Old 07-01-2025, 08:32 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Your boost numbers are lower likely because of your cam. Bigger cam will bleed off boost due to the increased overlap (point where intake and exhaust valves are both open). More overlap is good for making more high rpm power, but there is a point where it starts to work against a Blower car.
KingLT1 is online now   Reply With Quote
Old 07-01-2025, 04:09 PM   #16
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Originally Posted by Keithj3 View Post
I agree and I understand boost. I was stating an apples to apples comparison. Reason I went the X-port after the jokerz port is because I needed new bearings. The shop I use does deal with jokerz anymore so I went with the X-port. The car went from 858rwhp to 936rwhp, and now 60-130 4.86 in June Kansas City heat. X-port made the car faster. Same tuner same dyno.
You gained 80whp between a Jokerz port and Kong?
19Nasty1le is offline   Reply With Quote
Old 07-01-2025, 08:47 PM   #17
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Was there any change in your TQ? If you can remember, where did it peak?
758 HP/ 804 TQ
Old 07-01-2025, 11:06 PM   #18
Keithj3
Drives: 2016 camaro
I lost a lil bit of TQ it peaked about 3-400 rpm later. A only change was the X-port jokerz port I was on E-83 and and X-port E-70. Pulleys were untouched. About same temp outside. Even with 55 degree days I couldn’t get the car in the 4s 60-130, with X-port did it in June heat. I do have the latest X-port billet insert and the cnc thing he started doing in March. And the blower is WAY louder.
Keithj3 is offline   Reply With Quote
Old 07-02-2025, 12:24 AM   #19
Keithj3
Drives: 2016 camaro
Just looked brother my mistake made peak Tq 300 rpm later but made more was 829 tq now it’s 861
Old 07-02-2025, 12:14 PM   #20
ZLRob
Super Stock
ZLRob's Avatar
Very very interesting.. this is good insight especially since nothing changed except your blower outside of your build!
758 HP/ 804 TQ
Old 07-02-2025, 12:23 PM   #21
KingLT1
KingLT1's Avatar
X port shifts curve to the right, so that makes sense.
