Old 03-05-2026, 09:22 PM   #15
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Originally Posted by Patriot Motorsports USA View Post
I will get a picture of how huge that fitting is and share it later today. You would need a female "hotdog in the hallway" sized fitting to go over the one and I suspect it would still be a beyotch to get to and remove the clip. For me, I wanted to re-route it away from the water pump area and belts, just in the remote case a belt breaks on track, it doesn't take out an oil hose that would have to be run in a path that could cause a wreck due to oil getting under my tires.
Hope that helps.
I get what you're saying, the whole setup looks great. Was just wondering about a plug and play solution. The AOS on my other car has a drain that y's into the factory oil drain and goes back to the crankcase and always wondered why their is no similar cc setup for our camaro's.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old Yesterday, 01:10 PM   #16
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
Just dropping how this turned out... and using the .5L Improved Racing CCR Catch Can with their optional -8an ORB to a -10an fitting which works perfectly with a -10AN Pushlock fitting to the OEM drain when cut just ahead of the engine mount.
LMK if anyone has an interest in something like this... but I did this because I knew it could be done and we have only a month before the 2026 GridLife Racing season begins!!
Patriot Motorsports USA is offline   Reply With Quote
Old Yesterday, 03:57 PM   #17
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Gotta admit that looks good! Love that it drains like the OEM box too.
Does that catch can have the ability to do a one-way blow off vent like MM?
Old Yesterday, 06:34 PM   #18
I know that Improved has a adapter that has a venting check-valve... maybe that works in the same way.
catch can, elite, improved racing, mighty mouse
