Old 12-01-2017, 10:24 AM   #267
JusticePete
Drives: Camaro Justice
Porting can yield better throttle response, but the choke point is the butterfly / OE TB hole. Could someone explain how and why they would expect a RWHP gain from a ported TB as the size of the TB has not been changed?
JusticePete is offline   Reply With Quote
Old 12-01-2017, 11:08 AM   #268
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I just ordered 1..
Old 12-01-2017, 11:19 AM   #269
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Originally Posted by JB'sZL1 View Post
The af mixture and timing could be off with those mods. Coupling with the fact that one will not appreciate the gains w/o the tune, for me it's a no brainer.
Concur.
Changing topics,
Do you think it's wishful thinking that GM will come out with and aftermarket (drag) tune to go with their performance product line? The only way I would do a tune is if I can keep the warranty intact.
Old 12-01-2017, 11:20 AM   #270
kwav8r
Flyin NOE
I think Tony Mamo uses a larger TB, the part numbers from the OEM to the one he ports is not the same.
Old 12-01-2017, 11:28 AM   #271
JusticePete
That makes sense.
Old 12-01-2017, 12:13 PM   #272
kwav8r
Flyin NOE
Originally Posted by Lt1z350 View Post
No it is not a different or larger body. The point is 100 percent valad as I have tested the theory on my own. The only way to really gain power is to increase over all flow either oversizing the choke point or making it flow more by removing half the throttle shaft which does increase air flow as if was larger. The problem is at that point you will set a code for airflow correlations between the maf and tps and will go into reduced power. I have done this on my own so know what it takes to increase flow and piss off the stock tune. I don’t have a pic handy but will post later when get home. So now I can’t use it till I tune for it. What the porting is doing is removing a large lip so that at 25 percent open it is acting more like 40-45 percent open. Soon as you crack the blade on the stock one the air is forced to other side of body as ramps up when you port it then it pulls more even from top to bottom. A vacuum and some smoke sort of a wind tunnel affect you can see what it is doing stock vrs ported. So in the end gets you more response maybe a little power under the curve but wot it is flowing no more over all air it is less turbulent so might see some small gains but over all driveabilty is what your paying for with out having to tune.
I stand corrected.
OEM Part is 12678223
Tony shipped me 12620263 (ported of course).
12620263 supersedes the OEM. As I can't find the specs (bore diameter) for either part I'm going to assume they are effectively identical.
Agree (and understand) what porting does - makes airflow less turbulent, more efficient. The payoff (butt dyno) gives the impression that the car is quicker, which it may be from a throttle response standpoint but, agree that it would be marginal in the way of actual power increase.
Unless someone does a baseline dyno and then swaps in a TM TB for another dyno run I don't see how you could confirm either way - and even that would be suspect as what is actually being changed is, again, marginal and likely "within the noise" for statistical purposes.
Old 12-01-2017, 12:56 PM   #273
JusticePete
No change in volume = no gain in HP
That is not to say a ported TB doesn't drive better. If one right, they absolutely drive better.
Old 12-01-2017, 03:19 PM   #274
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Are you saying porting doesn't improve volume?
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 12-01-2017, 03:47 PM   #275
JusticePete
Think of a funnel. No matter how big the top, fluid only flows so fast through a 1" hole in the bottom. The top could be two inches wide or 22 inches, the choke point remains the 1" hole.
Old 12-01-2017, 08:36 PM   #276
gmanxpress
Drives: 2017 HBM ZL1 A10
http://www.camaro6.com/forums/showth...89#post9830289
gmanxpress is offline   Reply With Quote
Old 12-01-2017, 10:49 PM   #277
JusticePete
Originally Posted by gmanxpress View Post
I have a few hours around a flow bench including some test different brands of TBs along with OE. The numbers I have seen do not match these results.
Old 12-02-2017, 05:34 AM   #278
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
I think you are missing the point. Porting removes a very slight amount of metal, increasing the size slightly, it also smooths out the flow path, this reduces the resistance to flow increasing volume.
Old 12-02-2017, 12:41 PM   #279
396ssrat
Drives: 66 Chevelle SS
I've never seen a flow bench go down a dragstrip. I KNOW for a fact that Tony Mamo is a very talented air flow expert. Lots of pro porters out there claiming lots of magic but they don't all net the same results. A bench is but a tool.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
Old 12-02-2017, 05:31 PM   #280
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Who are you and what certifications do you hold to be questioning Tony Mamo? I've never once heard of you in 15+ years.
djfury05 is offline   Reply With Quote
