Old 02-19-2026, 07:45 PM   #15
Corky
Corky's Avatar
Drives: 2019 1SS M6
Track...Every time....
1st Gen ground effects kit GBA black | Mamo V3 ported TB | GM CAI | Velossa Ram Air | AWE touring axle back| Xpel PPF | illuminated door sills | Upgraded door panels with spectrum lighting |ZZP pillar pod with Banks Idash pro/AEM wideband
Corky is online now   Reply With Quote
Old 02-19-2026, 07:52 PM   #16
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
Originally Posted by Mark20242SS View Post
is it true that if you are in track mode the engine will run on 8 cylinders all the time? was just browsing facebook and came across a post about cylinder deactivation. googled it and that is what google says.
No, not true.
In Sport and Track, the more aggressive throttle/transmission calibrations make AFM less likely to engage because the car is tuned for performance, higher RPMs, quicker shifts, and more responsive pedal inputs but it’s not hard-disabled. If conditions are right (light throttle, steady speed, low load), it can still kick in to save fuel.
The only sure way to make it 100% go away is to use the Range AFM disabler that plugs into your OBD port. For as long as it’s plugged in, you have all 8 cylinders all the time.
RIPws6 is offline   Reply With Quote
Old 02-19-2026, 07:53 PM   #17
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
My lt1 stays in sport mode all the time even though I’ve been told by Pray that tour is the best shifting and such. For the record my Lt1 doesn’t have track mode
I can’t tell the difference anyway
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is online now   Reply With Quote
Old 02-19-2026, 08:24 PM   #18
2023-SS
Drives: 2023 SS
how programmable is the NPP exhaust?
Can we:
-program it to be SHUT on cranking?
-program it to be open for one USER Profile (spousal unit)
-program it always OPEN for another profile (Papa Bear)
-closed for cranking, then open afterwards for Papa Bear?
since we are talking modes, which mode DEF gives "Economy" performance?
my DD gets 45 mpg, the camaro hangs around 21mpg around town,
shows 27ish on highway.
you guys comments on Sport Mode throttle tip in is interesting. there was a giant box truck creeping along a skinny road, and he waved me to sneak around him, i had it in SPORT, and spun the tires taking off, i was very surprised, but maybe it was the Throttle Tip In, and not me being a Jack Wagon?
2023-SS is offline   Reply With Quote
Old 02-19-2026, 08:26 PM   #19
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
I switch between them quite a bit.
Tour is used for highway, as the suspension is nice and plush, easy steering. Same if there's any rough roads, or train tracks coming up. Tour mode.
Sport is mostly the default. It's great for all the twisty roads I get to drive on daily. Suspension is pretty stiff. Throttle response is wildly un-linear but I like its eagerness, so I'm ok with it.
Track is for when I really want to push it, as the pedal is way more linear, and the suspension is even stiffer.
Exhaust is always set to "Track"
speedyink1 is offline   Reply With Quote
Old 02-19-2026, 08:51 PM   #20
I use Tour mode with track steering and automatically selected exhaust based on mode, but I have the exhaust set to work in the modes I want it to.
Tour- valves open at idle, close on take off and then open again at 3500 RPM+
Sport- valves open at idle and open at general cruising but close at 8th gear+ for quiet operation during the freeway
Track- valves open under all conditions
Snow/ Ice- valves closed at all times
If only it was this simple... there are at least 9 tables involved in deciding whether to close or to open the exhaust valves, once defines RPM bands and the others the exact thresholds for valve open/close events, see example from my tune below (threshold definitions, sport mode valve close table, track mode valve close table). When I decelerate in sport or track mode under very low or no throttle, the valves are typically closed until the rpms pass the second threshold, then they open and remain open while idling, say, at a stop sign.
You'll also see that the valves are closed (value = 100) even in track mode in low rpm/high gear scenarios aka highway driving, that's why some people pull fuse F51 to make sure their valves remain in the default state (the tune sets this to "Open") at all times.
I have the A8, so only 8 forward gears captured in these tables, but they are likely very similar for the A10 as well, except they accommodate the 2 additional gears, of course.
Old 02-20-2026, 02:34 AM   #21
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
It's not as in depth as they make it appear and definitely do not overthink it. Open/ close tables all get set to the same values on my set up to keep things simple, since the valves on the Camaro do not allow for partial open/ partial close. I'll have to take some screen caps of how I have mine configured so you can see what I'm getting at, and why I run it the way I do. It works, and it works exactly how I want it to work when it's being commanded to work, and it's really effective for the Corsa NPP mufflers I use.
758 HP/ 804 TQ
Old 02-20-2026, 04:19 AM   #22
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '16 Camaro SS 6 spd manual transm.
Thumbs up
My SS 6MT is always in sport mode, I like the way my steering feels, and the car stays in sport mode all time, if I select track I hate that after shutting off and restarting it always goes back to tour, and on track mode I feel the steering too hard to move, in tour mode I feel the steering too loose, so sport is perfect for me, my npp valves always open since I removed that fuse. Suspension feels always the same sporty but comfortable since I don't have the magnetic shocks, don't have to worry about the excessive cost of replacing the magnetic shocks in the future.
'16 Camaro SS
Prior cars:
'14 Corvette C7 Stingray Z51
'14 Camaro ZL1 w/. Recaro seats
'11 Mustang GT 5.0 w. track package
'02 Porsche 911 Carrera
'05 Infiniti G35 coupe sport
Bosse'sBoss is offline   Reply With Quote
Old 02-20-2026, 07:34 AM   #23
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Can we:
-program it to be SHUT on cranking? Yes look for STEALTH mode in the menu
-program it to be open for one USER Profile (spousal unit) NO
-program it always OPEN for another profile (Papa Bear) NO
-closed for cranking, then open afterwards for Papa Bear? NO
Stealth mode is the only available mode Im aware of that will be closed valves on startup. Tour will close the valves ~5-10seconds after startup where the valves are open.
I'm not too familiar in the real world with snow/ice mode on the valves. I want to say that when you shut the car off in snow/ice mode it will default back to tour mode on startup.
Old 02-20-2026, 08:31 AM   #24
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Sport mode for driving and track mode for exhaust!
Old 02-20-2026, 08:47 AM   #25
HankVA
HankVA's Avatar
Drives: 2024 Camaro 2SS
I toggle back and forth between touring and sport based on road conditions. Another factor is whether I want some snap crackle and pop, or to try and avoid attracting attention around cops.
On track, it's suspension and exhaust sent to track mode, and sport for the steering.
2024 2SS - J6H BCD SCJ NPP F55 5VM SB3
HankVA is offline   Reply With Quote
Old 02-20-2026, 09:06 AM   #26
ember1205
Hot Camaro
ember1205's Avatar
Sport.
Tour is "fine" but has slower throttle response. With a manual, I don't like how it takes off from a stop.
Track is also perfectly fine, but it's one of two modes that the car will not start up in (the other is Ice/Snow, and it defaults back to Tour if you turn it off in either of these modes).
So, Sport is the happy medium for me.
Old 02-20-2026, 11:27 AM   #27
Mark20242SS
Mark20242SS's Avatar
Drives: 2024 Chevy Camaro 2SS
on my way to work this morning, i had it in track mode for a while and tour mode for a while. both seemed ok on the throttle sensitivity, sport mode is the one where it seems to be touchy on throttle.
i have my suspension, exhaust, and steering set to where i want so they do not change with the modes.
interesting how gm programmed all the modes.
Mark20242SS is offline   Reply With Quote
Old 02-20-2026, 12:44 PM   #28
ZLRob
Super Stock
ZLRob's Avatar
Here you go. This is how I configured mine. It works well this way.
758 HP/ 804 TQ
