Old 01-23-2026, 03:06 PM   #15
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I wouldn't be too afraid of the convertible. Top back glass delamination is the only significant issue. Can't be successfully repaired (reglued) due to the high fabric tension and replacements run $3-4k, which should be a budgeted long term wear-out item every 15 years anyway. Fortunately for buyers it's hard to hide and easy to see from the outside of the car and in pictures.
Otherwise the convertibles are just as solid as the coupes, plus they have and extra 1/2" thick steel channel in the lower rockers and a big steel x-brace underneath. Al's team designed the entire 6th gen chassis for ZL1 torque in the convertible first, and there were/are no stiffness downgrades based on drivetrain, so SS/LT1/V6/T4 and coupes all benefit. This is part of the reason why the coupes performs so well on road courses, they're much stiffer than the GM cost accountants would want it to be. There is zero cowl shake in these cars, the high doors keep the interiors pretty quiet even at highway speed with the top down, and the downward tilt of the infotainment display eliminates all sky glare.
If you go with an 8 speed, just plan/budget to flush the transmission fluid every 50kmi and shudder likely won't ever be a problem. Or tune out the TC slip, or both.
The 6th gen is a significant step up from the 5th in most respects. You won't be disappointed.
Gunkk is online now   Reply With Quote
Old 01-23-2026, 03:28 PM   #16
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by m6-lt1 View Post
Get a 2019 or 2020. The post covid LT1’s seem to be blowing up at a higher rate than the older cars.
Since you said you like twisty roads, get an SS, not an LT1 or SS 1LE. The LT1 has skinny tires in the rear. The SS 1LE has super high limits so it feels unalive when you are pushing it around twistys and in a straight line. You have to go way too fast to make a 1LE feel fun on public roads. The SS is the perfect balance for public road driving.
+1 on the SS being the correct "middle of the road" for both drivability and handling for us average Joe's, but I prefer the pre refresh looks of a '16-'18 the best. There are no "ugly" Camaro's IMHO, but... I love my '17. I also concur with the opinion about 1st model years, so that eliminates '16's (something you likely noticed on your 2010 5th gen, there were a few things that when you corrected them the car got even better).
So I would look for a clean 2017-18 SS Camaro. Best of luck and enjoy because whatever 6th Gen model you choose, it's gonna be so much more car than your 5th Gen that it will amaze you!
Ventmaster is offline   Reply With Quote
Old 01-23-2026, 08:10 PM   #17
Originally Posted by BBQdDude View Post
I'll update my OP but ...
Budget is 30k-35k TTL.
My past fifth gen was manual. However due to issues this one will need to be auto. With that said will hope to pickup one with AFM tuned out and TCM tuned already.
Would love a convertible but with the age I think possible issues and cost to replace will weed that want out and will seek a sunroof/moonroof.
Used to do 1/4 runs at National Trail raceway where I live in Ohio BUT my main joy with all past fast cars is country twisty roads and pushing Gs. Don't plan any 1/4 miles run with this one.
Pockets not very deep once retirement hits so major mods will be out. I am hoping TCM and ECM will be already tuned though. I know these cars get expensive but dong a lot of my own maintenance I think will help as long as the mod bug can be kept at bay.
Aha, makes sense, thank you.
I think someone is either a "vert guy" or not, and if you're okay driving a coupe with a moonroof, those are much cheaper. You could get one with the gray interior if you want the cabin to feel a bit more open and less like a fighter jet cockpit (which I love, but it definitely isn't for everyone, as the 6th gen interior is slightly less spacious than the 5th gen you're used to).
The 10-speed automatic in the SS (10L80) is a safer bet, but 2020+ cars are more expensive, and honestly, after a proper tune, no AFM and proper trans fluid, the 8-speed (8L90) is pretty good, too, it actually has one or two more "bang" WOT shifts than the 10-speed. People here act like these two are worlds apart, but in reality they're closely related designs. The original 10L90 (in the ZL1) wasn't a clean slate part, it's mostly based on the 8L90 with the potential for the shudder already fixed, but GM can't seem to make a flawless automatic, even when they get close, they just had to f*** with it and create a "Gen 2" 10-speed that now has valve body problems... anyway, rant aside, if you get the 10L80, you'll be good but pay more up front; if you get the 8L90, budget some money for a torque converter, new fluid and a tune that you'll probably want either way.
I very much enjoy curvy mountain roads here in East Tennessee, so I hear you on that one. Even the stock SS will be pretty good for that, as others already stated, but make sure you get proper tires, the stock Goodyear runflats are junk, loud and completely intolerant of cool or wet weather. You need a good set of tires, say, Michelin PS4S or Continental ECS 02, or maybe their all-season variants, if you want to fully enjoy the car.
Down the road, to keep the mod bug at bay, you can upgrade your wheels and optionally your brakes to the 1LE spec, which will give you even more traction and fun in turns. I have these and my 2SS can pull 1.1g+ on off-ramps or on-ramps without even a chirp. Then you can get a flex fuel kit with a tune for 40-50 extra horses, it's a pretty cheap upgrade that helps your engine, your wallet (if you can get cheap E85, which I assume is the case in Ohio) and your overall happiness with the car. Based on what you said, I don't think you'll want more, honestly.
Overall, you can't go wrong with a 6th gen 2SS, these are fantastic cars with many nice convenience and safety features. Just make sure you do a proper full inspection and a thorough test drive, ideally take a GM mechanic friend with you to check for obvious signs of abuse or neglect.
Old 01-24-2026, 02:39 PM   #18
2023-SS
Drives: 2023 SS
buy a southern car, if you find one near me, I can go check it out
you can be home in two days, and have a clean car with no rust issues.
I saw ppl in New York driving V6 camaros in the snow!?!?!?
2023-SS is offline   Reply With Quote
Old 01-24-2026, 03:32 PM   #19
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Some people do drive their cars in anything sometimes. I've Camaros and many other nice cars being driven through the garbage on the roads around here, gross.
speedyink1 is offline   Reply With Quote
