#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
While my car was in the body shop taken apart post collision I pulled the rain blocker off since it was fully exposed.
#16 |
Funny how the JLT looks almost exactly like the the SS variant of the "baby" Roto-Fab
![]() I don't get any excessive debris even with my Velossa air scoop, and the intake seals perfectly with the hood. The hairy cardboard hood liner on the SS definitely helps with that, though.
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#18 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
One consideration with aftermarket high-flow panel filters is airflow quality rather than total volume. These engines appear to be sensitive to turbulence upstream of the MAF sensor, which can slightly affect calibration. In my experience, running a high-flow panel filter resulted in a subtle but noticeable reduction in midrange response, which resolved after reverting to the factory paper filter. This is consistent with the assumption that factory MAF calibration is optimized around the stock filter media and airflow characteristics. |
#19 | |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
758 HP/ 804 TQ |
#20 |
Irrelevant because the filter area of the Rotofab Big Gulp is larger than stock and the 5" diameter tube size is larger than stock both reducing restriction on the intake side.
#21 | |
Moderator
#22 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily Last edited by dreksnot; 12-26-2025 at 04:21 PM. |
#23 | |
Moderator
#24 | |
#25 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
I had a nice conversation with the owner of S&B Filters last week and they have all the photos of the fitment and their Engineering dept has made the necessary changes. While they cannot legally make any adjustments to the corner of the air filter housing due to being a manufacturer with an EO# in California, they have sent me multiple boxes that I will be installing in the kits we sell, so the housings will fit perfectly to the hood with either our brackets or GMS units. I will have these ready in January. I agree the airboxes are all overkill as a stock paper air-filter in an OEM airbox made 697whp with 35% ethanol with just the right combination of cooling and tuning. Hope this helps!! |
#26 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
We did discuss how you fixed it yes, but I'm unable to. I have a spare box I can mail to anyone to modify, as I stated before, if you or anyone can offer the service, I just never heard back. Way to step up for JLT, someone had to do it, so thankyou for that.
#27 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#28 |
![]() Drives: Chevy Camaro ZL11LE Join Date: Jan 2026
Not stating anything that has been verified with quantifiable data but some reported factors that are worth considering when looking at intake solutions from the TB out.
Air will flow like water only as allowed by the point of the smallest constriction so installing a CAI with larger filters and tubes may not yield better flow without also removing the constriction of the stock Throttle body. Oiled air filter elements have been reported to corrupt MAF sensors. Causing the sensors to read incorrectly. Dry filters while not flowing as well as oiled filters don't have this potential issue Food for thought |
