Old 05-06-2016, 10:19 AM   #267
Atra
Drives: 16' 1SS M6
Originally Posted by Tmcbigblue View Post
How does the car feel after the intake? Does it feel stronger?
Butt dyno shows it a little. Ear dyno shows it more XD...
Nightfall Grey 1SS 56F Black Bowties
Atra is offline   Reply With Quote
Old 05-06-2016, 12:14 PM   #268
K1SS MY SS
K1SS MY SS
K1SS MY SS's Avatar
Drives: 2016 Chevy Camaro 1SS
I installed my CAI about a month and a half ago. Didn't have whistling at first but now I do. It kind of sounds cool though lol. Doesn't really bother me at all.
Chillin wit the Stangs
K1SS MY SS is offline   Reply With Quote
Old 05-06-2016, 03:27 PM   #269
Sooks569
Originally Posted by Sales @ CAI Inc View Post
Hello All,
This post is in response to a request for an update regarding a solution to offset the whistle noise:
Our R&D team is diligently researching a possible way to cancel out the noise, this takes time and we will definitely keep everyone updated.
Reminder, the noise is generated from the OEM intake manifold and will be enhanced by ANY aftermarket air intake system that is less restrictive. We have sold a large quantity of our new 2016 Camaro air intake systems and we have only heard about the "whistle noise" from approximately 2% of our customers.
We have done extensive research regarding the "whistle noise" since the very first day that we were informed about it. We have confirmed that some of the OEM Camaro6 vehicles do indeed come with the noise. Early numbers show that there is a small percentage of OEM vehicles that have the noise and there is speculation that different castings (intake manifold) may have been used (on some vehicles) during production.
Until there is a solution, if anyone finds the noise to be intolerable, they can either go back to the stock box (which will muffle the whistle noise) and wait for a solution or they can return their system for a refund.
Bottom line, we are here for our customers, we stand by our products and we are very appreciative of all of our loyal customers and great dealers!
I've been getting the whistle on mine too, I was thinking it was coming from the exhaust. But, when you're going fast it's hard to tell where it's coming from exactly. Will you send out an email if a fix is available?
Sooks569 is offline   Reply With Quote
Old 05-08-2016, 09:22 PM   #270
JonGSA
JonGSA's Avatar
Drives: 2016 2SS Hyper Blue
Question for the people at CAI..,,,,,why does the filter have to be in the exact position? Reason being is that my car threw a 2099 yesterday. And I guess during the installation while lining up the maf tube, the filter was spun about an inch counterclockwise from mark. The filter being a round cone and all sides being equal, why does it have to be exactly in its position?
Thanks
'16 2SS Hyper Blue Metallic - M6 - NPP - MRC -Black bowties - CAI Intake - SW Cat Back w/NPP
Other money pits:
'13 S1000RR
'11 R1200 GS Adventure
'01 HD Sporty 1250
JonGSA is offline   Reply With Quote
Old 05-09-2016, 09:45 AM   #271
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Thanks
Thanks for purchasing our system!
Please make sure that everything is lined up correctly when installing the system and there will not be a CEL.
Sales @ CAI Inc is offline   Reply With Quote
Old 05-09-2016, 11:00 AM   #272
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
I get the whistle under moderate throttle and I have the msd intake manifold
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 05-09-2016, 11:08 AM   #273
JonGSA
JonGSA's Avatar
Thanks for the heads up. I thought i had everything lined up during the install but I forgot to rotate the filter back to the spot when spinning the MAF tube to the dot. All 3 dots are lined up now, even though the filter was just off by an inch to the left of the dimple. Hopefully no codes now.
However im still curious as to why. This isn't my first intake I've ever done. I've installed intakes on other cars over the years, dual cold air intakes on my 350z and none were ever this anal about filter alignment. Correct me if I'm wrong but the filter is round cone type so essentially all sides are the same. The only part of the filter that's different is the seam where the element comes together. Does this seam, lining up with the MAF sensor angle help "block" some air going past the sensor to keep it from "seeing" too much air?
Thanks
Other money pits:
'13 S1000RR
'01 HD Sporty 1250
Old 05-09-2016, 06:56 PM   #274
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Thanks
Eagerly awaiting response
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 05-09-2016, 10:55 PM   #275
laynlo15
Drives: 2022 Lt1 A10
I had a check engine light about a week after I installed it. . I didn't check the code. I disconnected the battery, pulled the maf back out and checked the gasket and it was fine. Put it back together and made sure everything was tight. Connected the battery and fired it back up. Not had a light since and still no whistle. I hear it sucking in a lot of air when I get on it and that's good.
Old 05-10-2016, 01:01 AM   #276
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
So I installed my CAI and it seems my metal housing lacks the dot to line everything up. I have since just lined it up the best I could based on images CAI has posted online. No CEL yet, but kind of odd my housing unit lacks a dot.
Sledgehammer70 is offline   Reply With Quote
Old 05-10-2016, 09:01 AM   #277
Atra
Drives: 16' 1SS M6
Do you have the whistle aids though?
Old 05-10-2016, 09:03 AM   #278
Atra
Drives: 16' 1SS M6
Uh oh....Have you swapped back to stock intake to see if it goes away?
Old 05-10-2016, 09:04 AM   #279
Pckrfan795
Pckrfan795's Avatar
Drives: 2021 Shadow Grey ZL1M6
I didn't realize the impact of this... we have a problem
Sent from my SM-G930V using Tapatalk
2021 ZL1M6, Shadow Grey
Pckrfan795 is offline   Reply With Quote
Old 05-10-2016, 09:16 AM   #280
Atra
Drives: 16' 1SS M6
Indeed...
6th gen camaro, 6th gen intake, camaro intake, camaro6, hyper blue
