be significantly FASTER with this set up compared to the MODIFIED ZL1 1LE set up then that would be a YES. Is it worth it for the VAST majority of people probably NOT.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 05-14-2023 at 11:22 AM. |
#276 |
UPDATE 3 AP Racing Brake Setup
You can use as I mentioned the AP Racing Set up on the FRONT of our cars WITHOUT changing out the rear set up and it WILL NOT upset the brake bias that is built into our cars because they design the system to MATCH the brake torque characteristics of the STOCK GM set up. . The statement BELOW is DIRECTLY from the Essex parts website and contains some useful info:
Q: Is it okay to just buy your front-only brake kit? What about the rears? A: Our front brake kits are designed to very closely mimic the OEM torque output on the front axle.That is accomplished by carefully sizing the discs and caliper pistons.For example, if we increase the disc diameter in our kit vs. stock, we decrease the overall piston area to produce the same overall torque output as the factory setup.As such, installing our front kit on your car will only have a negligible impact on brake bias.In most cases, the shift in brake bias is only in the 2-3% range.To put that in perspective, installing a more aggressive brake pad compound in your factory front calipers would typically have a greater impact on brake bias than installing our front kit while keeping the OEM front pad compound. On most front-engine sports cars, the front brakes are taxed much more heavily than the rear brakes.That's why the front brakes are almost always larger, and why you go through 2-3 sets of front pads and discs for every set of rears you burn up at the track.The fronts do a disproportionate amount of work, and as such, they are the most critical component to upgrade.On many platforms, rear brake upgrades offer diminishing returns.The rear factory components tend to be smaller and lighter than the front components.As such, switching to AP Racing calipers and discs don't usually offer the dramatic unsprung weight savings that they do on the front.Since the rears tend to not run as hot, simply running good race pads and stainless steel lines on the rear will solve or prevent any rear brake issues. On a rear-engine car, the rear brakes do a proportionately higher amount of work than on a front-engine car.As such, brake wear tends to be more balanced on the front and rear, and rear upgrades can be more relatively more important to the overall system performance. Q: Will your brake kit mess with my ABS, stability control, torque vectoring, or disrupt my front to rear brake bias/balance? A: No!Since our systems closely mimic the factory brake torque output on a given axle as described above, they have no noticeable impact on ABS, stability control, torque vectoring, etc.The brake pedal will feel much better due to lower compliance, and the brakes will take a far greater beating for considerably longer.You won't have any wonky ABS issues however. Reference website (look under FAQ): https://www.essexparts.com/ap-racing...m-camaro-gen-6
#277 |
![]() Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
#278 | |
The Xp12's wore MUCH better than the XP20's but they as well DID NOT have the same bite as the DCT60's did These pads dust MUCH less than the HAWK pads did and they were easier on the rotors.
#279 | |
#280 |
Well I also used these pads as my street pads as well so in that regard they were decent because they definitely were better on the street than the stock brembos were but just not as track capable as the hawks
