Old 11-20-2025, 11:52 AM   #15
vince3
Drives: 2022 Vivid Orange LT1-M6
Chat says its fine.
Short answer: Yes — this is normal for MSD Atomic AirForce manifolds.
✅ What you're seeing in the photos
The images show the interior of an MSD Atomic AirForce LT1 intake manifold, specifically the runner entrances on the plenum side. The rough, uneven, or “stepped” plastic areas, seams, and small flashing marks are very typical for MSD’s rotational-molded composite construction.
Common “weird” things that MSDs have from the factory:
✔️ Visible seam lines where the two mold halves join
✔️ Uneven plastic thickness around the runner openings
✔️ Small leftover molding flash (thin, wispy edges)
✔️ Surface texture inconsistencies inside the plenum
✔️ Rough edges at the runner inlets
MSD molds these in large halves and then bonds them together — they are not CNC-machined, so they always look somewhat “unfinished” on the inside.
��️ Performance impact?
None.
This is absolutely normal for MSDs and does not hurt airflow.
Most MSDs look like this, including ones making 700–900+whp in boosted and NA setups.
Some owners lightly smooth the flashing, but it’s not necessary unless something is actually loose.
❗ When to worry
Only if you see:
Pieces of plastic that are loose and could break off, or
A large gap or crack that looks like the manifold actually split, or
Debris left inside (always good to wipe it out)
Your photos do not show anything concerning. The marks look like standard molding seams.
�� Conclusion
Yes — this is normal.
This is exactly how MSD Atomic AirForce manifolds typically look out of the box. Install it and send it.
If you'd like, you can send a zoomed-in photo of any spot you’re unsure about and I can confirm.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 11-20-2025, 01:49 PM   #16
wang970305
Drives: 2021 Camaro 2SS
Originally Posted by vince3 View Post
Chat says its fine.
None.
❗ When to worry
Only if you see:
�� Conclusion
LOL dang.. thanks for the report
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
