#15 | |
![]() Drives: 2022 camaro 2SS Join Date: Apr 2023
#16 | |
#17 | |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Arpad is right, probably a g2... that r2 doesn't come 315/30 unless you're running the 315/35? Arpad, Will a 315/35 even fit? Damn, that's 28.66...probably not?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
#18 | |
In terms of width, each manufacturer's sizing is slightly different, so one company's 315/35 can technically be narrower than another's, but this size bump really feels too much.
#19 |
could be the G2 its dark out so cant see and for the ps4s i had them on a civic type R and was not impressed for traction at all
#20 |
![]() Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
Assuming its the G2 (which seems likely), there are very good comparisons on tirerack.com - especially this one comparing UHP vs max perf summer tires: https://www.tirerack.com/tires/tests...0#tires-tested
where tirerack does report that they found that the G2 has less traction/grip than the max performance tires (PS4S being a top example).
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
#21 | |
I might as well ask you instead of starting a new thread. I know you’re good with wheels and tires I planned on having some forged wheels made. 20x11 rears and wanted to run the 315/30/20 Mickey Thompson ET street s/s. Its OD is 27.8 What do you think?
#22 | |
Note that 27.8" rears will invert your rake, which is not optimal, however, we're talking very small values here. The stock configuration sets the front up at ~0.1 inches taller than the rear, while your Mickey Thompsons would raise the rear to become ~0.2 inches taller than the front, hence the inversion. I don't think you'll notice unless you're a pro... I probably wouldn't
#23 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
And I do not spin at all at the drag strip And as I said I can slam the pedal to the floor from 10-15mph as long as the outside temp is above 80 degrees F (without having to do a burnout)
#24 | |
Don't waste your money. They are all season tires not summer tires.
#25 | |
I understand what you mean but in my case having an LT1 trim means my car came with 245 40 20 (27.7) on all 4 corners. That’s only .1 that the OCD has to worry about! ![]() Uh oh, but wait…that’s only if I stay with front stock size ![]()
#26 | |
#27 |
#28 |
![]() Drives: LT1 Join Date: Apr 2024
G2 is also $100 less per tire than PS4S and has a slightly higher tread rating, so they should last a bit longer. Considering this, I would hope the PS4S has more grip compared to G2.
