#15 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
Today, I do a lot of tracking at Road Atlanta, VIR and Barber that have elevation changes with the potential to slosh 10-quarts of oil in a pan quite violently. It was with this issue, I designed my oil cooler system using the Porsche RSR crossflow cooler which adds two more quarts of oil to the quantity but this flow of oil is coming straight from the pump, is mounted higher than the engine and in application removes any chance for aerated oil to reach the filter and thus the oil galleries. I am still on the OEM pump at 37k miles total and logging 14,750 track miles now without any failures of any kind... not even a misfire! I would definitely build a dry sump system for my car as they help increase power, reliability but do come at a significant cost of operation and maintenance. Whether or not you follow your heart and build a most incredible Dry Sump Solo2 Championship winning car... I agree it is a path I will also embark upon. Right now I have conquered the oil cooler system and now working on the closed catch can system for the LT4/LT1 engines. See the photo below... in any design you build the Dry Sump, you will need a proven oil cooler setup. With that incredible Katech engine, my design will be a benefit you will most definitely realize upon using. I would also use Banks Power's analog sensor to CAN adapter with an oil pressure sensor tapped into the back of the block on both sides to see if you are getting any drop in pressures across the system. It can identify if and where you might be having aeration due to bad casting in the block or design of the system. I did so with temp sending units in the development of the cooling systems. |
#16 |
![]() ![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
That cooler setup is pretty great. I'm considering adding a 2nd cooler in the rear of the car with a fan seeing as I'll most likely need to mount the oil tank in the trunk.
Still a lot to figure out and design, but the only real answer I still need is what I need to do after the OEM oil pump is removed and leaves the port open that goes through the timing chain tensioner up to the camshaft?I believe it is the VVT feed? |
#17 | |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
#18 | |
I wish y'all were in California I'd just drop my car off and let you do your thing! |
#19 | |
The fix is to move to the East Coast where the competition is EpicAF... and that's just to reduce the Taxes!! |
#20 | |
#21 | |
I honestly wouldn't want to do another one. It's so labor intensive to install cleanly that I couldn't charge you enough for it to even make sense. I don't even want to look back at that job to see how many hours were put in
#22 | |
#23 | |
Really hope I get similar results. I'm hoping adding oil to the system and mounting the tank in the trunk both help keep the temps lower. I'm sure it's gonna take a lot of time to install the system, planning on doing it along with a full cage and engine refresh this fall/winter so I should be able to take my time with it. |
#24 |
I can't disagree with you, but others have gotten positive results with it, I seem to be the anomaly that didn't.
