#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
If you’re that worried about it, you can do what some track guys do and switch to 5W-50 Mobil one super car oil. Not sure how cold it gets where you are but I wouldn’t use this oil if you’re going to see cold starts under 50-60 degrees in your winters. I still think you’re worried about a problem that does not exist. These cars are built to withstand 100 degree track days on the 0w-40 oil. Now if you’re still using your cars (2017) factory fill of 5W-30 then I think you made a strong argument for switching to the updated 0W-40 factory fill.
Current: iso GT500
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#16 |
![]() ![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
Im currently running 5w30, since winter is over here im probably going to switch to 10w40 and see how it does. No additives and just see how the difference weight does.
#17 | |
![]() Drives: 2022 Camaro V6 2LT Convertible Join Date: Jul 2021
This video is one of the best defacto oil analysis presentations to learn what to look for in oil. These guys analyze back to back many of the important oil specifications in these oils:
I asked Lake Speed Jr. to create a video on the effects of oil temperature, How hot is too hot. |
#18 | |
thanks for that post |
#19 |
So I've gone down this rabbit hole you guys have sent me down with oil geek. Im going to run 5w30 but probably change it every 2000 miles or try and plan a good hour drive every couple of weeks to try and evaporate moisture and fuel that may be collected in the oil sump.
#20 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Next oil change send a sample off to Blackstone. Your current oil and maintenance regimen might be just fine.
