#15 |
Agreed...with Cats you really don't want to be leaner than .80-.82 imo.
#16 |
Always a pleasure to hear solid info from the horses' mouths
![]() My car has LT4 injectors and the LT4 high side/low side fuel pumps, it's tuned for 0.82-0.83 lambda at WOT, and it can drink corn juice up to E60, producing ~735 rwhp while reaching only 5.1 to 5.2 ms injector pulse width. I'm happy to stay in this safe zone, no need to chase the last couple horsepower and ethanol percentages with its heavily diminishing returns, risking the cats or the engine in the process, at least from my POV.
#17 | |
This morning they proposed, 242 / 266 @ .050", .647" / .638" lift w/ 1.8 rocker ratio, 118+4. I calc'd 18 degrees overlap. My current cam is, 235 / 248 .644" / .631" 1.8 / 1.8 118+4, with 5 degrees overlap. What do you think?
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#18 | |
![]() Drives: 2018 ZL1 1LE Join Date: May 2022
However, I do have some data from the prior owner who trapped 131.19 in the 1/4. Another oddity; this car was set up on flex but was exclusively run on E85 when it was in California. We don't have as much E around here so my brother mostly runs it on pump gas; we noticed the car was running extraordinarily rich, so we had my tuner data log it when we threw it on his dyno. Turns out it was running at a lambda 0.74 average through the rev range, so we immediately retuned it; we did not datalog the old E85 tune. I'm guessing this had something to do with the elevation change from CA to UT, but I also figured MAF would do a better job at correcting that. Regardless, the car went from 610 WHP to 710 WHP on pump gas from this retune lol. |
#19 |
This also explains a lot; thank you!
#20 | |
#21 | |
I wonder if the tuner has logs of this car on the dyno running E85 at sea level. Would be interesting to see if their fueling headroom was from running it lean with catalytic protection disabled. I might shoot the tuner a message out of morbid curiosity. |
#22 |
![]() Drives: Zl1 Camaro Join Date: Oct 2023
Couldn’t reply email verification issues
Yes new katech oil pump going in. Next mods are going to be Kong x porting and port injection and ported heads. Thanks for inputs
2018 Zl1 1le 6speed
2” Kooks headers ,green cats full exhaust JLT intake, BTR Stage 2 cam,Mighty Mouse catch can Innovations west damper 9.25” lower 107mm throttle body, Mpi lid, flex fuel Full SPL rear suspension, DSX twin intank pumps |
